跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
707 个问题 查看全部
Why the power connector is overheating?
Hi currently the power connector of the MagSafe 2 charger turns very hot in a few of seconds, if elapses more than two minutes then it burns my fingers. This happens on charging and on full charge too
Thanks for your answers
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
4条评论
Is the Magsafe plugged directly on the wall socket or a into a surge protector bar?
完成的
Also if you have any less than a 85 what charger it will over heat very easily with this computer
完成的
Mine is plugged in surge protector bar and getting very hot after 20-30min.
完成的
Call Apple themseleves and let them know, each apple Mac comes with a 3 year limited warranty, if they won't do anything ask to speak to a senior advisor, if they still does not work ask for a one time repair exception and if nothing please take it another place either certifed for Apple repair or not, I suggest certiefed because I am Apple Repair certifed and this sounds like a hardware failure and you can take it to a local Apple Store and tell them, more than likely we will run some tests and either replace or repair the product at no cost at all, if you have any other questions, don't be afraid to contact me.
完成的
添加一条评论
6个答案
最有帮助的答案
Your device is still under warranty. Before you do ANYTHING to repair this machine or it's components, internal or external... Call Apple. They will replace anything that is not operating properly that is no fault of yours, but a fault of the equipment.
这个答案有帮助吗?
得分 2
1条评论:
I totally agree with Brandon on this one. After you get it back, it you see a hint of a problem, take out the Extended Apple Care for an additional two years of warranty.
完成的
添加一条评论
I have this problem too. When I got this problem I searched about this and saw many users had this issue. Seems like Apple doesn't care about their faulty charger. I doubt that do they really have a proper engineering team to fix this issue . I felt bad now being a mac user first time by seeing this issue persisting for a very long period of time.
Extending warranty doesn't make sense if you get the same designed charger again, because anyways its going to get the same issue in few days.
这个答案有帮助吗?
得分 2
3条评论:
Rajkumar,
We have 100's of these chargers in use without any issues do to a poorly designed charger.
What we do see is people wrapping the cords into a knot and then expect the dam thing to work! We glued down the butterflies and put instead a velcro wire wrap and trained out employees to loosely coil the cord.
The other thing we do is make sure the site offices have UPS's so the power is clean and they all have small surge suppressors for the road.
Just to be clear here these same issues are present on every laptop made! From Dell & HP I've seen them fail in the same way - User error!
完成的
Ok, if it is user error, please tell me what to do now. A new Apple 85W MagSafe 2 Power Adapter lists for $79. This is my second MagSafe 2 adapter. I replaced the first one because the cord basically unraveled (I was told by the apple repair guy that I was the cause of the cord unraveling because I disconnected the charger by tugging the cord). I did not note the connection getting warm. This new adapter was quite warm from the beginning but I still could touch it. Now it gets so hot I can not touch the connector! I do not want to revisit cord unraveling so when the charge is complete, I flick the connector with my finger! I frequently clean the magnet because it collects up tiny flakes of metal that prevent any connection. I notice that two of the five connection points have darkened. The gold plating is still there, just under the dark crusty looking stuff. What can I do short of buying a new adapter? BTW, at this point, warrantee is not available and I always use a good surge suppressor.
完成的
@scyghost7 - You may need a new DC-In Board What is your exact model?
Also there are many fake MagSafe chargers now flooding the market! So make sure you do get a real one! Best to go to an Apple Store or authorized reseller. The cord issue was one of the tell-tale signs of a fake charger!
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth. Review the vid showing the difference of the reaction of the MagSafe LED.
完成的
添加一条评论
I found a probable cause and solution! Once I was sure there was no warrantee in affect
The over heating seems to come from the MagSafe connection shorting out due to corrosion build up. I used a hard plastic picker to remove as much of the corrosion as possible.
Also, I took small pieces of tape and pressed them into the recessed area to remove small pieces of metal that had begun to collect to the magnet preventing a tight connection of the electrical points.
When I was no longer able to get good clean points, I found just the MagSafe connector and cord on Amazon for about 10% of the original price!
