Home button only works long press
My home button only works when long press to reset iPad so holding down the power button and home button together to do a hard reset but once on the home screen the home button will not work? Any ideas
many thanks
If you changed the screen yourself, then you’ll need to open it up and closely inspect the Home Button flex. Look for any tears along the flex or a kink due to an incorrect bending of the flex. The other possibility is that the connector on the logic was damaged.
这个答案有帮助吗?
Can’t be the flex as tried another working flex and home button still does not work and I was careful slotting the flex back in to connection
It is likely a logic board issue, although button is one the two functions rely on different circuits and once you rule out bad connector or a bad flex there's nothing else left I could think of. I had a similar issue not long ago with a customer's iPad Air, but it had signs of previous repair attempt with melted plastics.
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 164
2条评论
Any history about this iPad ? Description points lo a logic board issue..
由 arbaman 完成的
Hi
yes the screen was changed and the finger id works but not the home button but also if you try another working home button it still does not work
由 Arran 完成的
