How can I synch my contacts and calendar from my iPhone
Just got HD10, great so far. Have all my contacts and calendar on my iPhone and want to sync them across to HD. Any ideas outthere please
Go to http://www.icloud.com, if you sync to the iCloud, then you go to that web address, and export your calendar and contact files.
Then you can either email them to yourself or manually transfer them to the file system of the HD 10. When you do so, use your calendar and contacts apps to import the respective files.
这个答案有帮助吗?
This worked great so thanks. The only problem I ran into was not knowing what directory to place the csv file on. I had to place a copy of it on all internal and sdcard directories. What's the correct directory.
@chs117 besides the excellent answer by @avanteguarde you can also use App's like CardDAV and CalDAV to simplify this.
这个答案有帮助吗?
The solution suggested by SW did not work for me. Error when tryi g to open link on my Kindle Fire
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 5,326
