简介
按照本指南中的步骤更换iPad 5 Wi-Fi 版中的Home 键组件。
请注意,Home 键中的Touch ID 传感器与其各自的逻辑主板配对,因此更换Home 键将导致Touch ID 功能失效。
工具
移除前面板组件
如果您的新屏幕遇到“幽灵”或“幻影”触摸输入问题,可以通过在面板背面的标注区域粘贴一层非常薄的绝缘胶带,例如Kapton (聚酰亚胺)胶带,来解决这个问题。 iFixit面板具有良好的绝缘性,不需要粘贴任何胶带。
要重新组装您的设备,请逆序执行这些步骤。
22等其他人完成本指南。
特别感谢这些译者︰
90%
DorothyB正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
13条评论
Hi. What happens if home button cable is broken? Can i use a home button from an ipad air 1?
The iPad 5 home button bracket that you order seems to be different from the original one I took off the iPad. Has anyone else noticed this? I also can’t get the button to work correctly with the new bracket.
yes i just ran across this. If seems the ones that come pre equipped are different. when attached i could not get it to respond back to home.. Touch id i get but no return to home im stumped on. ivfe just purchased the replacement home button to find that it seems a bit off aswell. The rear holding bracket doesnt seem to press against the button allowing you to push it back thru from the front of the ipad. I will update further once i complete this job. BR
