跳转到主内容
加入维修社区 - 创建账户
Nintendo DSi 是 Nintendo DS 产品线的第三款迭代机型,于2008年底在日本市场发布。
How to fix dsi troubleshooting
when i turn my dsi everything looks good but as soon as i press on one of the icons displaced on the screen it says "an error has occurred.press and hold the power button to turn the system off.please see the nintendo dsi manual for help troubleshooting." when i turn it back on it keeps doing it no matter how many times i do it. i hope you can help me with my problem. thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 82
38条评论
my DSi has the same problem and same response I looked on Youtube and it said it was because of the wireless thing inside the ds and u have to take it out but I didn't watch the rest of the video because there was a problem with that. I have a Hello Kitty sticker/skin on it, and I can't take it off because I've had it on there for years
由完成的
the same thing with mine but i have a case that i can't take off so i can't fix my dsi at all. the video i watched showed that u have to take out the wireless thing also. sometimes i leave it for 1 day without turning it on and it works again
由完成的
i can't update it or else nothin will work
由完成的
my ds is a japanese version so i can't fix it properly but when my uncle said something was deleted
由完成的
I have this problem too! I load up my DSI XL with my R4I in and load up my R4 and it says: "an error has occurred. press and the power button to turn the system off. please see nintendo dsi operations manual for help troubleshooting"
please please help me and tell me how to fix it because i have 999 on there :(
由完成的
显示更多的33条评论
添加一条评论
11个答案
最有帮助的答案
http://www.nintendo.com/consumer/downloa... for the manual. Just in case you should want to follow what it says and look it up:) Did you do a recent update on it? Just asking because newer DSi firmware blocks out third-party devices like the Action Replay or flash carts. You have to check the Action Replay website to see if there's any firmware update for the AR to bypass. BTW are you using something like Acekard? http://www.dsihacker.com/acekard-2i.php So let us know how it is going and if you need further help. Give us all your info so that we can find a solution to this....Good Luck
这个答案有帮助吗?
得分 6
1条评论:
Buddy, I bought a Nintendo dsi prefix without checking it, it also gives this error, I don’t use the cartridge, only an 8GB memory card, don’t run the application, you can climb the menu, the error appears if Any application on the console. Please help, what needs to be done to make the console work normally?
由完成的
添加一条评论
only for acekard2i
Updated Your DSi to 1.4, Acekard 2i doesn’t work, A Guide to Fix It
Posted on : 28-09-2009 | By : Blueearthdigital | In : Uncategorized
22
So yep, you’ve updated your DSi to 1.4 and your Acekard 2i doen’t work. We can fix it. But be warned in the Highly, Highly, Highly Unlikely event of buggering up your Acekard 2i or the DS I will not be held responsible and proceed at own risk. If you do stuff it up I have One fix(from self experience).
1. Download this File, I did not create this file and I don’t know who did (Click Here) file from http://www.ndscardshop.co.uk/
2. Put these files on the Micro SD Card for your Acekard 2i.
3. If you have already updated your DSi to 1.4, your going to need an Original DS or a DS Lite and put the Acekard 2i in that, If you haven’t just put it in your DSi
4. If your using a Original DS or DS Lite, Go to Acekard 2i and browse to where you put the Files, your going to need to open the one entitled “ak2ifw_update_14_DSL.nds”, If your using a DSi open the Acekard 2i and browse to where you put the files, open the titled “ak2ifw_update_14_DSi.nds”
5. It will tell you to re-instert The Acekard 2i, so do that, It should tell you to press B then so do that, then it should ask you to press start so do it, now it will be changing how the DSi will recognize the Acekard 2i, Now DO NOT PRESS THE POWER BUTTON OR YOU WILL BRICK THE Acekard 2i. After it finishes it should tell you to power off the DS. Now Your Acekard 2i had been fixed! YAY!!
Holy Crap I’ve Bricked My Acekard 2i by pressing The Power Button while it tells you not to. What do I do?
(Here’s the Solution)
1. Your going to need a DS Lite or Original DS with any Flash Cart.
2. Put the Update file called “ak2ifw_update_14_DSL.nds” on The Flash Cart of any Sort.
3. Open the Update file you put on your Flash Cart.
4. When it Tell’s you to re-insert the Acekard 2i, take out the Flash Cart and insert the Bricked Acekard 2i(with update file)
5. Then Follow the Steps
6. Once it’s finished you’ve Un-Bricked The Acekard2i
这个答案有帮助吗?
