跳转到主内容
Repair and troubleshooting information for the ASUS Flip C100P Chromebook. Released in 2012.
Cracked screen making it hard to use.
I have a pretty big crack in my screen....no dead pixels, but it's making the touch screen go crazy. I can hardly use the chromebook even in laptop mode because the screen will flicker and open random things as if someone is going crazy on the touchscreen.
I looked into ordering the screen repair kit but found it was almost as expensive as a new chromebook. So my question is, is there a way I can just disable the touchscreen function? I don't mind only using it in laptop mode.
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
steph fxe this should work for you
First go here: chrome://flags/#ash-debug-shortcuts and enable the flag, then click RESTART NOW at the bottom of that page.
Once that's done, you have two new keyboard shortcut toggles available to you -
Toggle touch screen on/off: --> Search+Shift+T Toggle touchpad on/off: --> Search+Shift+P
WARNING - use of this feature may cause unwary users to think their touchpad or touchscreen is defective. There are no status indicators to tell you that you have turned the touch device off!
这个答案有帮助吗?
得分 4
2条评论:
Alright! thanks so much, I never would have figured that out by myself. You just saved me a bunch of money, awesome.
完成的
Thank you so much! Same problem, thought I would have to buy a whole new computer since repairs are hardly a different price.
Mine is a chrome pixelbook and just a tiny crack in the bottom left of the screen but caused massive glitching. Again, tysm!!
完成的
添加一条评论
添加你的答案
steph fxe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 2,311
