跳转到主内容
加入维修社区 - 创建账户
有关 Dell Inspiron 15 英寸笔记本电脑的维修和服务信息。
No display. White LED blinking.
Earlier this had a bad battery issue. (Some combination of Amber and white.) But it worked after clearing CMOS. But now Fan spinning for about 3 seconds and the white diagnostic led blinking. Tried clearing CMOS, and unplugging everything unnecessary.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@lewishamilton use the 5000 series Inspiron 15 5567 Servicemanual En Usand check page 85 to determine what the trouble code will look like. If it is a continuous white light that blinks, this appears to be a non-specific hardware failure code. I would try this first. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
It would have been nice if you could remember what happened on here (Some combination of Amber and white.)
这个答案有帮助吗?
得分 0
4条评论:
Hi, Yes I checked the service manual before starting the thread, but there isn't anything similar.
Already tried that but no success.
Unfortunately, I can't remember the exact combination. But I checked some Dell manuals and mentioned as bad battery.
由完成的
@lewishamilton that could most certainly be a possibility. Commonly a bad battery should not prevent your computer from coming on. Remove/replace it and also remove the RAM and see if that changes anything. A bad Ram stick can prevent your computer from coming on.
由完成的
@oldturkey03 I don't replace it for TSing - I disconnect it, wipe the CMOS RAM and reconnect. That usually does the job, and the old battery can be reused.
由完成的
@nick not for the troubleshooting. You are right, for that you only need to disconnect the battery.
由完成的
添加一条评论
添加你的答案
Lewis Hamilton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 76
总计 1,463
