跳转到主内容
iFixit 使用 cookie 来增强网站功能、分析流量和个性化广告。使用本网站即表示您同意我们的 cookie 使用和隐私政策
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
battery showing low temperature.
Recently I had purchase samsung galaxy j1 on 30th aug 2015 & just few days back the battery showing low temperature what does it means....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
je restées charge a long temps que afficheur
完成的
添加一条评论
1个答案
已选择的解决方案
arindam bose, this is a pretty new phone and I would suggest that you have it fixed under warranty. The usual causes for this error are issues with the battery connector, failed btemp line on the circuit board, bad battery, bad charging port flex. So if I would fix it outside the warranty (bad idea) I'd start with a new charger, then a new battery, then do some fault finding on your logic board. Again, use your warranty.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
arindam bose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 1,985
