跳转到主内容
加入维修社区 - 创建账户
Toro 公司生产的手推式割草机的维修信息与支持。
Why is the engine over revving?
With the engine running the governor doesn't seem to be controlling the engine rpm's and over-speeding. Throttle control cable doesn't seem to be controlling the engine
speed whatsoever.
Thanks, Tom of Indy.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
What model is your mower? Is it ride on?
完成的
tjcox6841 anything related to engine adjustments etc. will be in the Tecumseh manual. Let us know if you can find any model number or other indicator on the engine.
My cross reference shows that your mower should have a Tecumseh TVS840-8014B
完成的
添加一条评论
2个答案
已选择的解决方案
tjcox6841, Tom, You did not state your engine or model #, so I will post some what generic answer. Sounds like the governor linkage may be stuck, broken linkage/spring. Look for dirt/debri around the governor linkage and wash/brush/blow any debri from linkage and ensure linkage mechanism is intact and hooked up and throttle cable is still hooked up and not broken/seized on. Links below may be of some assistance. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=shgawgDT...
http://www.hobbytalk.com/bbs1/110-small-...
https://www.youtube.com/watch?v=EVIZtyw3...
https://www.google.ca/search?q=tecumseh+...
这个答案有帮助吗?
得分 6
9条评论:
Toro Model #26551 tecumseh two cycle engine.
完成的
Governor linkage is free ,however I believe the adjustment may have been changed.
完成的
@pccheese when you vote an answer down, it polite to state why you did it. Why did you vote this down?
完成的
@mayer Oh, pure accident. I ment to vote it up.
完成的
@mayer , @pccheese Thanks, I was scratching my head on this!
完成的
显示更多的4条评论
添加一条评论
tjcox6841 here is the description from the manual for the TVS series engine. Let us know if this looks like what your engine uses. If so, I can probably provide you with the rest of the manual, but cannot post it due to size limitation. Post some images of your engine, your carb and your governor linkage etc. Use this guide to do so. This will allow us to see what you see.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
tjcox6841 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 26
总计 53,882
