跳转到主内容
Why my phone there is not voice/sound?
I can't hear the sound
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@iraandespa if you hear no sound from the speaker, check with a headset. If you don't hear anything from that either, it could be software related. Of course, make sure that you have the volume turned up etc. Next, try to get into the Samsung Hardware Diagnostic Test Menu by dialing *#0*# There you will see the Speaker test. Give that a try and tell us what happened.
Bottom line, if it is a bad speaker, it should work with your headset. If it is a stuck headphone jack, your headphones should work when you plug it in. This is seems either software or audio circuitry related. Only two things left to do. Replacing the speaker and/or the sub_board (charging board). Both are part of the larger audio circuit.
这个答案有帮助吗?
得分 0
添加一条评论
i can't hear sound
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ira Andespa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 90
