跳转到主内容
Repair guides and support for the Canon Speedlite 430EX II external flash assembly.
11 个问题 查看全部
Tried everything but it still won’t turn on
So it does not turn on. Tried everything but it still won’t turn on, I tried cleaning it but it still looks like this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@evaneng did you use IPA to clean it or something else as you might be left with (Possibly permanently) corroded contacts
完成的
添加一条评论
1个答案
最有帮助的答案
@evaneng since those were alkaline batteries the nickel on those contacts has been causticaly etched away. Use a long cotton applicator and mix some white vinegar and sterile water (about a 50/50 mix) and use the applicator to clean of more of the residue. It will not be shiney but will from now on continue to be rather dull looking. That is okay, for as long as you keep it from getting worse. After cleaning it with vinegar/water, use some high grade isopropyl alcohol to clean that off. Then apply some dielectric grease to those contracts. Nothing layered on just a fine coat will do.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Evan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 394
