跳转到主内容
加入维修社区 - 创建账户
AM3 插孔于 2009 年 2 月发布,是适用于具有 941 个针脚触点的 AMD 处理器的 CPU 插孔。
Monitor not displaying anything because of CPU
My monitor is not displaying anything on screen. There is no fault in monitor, the fault is in the CPU processor, as I already checked my processor on other motherboard, my question is can i repair my processor. There is no damage as I can see on processor. It is clean.
AMD FX-8150.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
How do you know it isn't the GPU or video card? What's it in? What does it do? If the CPU works in another machine, it's obviously not the CPU giving the problem, is it? What does an external monitor show?
由完成的
If your processor has no damage ,
if the possible solution is clean your RAM before connect on-board or replace
由完成的
How do I fix my cpu on my computer
由完成的
CPU's can NOT be repaired.
由完成的
添加一条评论
4个答案
已选择的解决方案
mohityenugwar there is nothing you can do. If your processor has failed the only way to get things working, is by replacing the processor.
这个答案有帮助吗?
得分 8
添加一条评论
There is no realistic way to repair a processor itself. The only viable solution is to replace it. You should be able to find used Phenom x2/3/4s fairly cheap online.
Update (01/17/2017)
Also, most AMD FX series processors do not include integrated video capabilities. These CPUs were designed for gaming systems with dedicated graphics cards. There is a possibility there is, in fact, nothing wrong with the processor.
这个答案有帮助吗?
得分 1
1条评论:
Re-read the question ". . . I already checked my processor on other motherboard. . . "
由完成的
添加一条评论
U can change d processor can't b repair
这个答案有帮助吗?
得分 1
添加一条评论
It could also be the motherboard. Try the CPU on a different motherboard and see whether you get anything. Vice versa, you could also try a different CPU on the same motherboard. My guess is that most of the time, it's the motherboard.
这个答案有帮助吗?
得分 1
1条评论:
由完成的
添加一条评论
添加你的答案
mohityenugwar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 42
总计 4,049
