跳转到主内容
你的 JBL Charge 3 音箱是否出现音质失真的情况?JBL Charge 3 音箱可能会遇到各种导致声音失真或发闷的问题。请检查以下可能的原因以查明并解决问题。
设备处于错误的音频模式
JBL Charge 3 音箱有多个音频预设,可能会被意外激活。请尝试重置音箱:开启设备,同时按住“音量加”按钮和“播放/暂停”按钮,直到电源按钮亮起。JBL 建议你在正常聆听时将音箱保持在预设模式。
电池故障
如果设备 无法充电或无法保持电量 时间过长,请考虑 更换电池。音箱在大音量下表现不佳,原因可能是 电池 损坏,而非扬声器本身的问题。
扬声器故障
如果你已确认音箱处于正确的音频模式,那么扬声器本身可能已损坏。如果长时间在大音量下播放重低音音乐,扬声器可能会损坏。请务必在较低音量下播放重低音音乐,以免损坏音箱。请使用 JBL Charge 3 扬声器更换指南 来更换设备的扬声器。
其他人关于此问题的提问
相关页面
Arielle Sampson
于07/05/20注册
17,131 声望
撰写一个指南
3条评论
Mine was accidentally dropped on its side and the speaker on one side sounds busted and it sounds crackly when bass on any song is played. if I where to replace that one speaker inside what would I need to get to do it correctly without damaging it further? And where would I be able to find an other speaker like that to replace it ?
Zeeplee - 回复 分享
For me, it was the battery. I had the problem that the box was only distortion present when loud or bass-heavy music played. Independently from this (or that's what I thought), the battery was old. The box did not last very long anymore, and when I put it on a charger, the LEDs indicated a full charge almost right away. I replaced the battery, and the distortion went away, too. I presume there was some sort of brown-out, which caused the distortion.
Axel Buß - 回复 分享
Axel, thank you for this feedback! I had a similar situation with my laptop where it was overheating and slowing down because my battery was old. I didn't think the battery could cause it to overheat but it was a simple repair and replacing it ended up fixing what I thought was 2 separate problems (1. short battery life 2.overheating and slow performance).
Evan Gattuso - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 51
过去 30 天: 212
总计 53,370
