跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Why is my battery red?
So the night before I was using my laptop watching netflix and fell asleep so it drained. I comeback charged it and turn it on and now it shows 100 percent charge which i know is false. My charger light is green and not showing orange. And I have red battery icon as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Lets do a SMC reset before doing anything else: How to reset the System Management Controller (SMC) on your Mac
Where did you get your battery? As this is not the original battery your system came with.
完成的
添加一条评论
1个答案
Ick. It’s time for a new battery. Your full charge capacity is WAY lower then the design capacity.
2013早期 MacBook Pro 15'' Retina 显示屏电池更换
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Update (11/05/2018)
Do a SMC reset first, then if nothing changes after that replace the battery.
如何重置Mac笔记本电脑上的SMC、PRAM和NVRAM
Replace a 8680 mAh battery compatible with MacBook Pro 15" Retina Mid 2012 to Early 2013 A1398 model laptops. 11.26 Volts (V). 99 Wh (Watt Hours). Battery model A1417.图片
产品
$79.99
MacBook Pro 15" Retina Display Early 2013 电池图片
指南
难度:
困难
1 - 2 hours
Mac Laptop图片
指南
难度:
非常容易
1 minute
这个答案有帮助吗?
得分 0
6条评论:
New battery? Look at the Coconut Battery report on the manufacture date.
完成的
@mayer You’re right, but look at the full charge capacity versus the design capacity. Let’s wait and see what a SMC reset does to this matter,
完成的
@ajcooke01 - Lets first see if resetting SMC alters things.
完成的
@ajcooke01 I had a customer with a similar problem because he had bought a really cheap knock off battery that even weighed less than half of the original.
完成的
@mayer thats indeed a red flag. Let’s see if a SMC reset does the trick for this one.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
raider7 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,639
