Left high beam malfunction
My left high beam does not work on my 1996 Toyota Tacoma even with new lamp and relay. Solution?
@hannibal316 check the socket and see if you have power coming to it when you turn your Hi-beams on. If you lamp is new and the relay is new you are most likely having an issue with the socket/wiring.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 98
1条评论
Thanks, will look into it☺
由 Hannibal 完成的
