跳转到主内容
Check out these guides for information on repairing and dissembling your sewing machine.
20 个问题 查看全部
Bernina 830 service manual
Zigzag not working. Need a service manual. If anyone has one. PDF form would be great.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
I'm having trouble with the bobbin tension. Any suggestions?
完成的
Hi @nannamarg ,
This link may be of some help. See 2nd post down.
https://thequiltshow.com/forum/bernina-c...
完成的
I have just bought a nearly new but quite old Bernina Record sewing machine, but the clutch release wheel that you release to load the bobbin will not release, will it be ok to use a pair of grips to release it, or is the some other way to release it?
完成的
I filled a bobbin with thread and now the knurled screw on the hand wheel will not re tighten. Can someone help with this?
完成的
添加一条评论
3个答案
已选择的解决方案
Hey Cheryl, I found a link to the manual of your specific model here and the user manual here. The threadguide/lubricating unit pdf can be found here. You can check out the firmware details here.
-Let me know how it goes.
这个答案有帮助吗?
得分 1
3条评论:
iApple your first link and your second link are identical. Neither one of those is for the service manual
完成的
Thanks for notifying me oldturkey03, the link has been replaced with the service manual.
完成的
iApple you are funny. The first link is now the user manual, not a service manual. Big differences :-)
完成的
添加一条评论
最有帮助的答案
Cheryl, this video may help. On the bottom of this page is now a pretty good service manual about the adjustment of your sewing machine.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Cheryl,
I see it has been almost 7 yrs. since you posted this inquiry, but I have an answer for you. I joined a group called .... BTS@ groups.io ... and found all of the service manuals and user manuals as a free pdf. download. The BTS stands for Bernina Thirtysomething. I tried to send it as a link but it did not work. I sure hope this helps.
Happy sewing!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cheryl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 63
总计 18,480
