跳转到主内容
Why is my power adapter overheating?
When I open my phone it tells me the device is overheating and it shuts down
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
abdelhabibtouil you are not telling us what is overheating, or is it just saying it is overheating. If your power adapter is truly overheating, replace the battery and the charging port (daughter board). If it is not overheating, but your phone says it is, replace the battery too. Something like this video will assist you doing this. The part you need to replace, looks like this
这个答案有帮助吗?
得分 1
2条评论:
My phone fell and when I turned it on, it says that the temperature is high and it turns off, but there is no overheating
完成的
@abdelhabibtouil those temp messages usually come from the battery. Since this happens after your phone dropped, I would disassemble it and take a good look at all the connections etc. Check for any damage. Yes, I like to replace the battery in case like this.
完成的
添加一条评论
添加你的答案
abdelhabibtouil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 291