I used but joint crimp connectors and shrink tubes to assemble everything! Now I keep a small piece of gaffers tape over the recessed area to keep metal bits from collecting to the magnet
这个答案有帮助吗?
得分 2
1条评论:
@scyghost7 - How about just replacing the damaged connector on the system MacBook Pro 15" Retina (Late 2013-Mid 2015) MagSafe 2 DC-In Board and here's the guide you'll need to follow MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement
Be very careful many on the chargers sold on Amazon or eBay are fakes! They can damage your system! OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Lacking safety features, cheap MacBook chargers create big sparks
完成的
添加一条评论
I bought mine refurbished. They would not send the grounding part of the cord, just the box and small diameter cord. They said they had had a problem with them heating up when used as a unit.
A couple of times I have forgotten and plugged into an extension cord (heavy duty -12g) and OUCH too hot.
Using only the square plugged into the wall & connected with the magsafe I haven't had it get overly hot.
这个答案有帮助吗?
得分 0
4条评论:
@nan_c - Check your house wiring you have a bad ground service. Get an outlet checker or call an electrician to check the outlet/s you use for your system as well as check the buildings grounding service from the breaker panel to your ground point (copper water pipe exiting, copper rods in the ground). You may have a a bad cord or motor in your house which is dumping power to ground which then comes back in your charger.
完成的
All good. It doesn't overheat if I use it as instructed. Seems that it was a MacBook pro 2015 issue (per double dex. the refirb guys)
I was just sharing my experience when I ran across this previous post. Not having a problem.
完成的
@nan_c - You're just avoiding the problem not addressing it.
完成的
Another year has gone without any problems. That is just me! Not suggesting that anyone use non apple anything! I do not use the 3 prong cord that goes to the cube. I just plug the cube- non apple (2 prong 85w) into the wall... no extensions (or it will heat up) Again, I am following the instructions of the refurb. company from which I originally purchased. Still haven't had my battery replaced either! Everything is fine.
完成的
添加一条评论
What heats up connectors? Poor connections caused by high resistance. That drops voltage and produces heat. It can be caused by corroded, loose contacts, or bad connections like bad welds or solder joints. Troubleshoot those causes.
这个答案有帮助吗?
得分 0
1条评论:
A dirty contact within the MagSafe connector is a common issue. Cleaning with a dampened Cotton swab (Q-Tip) with Isopropyl alcohol or kitchen cleaner, you may need to scrub them with a fresh pink pencil eraser.
Using a knockoff charger is the next issue. Its almost impossible to tell the real from the fakes! Make sure you only get a replacement from Apple directly. Most sold on Amazon or eBay are knockoffs (even if they tell you otherwise)!
Don't Replace Your MacBook Charger With a Cheap Knockoff
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
完成的
添加一条评论
Take it back. When you get a new one don't leave it unattended it's a possible fire hazard! But try telling Apple that! I shall be ditching all Apple products ASAP!
这个答案有帮助吗?
得分 0
1条评论:
Ray - Lets not throw the baby out with the water!
The issue is not Apple! It’s the knockoff chargers! Trust me I know. The engineering firm I was supporting had one of their staff forget their charger, he went to a local store to pickup a charger as he had a presentation in the morning.
Went back to the hotel plugged his system in and went to dinner. Came back to the sight of the fire equipment and the fire brigade in the process of dealing with a fire. He was able to get to the front desk getting informed his room is where the fire was! Them gave him another room for the night, the next morning he was able to get his now smokey cloths and his other items.
We inspected the system which wasn’t to badly burnt as it was on the desk slightly a way from the charger which was a charred mess! In the end this cheap charger cost the company a bit over 3 million!
As much as I don’t like paying the Apple tax. 3 million is way to much too risk! Only get the charger from a real Apple Store or off of Apples web site. Amazon & eBay are mostly knockoffs which will hurt your system or worse!
Check the URL’s I posted above for more details.
完成的
添加一条评论
添加你的答案
Guillermo Leon Plata Camacho 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 42
总计 12,723
