跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
Home button only works long press
My home button only works when long press to reset iPad so holding down the power button and home button together to do a hard reset but once on the home screen the home button will not work? Any ideas
many thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Any history about this iPad ? Description points lo a logic board issue..
完成的
Hi
yes the screen was changed and the finger id works but not the home button but also if you try another working home button it still does not work
完成的
添加一条评论
1个答案
已选择的解决方案
If you changed the screen yourself, then you’ll need to open it up and closely inspect the Home Button flex. Look for any tears along the flex or a kink due to an incorrect bending of the flex. The other possibility is that the connector on the logic was damaged.
这个答案有帮助吗?
得分 2
2条评论:
Can’t be the flex as tried another working flex and home button still does not work and I was careful slotting the flex back in to connection
完成的
It is likely a logic board issue, although button is one the two functions rely on different circuits and once you rule out bad connector or a bad flex there's nothing else left I could think of. I had a similar issue not long ago with a customer's iPad Air, but it had signs of previous repair attempt with melted plastics.
完成的
添加一条评论
添加你的答案
Arran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 163
