跳转到主内容
An Acer Aspire 5100 Laptop with a 15.4" inch display.
20 个问题 查看全部
Can I replace the ATI Radeon Xpress 1100 with something better?
So I wanna replace the ATI Radeon Xpress 1100 in my Acer Aspire 5100 to increase the performance in it as Windows Vista says it’s pretty good except for the ATI Radeon 1100 performance which it rates as only 2.1, anyone know how or if i could?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi Valoris,
It is not really worth doing it for a laptop that old. The hard drive has an IDE/PATA interface so upgrading to an SSD drive is not really an option. Is your RAM the maximum 4GB? If yes that’s it . If no then you could upgrade. That’s about it.
这个答案有帮助吗?
得分 1
1条评论:
More info regarding RAM upgrade:
https://www.compuram.biz/memory/acer/not...
A SSD drive could make a difference. If drive is SATA then definitely yes but if PATA (IDE) then only maybe.
完成的
添加一条评论
Valoris Akosos this is a late answer used just for clarification. The video card on your computer is integrated into the motherboard. You can’t upgrade the card It is actually a chipset on your board). At this time you are stuck with what you have.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Valoris Akoso 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 116
