跳转到主内容
第五代iPad,2017年3月发布。可在Wi-Fi和LTE中使用32和128 GB存储。具有9.7“视网膜显示器和64位A9处理器”。
20 个问题 查看全部
How difficult is the screen replacement
So I have an Ipad 5th Gen. Model A1822. My son tossed it across the room the other day, and the screen shattered. Gotta love 2 year olds right. Any who, I have some experience in dealing with electronics hardware, although I doubt anything as small as the hardware inside an Ipad. How difficult is it to replace a screen that has been shattered. I have read the guide, and watched videos, I did not see anything that I do not think I could do, but as often is the case, I worry that these guides and videos are making things look substantially easier than they are. So, is this something that the average joe can accomplish?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
No doubt guides are often making things easier than they are..replacing screen will take lots of time and patience especially for removing perfectly the old adhesive..that’s of the essence to get good and long lasting results and avoid digitizer issues. Besides that, the guide @sammyz linked for you includes all you have to know to do a great job :)
这个答案有帮助吗?
得分 5
添加一条评论
Since you have experience in dealing with electronics, you are more than capable of replacing digitizer yourself, make sure you have the right tools to start with.
But first, take time to read this detailed guideline written by @refectio (scroll down to solution):
After doing my repairs (battery and screen) I have problems
这个答案有帮助吗?
得分 2
3条评论:
iPad 5 Screen Digitizer
This kit says it comes with a new screen with adhesive strips, do I still need to buy better adhesive or are the ones that come with it of good quality?
完成的
@dethnode Since this kit is sold by iFixit, I assume it will come with Tesa 61395 adhesive strips which is currently the best on the market, you don't need to buy any others.
完成的
IMHO, if it doesn't say Tesa Tape, I would assume it is not. A quick call to iFixit Customer Support would clarify that however.
As for the OP's concern about guides making things look easy... I have to say that the guides are very good in general, especially those written by the iFixit staff. The only knock I would have is that they don't really cover re-assembly other than to say "reverse the steps". That works pretty well with iPhones but it is not the case with iPads (which is why I detailed my linked answer).
完成的
添加一条评论
添加你的答案
john doe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 35
总计 960
