跳转到主内容
A 250GB 3.5" SATA Hard Drive released by Western Digital.
4 个问题 查看全部
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
完成的
添加一条评论
2个答案
最有帮助的答案
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Hitachi GST Deskstar HDS721010CLA332 Hard Drive Controller Replacement
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
在已经存在的问题里加入图片
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Hitachi GST Deskstar HDS721010CLA332 Hard Drive Controller图片
指南
难度:
中等
20 minutes
这个答案有帮助吗?
得分 1
添加一条评论
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Khushal Dhumane 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 74
过去 30 天: 357
总计 1,504
