跳转到主内容
Released March, 2016. Identified by model number: 15-cd040wm
Help with Laptop Keyboard Replacement
I'm having trouble finding a replacement for my laptop's keyboard. All the keyboards I've found have a similar ribbon cable but seem to have more connections than the one installed in my laptop.
The ribbon cable for my laptop
The ribbon cable of the keyboards I found online | Image 2
Do the extra connections mean that the keyboard won't be compatible with my laptop even though the ribbon cables plug into the motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Update: I ended up buying that replacement keyboard because it was that or throwing out a otherwise functional laptop. And the keyboard and the backlight work!
I had to hot glue and tape it in because the original keyboard was attached with plastic rivets that break when you remove it. Besides that it was a pretty easy repair. I'm updating this post just in case someone else has a similar problem.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
@sidd065 looks like the connections on the ribbon cable as well as on the connector side, are all different. I would not chance it. What is the exact model of your Laptop. Maybe we can help finding out more about this.
这个答案有帮助吗?
得分 1
2条评论:
Yeah, it won't work. OP's backlit configuration is difference since the strip is split from the main wire; they need a matched replacement.
I've never tried a HP backlit KB delete because that makes zero sense as it's a dumb downgrade. I've ripped SureView out of SV notebooks and HC editions with bad screens, so I know that works.
完成的
@oldturkey03 It is a HP Pavilion Power 15-cb004na. Its an older laptop with a confusing name so finding replacement parts is rather difficult.
完成的
添加一条评论
添加你的答案
Sidd065 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 482
