跳转到主内容
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
设备无法开机
按下电源按钮后,设备没有反应。
电池不再蓄电
如果设备在开机后立即关机,或者根本无法开机,那么电池可能已经无法充电了。如需更换新电池,请参考我们的 电池更换指南。
按键功能异常
设备无法正确识别按键操作。
按键磨损
如果按键回弹缓慢或一直卡在按压位置,可能是因为按键下方积聚了灰尘或其他小颗粒。如需清理设备正面的按键,请参考我们的 正面按键更换指南。如果需要清理设备外部的肩键(触发键),请参考我们的 背面按键更换指南。
按键无响应
如果按下按键后没有反应,则可能需要更换。如需更换设备正面的按键,请参考我们的 正面按键更换指南。如果需要更换设备外部的肩键(触发键),请参考我们的 背面按键更换指南。
摇杆(Circle Pad)功能异常
摇杆校准不当或无法工作。
摇杆不再精准
如果屏幕在摇杆处于中位时会自动滚动,则可能需要重新进行校准。如需校准摇杆,请参考 [http://|任天堂摇杆校准步骤]。
摇杆损坏
如果你的设备无法识别摇杆的输入信号,则可能需要更换。请参考我们的 摇杆更换指南。
设备开启时上屏为黑色
尽管设备已开启,但上屏并未点亮。
上屏损坏
如果设备开启时上屏依然显示为黑色,那么你的上屏很可能需要更换。如需拆解并更换屏幕,请参考我们的 上屏更换指南。
触摸屏无响应
触摸屏无法识别触控输入。
触摸屏损坏
如果触摸屏对操作没有预期的响应,或者在设备开启时显示为黑色,则可能需要更换。如需拆解并更换屏幕,请参考我们的 触摸屏更换指南。
Tim Newman
于09/25/17注册
2,075 声望
创作了4篇指南
团队
Cal Poly, Team S18-G6, Forte Fall 2017 Cal Poly, Team S18-G6, Forte Fall 2017 的会员
CPSU-FORTE-F17S18G6
5 名成员
创作了48篇指南
7条评论
New 2DS XL. touch screen was unresponsive. Took a firm piece of card, wedged it between screen and bevel with quite a bit of force, slid it all the way around couple of times. Worked!
Try it before replacing or taking apart.
B Franklin - 回复 分享
You are a genius my dude, this also worked for me, sorry for necroing this but you're the bomb.
Scott W - 回复 分享
Amiibo reader doesnt after dropping it. What do I do now?
Hamm Khan - 回复 分享
I have had a problem that my device does not seem to be loading or that the battery does not seem to hold charge. When charging, the solid red light won't turn off and when starting the device without charger attached it flashed red. I thought the battery was broken and ordered a new one, but the problem was another: the battery wasn't calibrated! YES, you can calibrate the battery. To do so, charge your device for several hours without interruption. Then detach charger and start your device. Drain the battery empty, for example by starting a game in full brightness and simply let the trailer run for several hours. When it shuts down due to drained battery, attach the charger and charge it uninterrupted for several hours until you're sure, it is completely charged. This calibrates the battery and for me the problem was gone.
dlxqdrt - 回复 分享
i have problem when my 2ds xl just turn blue and red when i put new boot.frim and boot.3dsx it still do blue and red what i do
deven stewart - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 54
过去 30 天: 189
总计 14,345
