简介
按照此指南来更换你的三星Galaxy S8的旧电池
拆开手机之前,你需要先将手机用到电量低于 25%. 充满的电池在收到重压或刺穿时很容易着火或爆炸.
如果你的电池有鼓包现象,参考此链接 采取适当措施. 千万不要加热你的手机. 可以用滴管或注射器再手机后改边缘注射(90+%)的异丙醇来使胶水溶解,鼓包的电池非常危险,请一定要戴上护目镜并小心操作,如果你处理不好的话,最好找专业人士代劳。
你所需要的
49等其他人完成本指南。
由衷感谢以下译者:
57%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
14条评论
this Iso + Heat method makes tough adhesive a thing of the past! just be patient. like the guide says, 2 mins to allow iso to penetrate
I applied the alcohol using a small paint brush, dipped into my iso jar, and “painted” along the battery edges.
roughly 30 seconds with heat gun on the front glass, boom, a freed battery
Just received this kit and I see it comes with the big adhesive, but it also has a smaller blue adhesive and a rectangle thing(that I think goes behind the battery?) that has a small one with it. Where do these things go?
Check out their guide they have up now for the replacement of this adhesive. Specifically, take a look at the pictures in step 10 to see where the little pieces are supposed to go.
Scott -
Highly recommend against doing this. Even going carefully and reheating, 2 of the corners cracked when moving the pick through. So much for taking perfect care of the phone for 2 years =o(
Ditto. I ended up cracking my glass using the iOpener method as well. After no ordering and replacing the rear glass as well now, I am resorting to only using isopropyl alcohol from now on. No matter how hot I got the iOpener, how long I let it heat soak the adhesive, or how many times i reheated the iOpener and reapplied it, I never got any of this adhesive to come off without a risky struggle. And upon ordering all the adhesive kits, I still was shipped missing pieces of adhesive (camera, fingerprint reader, specific support adhesive, etc.). Very frustrating and time consuming process; far more than what these guides say it takes.
Scott -
