跳转到主内容
加入维修社区 - 创建账户
指南
文档
配件
工具
型号:
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC
再显示 272 BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
概述
咖啡机是一种旨在方便家庭或商业场所冲煮咖啡的电器。它们种类繁多,每种设备都使用不同的方法从咖啡粉中萃取风味。
类型
滴滤式咖啡机
手冲咖啡机
手冲咖啡机是一种手动冲煮设备,让咖啡爱好者能够更好地掌控冲煮过程。其基本设计由一个漏斗或锥形滤杯组成,滤杯内放置纸质或金属滤网。将研磨好的咖啡粉放入滤网中,以缓慢且受控的方式浇入热水进行萃取。
全自动滴滤咖啡机
全自动滴滤咖啡机(也称为自动滴滤咖啡机)是一种受欢迎的电动冲煮设备,旨在提供便利与易用性。它们可以自动完成冲煮过程。你只需在水箱中加水,将咖啡粉放入滤篮,然后启动机器即可。水会被加热并滴滤在咖啡粉上。萃取后的咖啡通过滤网流入下方的壶中,壶底的保温板可保持咖啡温度。部分机型还具备调节浓度和定时预约等功能。
浸泡式咖啡机
冷萃咖啡机
冷萃咖啡机是一种设计用于简单、高效制作冷萃咖啡的设备。它们通常通过将粗研磨的咖啡豆在冷水或常温水中浸泡较长时间(通常为 12 至 24 小时)来制作咖啡。制得的咖啡原液口感顺滑且酸度较低,饮用前可根据个人口味用水或牛奶稀释。这些机器通常配有滤网系统以分离咖啡渣,使冲煮过程既方便又干净。
法压壶
法压壶是一种简单有效的咖啡冲煮设备。它由一个圆柱形的玻璃或不锈钢容器、一个压杆和一个金属滤网组成。冲煮咖啡时,将粗研磨的咖啡粉浸泡在壶内的热水中。几分钟后,向下按压压杆,将咖啡渣与咖啡液分离。由于咖啡粉在整个冲煮过程中与水保持直接接触,这种方法能冲煮出口感醇厚、风味浓郁的咖啡。
土耳其咖啡壶
土耳其咖啡壶(称为 cezve 或 ibrik)是专门用于制作土耳其咖啡的传统器具。这种小壶通常由铜或黄铜制成,配有长手柄和宽底座。将极细的咖啡粉、水和糖(可选)放入壶中,置于微火上加热。其独特的冲煮过程是将混合液反复加热至接近沸腾,从而产生一种名为“kaymak”的厚泡沫和浓郁的咖啡。极细的咖啡渣沉淀在壶底,带来独特而浓郁的咖啡体验。
加压式咖啡机
爱乐压 (AeroPress)
爱乐压是一款设计简洁、功能多样的便携式咖啡机。它由一个圆柱形冲煮筒、压杆和滤盖组成。使用时,将咖啡粉和热水放入筒内,搅拌后盖上滤盖,按压压杆即可萃取咖啡。其独特的设计不仅冲煮快捷简便,还能通过控制冲煮变量冲出一杯口感顺滑且风味丰富的咖啡。因其便携、经济且易于尝试各种冲煮技术,爱乐压深受咖啡爱好者欢迎。
摩卡壶
摩卡壶是一种利用蒸汽压力使沸水穿过咖啡粉,从而萃取浓郁咖啡的炉上式咖啡壶。它由底部的储水室、中间的咖啡粉漏斗和顶部的成品咖啡壶组成。水受热后产生压力,将水推入咖啡粉中,最终制成浓郁且高浓度的摩卡咖啡。这种制作过程简单快捷,以其能够冲煮出味道独特、接近意式浓缩的强劲咖啡而闻名。
单杯咖啡机
单杯咖啡机是一种紧凑、便捷的电器,旨在一次冲煮出一杯咖啡。它们使用预包装的咖啡粉盒或咖啡胶囊,让用户能够以极少的精力和麻烦,快速轻松地制作出一杯咖啡。这些机器提供多种咖啡选择以满足不同口味,因其简单高效而备受青睐。
意式咖啡机
意式咖啡机(通常称为咖啡机)是一种专门的咖啡设备,通过将热水高压强行通过细研磨的咖啡粉来萃取浓缩咖啡。它们通常在约 9 个大气压的高压下运行,以从咖啡粉中提取浓郁的风味和芳香化合物。意式浓缩咖啡以其强劲、大胆的口味以及表面形成的奶油状泡沫层(即 Crema)为特征。这些机器有手动、半自动和全自动等多种类型,为用户提供不同程度的冲煮控制。
全自动咖啡机
全自动咖啡机是简化了制作过程的高级电器。这些机器可以处理从研磨咖啡豆到冲煮的全过程,无需人工干预。用户可以自定义研磨度、咖啡浓度和饮品类型,因为这些机器可以制作多种饮品,包括意式浓缩、卡布奇诺、拿铁和常规咖啡。得益于内置的磨豆机和自动化冲煮系统,它们在提供便利与稳定性的同时,只需极少的力气即可享用现煮咖啡。
过滤式咖啡壶
过滤式咖啡壶(Percolator)是一种传统的冲煮设备,由壶身、中心管和穿孔滤篮组成。壶中的水被加热后,产生的压力将水向上推入中心管,并循环喷淋在滤篮的咖啡粉上。萃取出的咖啡流回壶中,循环往复直至达到所需的浓度。这种咖啡壶在过去曾非常流行,但由于冲煮方法和口味偏好的差异,现已大多被滴滤式咖啡机所取代。
虹吸壶
虹吸壶(也称为真空咖啡壶)采用了一种极具观赏性且基于物理原理的冲煮方法。它由两个腔体组成:下腔体的水被加热产生蒸汽压力,迫使水流向放置了咖啡粉的上腔体。当热源熄灭后,真空效应会将萃取好的咖啡重新吸回下腔体。这一过程制成的咖啡香气独特,口感顺滑纯净,能够充分凸显咖啡豆原本的风味。
更多信息
• 维基百科上的咖啡机
Andrew Optimus Goldheart
于10/17/09注册
516,388 声望
创作了405篇指南
团队
iFixit iFixit 的会员
Staff
119 名成员
创作了72,955篇指南
浏览统计数据:
过去 24 小时: 143
过去 7 天: 646
过去 30 天: 3,035
总计 192,115
