简介
使用本指南可以借助iFixit电池更换套件从MacBook Pro中安全地取下胶合电池。套件中的粘合剂去除剂将溶解胶合电池的粘合剂,使你可以轻松地将其取下。
iFixit粘合剂去除剂非常易燃。 请在通风良好的地方执行此程序。在此过程中,请勿在明火附近吸烟或工作。
为了你的安全,请在开始此程序之前耗尽MacBook Pro的电池。 如果不小心刺破,充电的锂离子电池会产生危险且无法控制的火灾。如果你的电池鼓包,请采取额外措施.
注意:如果与塑料扬声器箱体接触,用于溶解电池粘合剂的溶剂会损坏扬声器。本指南将指示你在去除电池之前取下扬声器。
如果您使用旧版 iFixit 粘合剂去除剂,即单独的瓶子和注射器(不再销售),点击这里使用稍微不同的指南。
你所需要的
使用撬棒扁平的一端,将 I/O 板连接器从主板上的插座中直接撬出。
以类似的方式,从 I/O 板上的插槽中卸下 I/O 板排线。
从 MacBook Pro 上拔下 I/O 板电缆。
请按逆序重组你的设备。
请按逆序重组你的设备。
150等其他人完成本指南。
由衷感谢以下译者:
75%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
58条评论
Going straight for the battery will work, but the solvent will leave cosmetic damage if it touches your speakers (and maybe more than cosmetic damage if there's enough of it). It's pretty tough to get the solvent only under the battery while the speakers are still installed. Removing the logic board allows you to then remove the speakers, and at that point you have a nice clear path to the battery.
Note: Early 2013 Retina Macbook Pro TRACKPAD REPLACEMENT INSTRUCTIONS.
IFixit only has instructions for the 13” early 2013 retina trackpad, not the 15” and they are quite different. You have to remove the battery to replace the trackpad in the 15” retina.
When you remove the battery, you see a brown plate covering the trackpad and a single screw. Do not mess with the screw - that’s just the click adjustment. Simply pry off the plate with the spludger. Then you’ll see six tiny phillips silver screws - undo all of them and then push the touchpad plate out. It was pretty easy to put the new one back in. Then finally test the trackpad clickiness on the corners and middle and adjust the screw until it “feels right”
I found something that works well loosening that glue. Cyanoacrylate UN-CURE. The stuff used to un-glue crazy glue. Readily available on line. Works very fast - <5mins. It’s somewhat scary in that - who knows what it will do if you get it on the speakers - or the motherboard, if you try to replace the battery without removing it (as I did). But the combination of the UN-CURE and a plastic spudger - and I had the battery(ies) out in about 10 mins. No ill effects. I used regular 91% Isopropyl to get the residue off the case and the plate covering the trackpad because I didn’t want to spread that UN-CURE around, wantonly. Alcohol works - but not nearly as well as UN-CURE. Probably safer.
