跳转到主内容
The Nokia 5130 XpressMusic is one of Nokia's mobile phones in the series of XpressMusic. It was released in January 2009 and discontinued in 2011.
remove the memory card password
I forget memory card password please help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 18
添加一条评论
17个答案
最有帮助的答案
Sreenu, try this "
Go to file manager on your phone
Go to settings and choose system folders,
In the System folder, find a file called mmcstore
Send the file to your PC using IR/Bluetooth
Open the file in Notepad
The password you need for your memory card is located within that file"
The other thing that might work for you is to "
1. Insert your card into your phone, without accessing it through the phone
2. Run FExplorer and Open the path C:\system
3. Find the file called mmcstore, and rename it mmcstore.txt
4. Copy that file (mmcstore.txt) to your PC and open it in Notepad
5. Your password will be located within that file. From here
One more thing you could try is to use a memory card read for your computer and format the cared through that. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
1条评论:
there is nothing with the name of File manager or application manager in Nokia 5130
完成的
添加一条评论
这个答案有帮助吗?
得分 3
添加一条评论
i forgot my memory card password please help me remove
这个答案有帮助吗?
得分 3
添加一条评论
yes
这个答案有帮助吗?
得分 3
添加一条评论
nokia c5130 memory card not opned
这个答案有帮助吗?
得分 1
添加一条评论
how remove the forget passowrd
Update
how to remove the forget password of memory card
Update
tell me hoe remove password
这个答案有帮助吗?
得分 1
添加一条评论
how remove the password of memory cad forget
这个答案有帮助吗?
得分 1
添加一条评论
i forgot my memoey card password please help me remove
这个答案有帮助吗?
得分 1
添加一条评论
to know the password
这个答案有帮助吗?
得分 1
添加一条评论
hellp
这个答案有帮助吗?
得分 1
添加一条评论
i didnt know about system folder in my phone
这个答案有帮助吗?
得分 1
添加一条评论
Forget memory card password
这个答案有帮助吗?
得分 1
添加一条评论
how to unlock my password
这个答案有帮助吗?
得分 1
添加一条评论
Hello., i've tried this for my Vivaz U5i sony ericsson. use thirdparty file managers like Xplore or others that has an option to show you hidden files. then follow the steps of @oldturkey03 . never update Xplore because i can't see again mmcstore file after update. now i got 2 mmory cards cannot be used bcoz of password. my Vivaz has now a broken resistive touch. but anyways goodluck guys :)
这个答案有帮助吗?
得分 0
添加一条评论
Yes I forget my memory password
这个答案有帮助吗?
得分 0
添加一条评论
memory card password unlock
Update (09/12/2017)
my memory card password unlock
这个答案有帮助吗?
得分 0
添加一条评论
Remove tha memory card password
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sreenu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 31,909
