Battery
2个答案 0 分 |
Power Button does not work. |
1个答案 0 分 |
New battery does not charge a second time |
1个答案 1 分 |
No display and power and hard drive lights are blinkings. |
Background and Identification
The Dell Latitude line of laptop computers are intended for business use, as opposed to consumer use. This means that these computers are very consistent in terms of what vendor manufactures the parts and what parts are used. Because of this, business computers are easy to maintain and support on a large scale (like a company) because they all have the same or similar components. The Dell Latitude E7240 is part of the Exx40 series of computers, which came out in 2013 and 2014. The E7240 was introduced in 2014. To locate the model number on your Dell computer, you can use this Dell support page.
Technical Specifications
- Height: 20.0 mm (0.79 inch)
- Width: 310.5 mm (12.2 inches)
- Depth: 211.0 mm (8.3 inches)
- Weight (with 3-cell battery): 1.36 kg (2.99 lbs)
- Battery: 3 or 4 cell “smart” Lithium ion
- Coin-Cell Battery: 3 V CR2032 lithium coin cell
- Chipset: Lynx Point-LP
- Processor Options: 4th generation Intel Core i3 / i5 / i7series
- Memory connector: Two SODIMM slots
- Memory capacity: 2GB, 4GB, or 8GB
- Memory type: DDR3L SDRAM (1600 MHz)
- Display Size: 12.5 in diagonal
- Display Resolution: 1366 x 768
Additional Resources
Dell Latitude E7240 Ultrabook Support Page
