跳转到主内容
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
How to install chinese language in n8?
i got a n8 and it cannot show chinese language,how can i install myself?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
how to install chinese language in Nokia N8
完成的
check out old turkey's answer.. if you want more help then you should start your own question.
完成的
添加一条评论
1个答案
已选择的解决方案
You can check and see what language are available to you by
Select Menu > Settings and Phone > Language .
Change the device language
Select Phone language.
Change the writing language
Select Writing language.
Activate predictive text input
Select Predictive text.
If you do not have Chinese in the option, then you need to have the language pack containing Chinese installed at your local Nokia Care Point. Problem is that you will lose this language pack everytime you update the firmware. The phone will always revert back to its original language pack.
Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Suettheng 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 4,044
