简介
使用本指南移除并更换三星Galaxy S10+ 后盖。本指南适用于标准的玻璃后盖和陶瓷后盖。
你所需要的
在手机背面使用一个吸盘,尽可能靠近右边缘的中心(粘合剂最窄的地方)。
用强力,稳定的力拉动吸盘,在后盖和框架之间形成间隙。
将开口三角撬片的尖端插入间隙。
如果你在撬开时遇到困难,最好的办法是向边缘施加更多热量并再次尝试上一步。
您可以尝试在接缝中涂几滴高浓度(超过90%)的异丙醇,以帮助软化粘合剂。
I can’t get the back cover to seperate, I’ve been trying for several hours now, it just stays with the rest of the phone. I’m fairly certain my phone is hot enough as I touched the back and I can’t place my hand there for more than a few seconds at a time. It’s just not coming off and I’m so frustrated! Any help?
Hi Fiona,
The back adhesive can be very difficult! Have you tried the suggestions in step 3? It may take a few heat cycles to weaken the adhesive. You can use a hairdryer to heat it pretty hot along the edge.
My back cover glass is shattered but not coming apart! What do I do?
I was able to use my fingernails first (with the assistance of the suction cup) to get in the gap, and then, with my fingernails still in the gap there was enough room to put in the pick. I couldn't get the pick in there by itself even after 10 minutes of warming and suction cup prying... but my fingernails could get in, and then I used them to hold the space open and pull a little more so the pick could be inserted.
26等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
7条评论
Good guide, pretty easy to follow along
si le cambio la tapa trasera a mi s10 plus deja de funcionar bajo el agua?
That’s correct. The phone will not be water resistant.
Eso es correcto. El teléfono no será resistente al agua.
then How can I keep it water-resistant?
Jeet z -
i used a sock filled with rice in microwave for 4 mins and set it on the cell with a piece of clear plastic for 5 mins, back was off with 1 pick in 30 seconds
can super glue be used
