跳转到主内容
目录
Do your JBL Charge 3 speaker’s ports no longer work? Does either charging your device, using the device as a charger, or using an audio cable not work? JBL Charge 3 speakers are susceptible to a range of problems that could cause the speaker’s port to stop working. Check the following possible causes to identify and solve the problem.
Connected Cable is Faulty
If your JBL Charge 3 speaker is not charging, you cannot use the device as a charger, or the audio cable function does not work, the problem could be the cable itself. Check that any cable you are attempting to use works with another device. Also, try using a different cable with your speaker, and see if the problem persists.
Faulty Port
If the cables are not at fault, the ports may be to blame. If one of the three ports will not work with its functioning cable, see the JBL Charge 3 Port Bay Replacement guide to replace the ports.
Questions other people have asked about this
Arielle Sampson
于07/05/20注册
16,847 声望
撰写一个指南
2条评论
Where can I take my charge three to get repaired?
george plumides - 回复
My charging port in my charge three does not work the contacts look mangled I can send a picture
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 27
总计 1,472
