跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
三星 Galaxy S9 Plus NFC 天线和充电线圈更换
Dominik Schnabelrauch
Dominik Schnabelrauch3 其他贡献者
最后更新于 March 28, 2024
25 - 35 分钟
中等
使用本指南卸下NFC天线和 Samsung Galaxy S9 Plus 的充电线圈。
打开三星 Galaxy S9 Plus 将“损坏设备上的防水密封条”。如果你不更换粘性密封圈,则手机将“正常工作”,但会“失去防水功能”。
重新组装设备时,你需要使用“替代粘合剂”来​​重新连接组件。
你所需要的
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换, 后盖玻璃移除: 步骤 1 中的图像 1,1
    • 在开始之前,请关闭手机。
    • 将加热的 iOpener 应用到手机的长边,以松开后玻璃下方的粘合剂。使用 iOpener加热至少两分钟。在拆开过程中,你可能需要多次重新加热并重新施加 iOpener,以使粘合剂足够温暖以便切割。
    • 按照 iOpener 说明操作以避免过热。三星Galaxy S9的粘合剂非常强大。如果你无法使用iOpener打开设备,也可以使用吹风机,热风枪或热板。小心不要让手机过热 —— AMOLED显示屏和内置电池都容易受到热损坏。
    I don't know how much longer should I use for the min heat gun.
    Hui Chen - 回复
    Only heat it up so you can still handle the phone. That depends on your heat gun. Wearing (ESD-)gloves might give you some extra degrees.
    Tobias Isakeit -
    It is very very hard to remove the back glass due to the adesive… I don't know if it is possibile (at least for everyone) to remove it wothout broking the glass
    Luigi - 回复
    This is nearly impossible without breaking the glass or risking overheating. I would say apply heat repetitively for 6-8 minutes. The very most adhesive is across the bottom so push the pry stick way in. I generally start on the rear side.
    Thomas Hayes - 回复
    Whoah NO. It will damage the camera and other sensitive electronics.
    D Harlo -
    Heating the back is essential, challenging, frustrating and, for first-timers such as myself, seemingly impossble, but I will say don't give up...I'll have another comment later.
    cbclistener - 回复
    I tried with the iopener but I gave in after three attempts. I then used a hairdryer and a pizza oven infrared thermometer, heating in increments. 60C did the trick and I was able to get the first pick in. Further heating was necessary to ease the rest of the back off, all to 60C.
    Chris Harrison - 回复
  2. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 2 中的图像 1,1
    • 在以下步骤中,你将切割固定后盖的粘合剂。
    • 如图所示,后盖内侧的粘合剂是这样布置的。
    • 你将在所示区域中切割粘合剂:
    • 粘合剂厚的区域
    • 粘合剂薄的区域
    • 避免在此区域撬或切片,以保护指纹传感器柔性电缆。
    The yellow portion labeled "Avoid prying in this area" is also pretty heavily glued. I had luck using heat to soften it, but I messed up my fingerprint sensor because the image above is mirrored - I sliced through the right side because the image says it's on the left. The fingerprint sensor cable is actually on the right (when viewing the back side of the phone) on the same side as the phone's volume control.
    Nick Tipton - 回复
  3. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 3 中的图像 1,2 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 3 中的图像 2,2
    • 如果手机的后玻璃破裂,吸盘可能不会粘住。尝试用强力胶带将其提起,或将吸盘加到适当位置并使其固化,以便继续进行。
    • 将吸盘按到后盖上。
    • 用吸盘提起后盖的底边,打开后盖和框架之间的微小间隙。
    • 这可能需要很大的力,但你只需要用吸盘打开一个非常小的间隙即可插入工具。如果遇到问题,请加热以进一步软化粘合剂,然后再试一次。粘合剂冷却速度非常快,因此你可能需要反复加热。
    • 在你打开的间隙中插入一个三角撬片,然后将其滑动到右下角。
    This is the most challenging part. The suction cup can barely hold for the amount of force required...but here's a tip, especially for the first-timers like me. It's not obvious in this image, but the back, curved as it is as it attaches to the frame, is curved because the surface under the back is also curved. Therefore, using an angle for the pick that's a bit tilted up will help to get under the back, and get the cutting of the adhesive started.
