跳转到主内容
Toyota's 7th generation pickup, but first generation of the Tacoma branded truck designed specifically for the American market. Featured brand new sheet metal, new frame, fresh suspension and three new powerful engines.
Left high beam malfunction
My left high beam does not work on my 1996 Toyota Tacoma even with new lamp and relay. Solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks, will look into it☺
完成的
添加一条评论
1个答案
已选择的解决方案
@hannibal316 check the socket and see if you have power coming to it when you turn your Hi-beams on. If you lamp is new and the relay is new you are most likely having an issue with the socket/wiring.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Hannibal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 134
