跳转到主内容
Apple Watch Series 2, announced September 7th, 2016 and released September 16 2016.
20 个问题 查看全部
Digital Crown no longer works
My Apple Watch 2 started to act funny, it would launch siri and scroll between apps all by itself.
It was acting as if the digital crown was being pressed in and rotated.
I tried the usual cleaning methods as per the apple website but without any luck.
It does rotate freely and doesn't feel sticky at all, and although it does these things it is completely unresponsive.
I have to use the the side button to navigate my way round the watch the best I can.
Does anyone have any Ideas?
Many Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
11条评论
I am facing same problem i just want to know is this not because of update i having series one and watch were upgrde 5.2.1
完成的
I contacted apple about this and they said I needed to clean the Digital Crown in warm water. When in the water turn and press de crown a few times.
完成的
is here a place to buy anything that includes these in a part? my 2nd gen is doing the same thing, however mine only started after version 5 was released.
完成的
Same here, afther last update looks like the watch is living its own life. Activating siri out off the blue and unresponsive when pushing the crown..
完成的
Time to visit an Apple Store to get your watch repaired.
完成的
显示更多的6条评论
添加一条评论
1个答案
最有帮助的答案
The digital crown uses a set of detectors that note the rotation. It sounds like the detectors have failed. You can see them here in the Teardown: Apple Watch Series 2拆解 in Step13.
Given how far you need to get I would just let Apple deal with it. They at least have a flat fee for the repairs.
这个答案有帮助吗?
得分 1
7条评论:
Thanks for the reply, I am out of warranty (by one month) and its seems like a high price, I'd rather spend a bit extra and get the series 3
完成的
Its still cheaper ;-} Apple Watch Pricing
完成的
I went to Apple for the same problem and they wanted to charge me $229 to fix it. The new models are $249.
完成的
@scooba4 - Agreed! Its on the high side given the cost of a new watch (cheapest model). Its when you get to the stainless steel or Ceramic cases it becomes less of a bite.
完成的
@danj you think there might be a "Flat Rate Repair" price direct from Apple?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
casey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 21
总计 16,596