    Don't let that give you too much confidence, though. Sufficient heating of the back, to make the adhesive soft enough to yield to the several picks, is essential. Go slow, if you go too fast, or don't have enough heat, you WILL break the glass...as I did. Replacements, fortunately, are easy to find and not too expensive.
    cbclistener - 回复
  4. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 4 中的图像 1,2 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 4 中的图像 2,2
    • 在仅插入三角撬片的尖端时,将其从左下角沿侧面滑动到顶部。
    • 将三角撬片绕顶角滑动并将其留在那里以防止粘合剂重新密封。
  5. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 5 中的图像 1,2 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 5 中的图像 2,2
    • 开始沿着S9 Plus侧面的左下角滑动三角撬片的尖端。
    • 将粘合剂切割到手机左侧的一半后,将开口拨片留在原位。
    • 将三角撬片从右下角滑到框架的一半,然后将其留在那里。
  6. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 6 中的图像 1,2 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 6 中的图像 2,2
    • 在框架的右侧插入第四个三角撬片,并将其滑动到右上角。
    • 将手机左侧的第五个三角撬片滑到左上角。
    • 使用三角撬片切割后玻璃上部下方的剩余粘合剂。
    • 不要一下子打开手机。易碎的指纹传感器电缆仍然将后盖连接到主板。
  7. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 7 中的图像 1,2 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 7 中的图像 2,2
    • 小心抬起后玻璃侧面有音量按钮的位置。
    • 使用撬棒的边缘撬起并断开指纹传感器柔性电缆。
    On my G965U, the fingerprint reader remained in the phone, and instead of disconnecting the flex cable from the motherboard, it was only necessary to disconnect the flex cable from the back glass where it was glued lightly
    lyellread - 回复
    I also have a G965U model S9+, and its fingerprint read also remained in the back glass.
    Nick Tipton - 回复
    It's easier to pop the button up than it is to reattach it when reassembling the phone. Well, I sure hope it goes better for you than it did me. (:
    Daylen Westwood - 回复
  8. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 8 中的图像 1,1
    • 取下后玻璃。
    • 重新组装时,请按照本指南更换粘合剂并重新安装后玻璃。
    • 如果你想要更换后玻璃,请按照本指南传送后部相机挡板,包括指纹。
    Is it necessary to replace the rear glass adhesive? I have given up on water resistance, just want it to hold in one piece.
    Zachary Shaw - 回复
    Hi Zachary,
    in order to assure that the rear glass sticks to the rest of the phone assembly you have to replace the rear glass adhesive once you removed the rear glass. However you can use a narrow and strong double sided tape, tesa tape or our precut adhesive card. All of these will do their job however as you just mentioned you will lose the water protection of your phone. Before installing all of these it is very important to remove the old adhesive backings (for example with high isopropyl alcohol 90% or higher).
    Sadly it's not possible to replace the rear glass without new adhesive.
    Dominik Schnabelrauch -
    Is the L shaped stocker with the three holes(first pic in step 2) in it essential? It came off when i was using iso to get the adhesive off. Just wanna know before i put the phone back together.
    Thanks
    Bob
    Bob Erto - 回复
  9. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换, NFC 天线和充电线圈: 步骤 9 中的图像 1,1
    • 卸下九颗4毫米菲利普斯#00 螺丝。
    Don´t forget to unscrew the two screws on the left side (one near the battery, and one near the edge).
    Janny 4real - 回复
    My s9+ NFC screws in this step are different sizes most are the same except one is shorter and coloured black and another is just shorter. The phone will not charge now, how can you find out which screws go where?
    H8redflip - 回复
    11 screws need to be removed here. Watch the video to confirm the remaining 2.
    Nick Tipton - 回复
    The 9 screws shown won't let the bracket up unless you finish with the 2 more screws. (near edge and bottom of the bracket).
  10. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 10 中的图像 1,3 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 10 中的图像 2,3 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 10 中的图像 3,3
    • 在包含NFC天线和充电线圈的塑料盖的右侧下方插入一个三角撬片。
    • 向侧面翻转三角撬片,将盖子从其塑料夹中提出。
    • 绕着塑料盖工作,撬起以释放剩余的夹扣。
    I used a pointed metal spudger to pop that piece. The picks were more difficult here. There's an arrow that points the spot that needs to be opened.
  11. 三星 Galaxy S9 Plus NFC 天线和充电线圈更换: 步骤 11 中的图像 1,1
    • 取下装有NFC天线和充电线圈的塑料盖。
结论
“”(如果可能)”,在安装新的粘合剂并重新密封手机之前,请打开手机并“测试你的维修”。
要重新组装设备,请按照逆序进行操作。
5等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
于11/23/16注册
228,969 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,409篇指南
2条评论
Be very careful when removing ... I broke my GPS antenna at the upper left at the index finger in the prior photo. Can't find a replacement anywhere.
Chris Schinell - 回复
How do you actually remove and replace the NFC charger..??
Farmer Detroit - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 33
过去 30 天: 100
总计 15,648