得分 4
3条评论:
you are right
由完成的
can you make this easier
由完成的
i've done the update on the DS lite then tried the card on my dsi and it still says an error has occured
由完成的
添加一条评论
I have had this problem and have fixed it by replacing the wifi board, which is real easy, and there are instructions on this site.
Nintendo Handheld Game Console
You should carefully remove the back and check to see if the wifi board is still attached. They usually only come loose if they fall or are banged around.
这个答案有帮助吗?
得分 4
5条评论:
Thanks you man
由完成的
I am pretty sure the Wifi board in your system, has either disconnected from the motherboard or is damaged and will not turn on.
This is very easy to check, just remove the back cover and the Wifi board is visible right away.
由完成的
You need a new wifi chip, the same happened to mine, its cheaper to buy the chip then take it to a shop like best buy or something, if you directly take it to the shop, you will get charged for the service and the chip, so buy the chip yourself. I ended paying $20 instead of $200 so i saved a lot if money.
由完成的
Late reply by all accounts, but was searching for this very problem and the fix was the WIFI card was loose, so thanks for signposting the way!
由完成的
I fixed my problem by holding down all of the buttons, the L button the r button select and start and the power button unti it reset self
由完成的
添加一条评论
Definitively the main cause for this error is the wifi card:
- Reason 1: Wifi card is loose > You will need to put it back in place
- Reason 2: Wifi card is damage > Only way to fix it is to replace with a new one.
This issue is not related to R4 flash cards, firmware or updates.
Regards,
Juan
这个答案有帮助吗?
得分 4
1条评论:
its not the wifi card i took one from a working dsi to mine with the code and it didnt help and i put mine in the good dsi and nope still works fine
由完成的
添加一条评论
before replacing the card, try and push on the back of the DSi approx. where the wifi card is. If that doesn't work. open the DSi case then disconnect and re-seat the wifi card. That ended up working for me. I guess the connector was a little loose. The connector doesn't really have any kind of grab, it is just seated so the regular jostling that a portable game system goes through will eventually unseat it.
这个答案有帮助吗?
得分 1
添加一条评论
As a temporary fix....If you just want to be able to play your Ds games after receiving this error...Just power on the DS...then go to settings...then turn OFF the WiFi option. (The wifi light will go off) You won't be able to take full advantage of some of the other modes that rely on wifi on the Dsi but...you will be able to play your games again without opening up the back hardware of the device. -2F™
这个答案有帮助吗?
得分 1
2条评论:
Just tried that it worked, then I turned wifi on, 20 minutes later, still working, thank you!!
由完成的
my code comes on when you open any app, so this doesnt help me :(
由完成的
添加一条评论
if this error happens when you click on any icon even the settings then you ds has a faulty motherboard fullstop
Update (12/24/16)
blck screens white screen multicolour line your graphic card has gone or the screen connections are damaged (they are very flimsy tiny wires usually only happens when someone opens the screws and takes back off without knowing what they are doing
这个答案有帮助吗?
得分 1
添加一条评论
When you turn on the ds, a photo appears on top, if you click to activate the camera, it will appear, Dsi Camera, you press, and go to the photo gallery, after a few seconds, turn off the ds and you will be able to open the programs .
这个答案有帮助吗?
得分 0
添加一条评论
I tried this out https://youtu.be/MTwmlIZ5YiE it works and it doesn't change the data on the dsi
这个答案有帮助吗?
得分 0
添加一条评论
I need to fix it so I can play games on it and how do I get new games I am a kid
Can you please give me sharks in the how to fix this
这个答案有帮助吗?
得分 0
2条评论:
@annharris we will need to know exactly what is wrong with it. What does or does it not do?
@dan0 is our game console guru and I am certain he'll help you out.
由完成的
Hi!
Yes, what is going on with the DS? Thank you!
由完成的
添加一条评论
This error usually happens due to corrupted system data, a faulty SD card, or a bad app/icon. First, power off your DSi completely, remove the SD card, and turn it on again. Try opening icons without the SD card inserted—if it works, back up and reformat the SD card or replace it. If the issue happens even without an SD card, hold A + B + X + Y while powering on to access the maintenance mode and reset settings. Also ensure the battery is seated properly. If nothing helps, the system firmware may be damaged—professional repair is required.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
manuel 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 47
过去 30 天: 200
总计 147,401
