简介
本指南说明了如何更换电池以恢复您iPhone8的性能. 如果您的电池已经鼓包, 请采取适当的预防措施.
本指南指导您完全分离显示屏部件;这是为了防止意外损坏显示屏电缆。如果您认为您可以在不过度拉紧显示屏电缆的情况下轻松取出电池,可以跳过拆卸显示屏的步骤。此外,虽然可以在打开手机后立即撕下固定电池的胶带,但本指南建议您首先拆下Taptic引擎。这样做可以降低因拆除时意外贴在Taptic引擎上或者以过大的角度拉动胶带等情况造成胶带断裂的风险
为了达到最佳电池性能,在完成本指南后 请校正 您的新电池: 充电至100%并继续充电至少2小时,将iPhone完全放电,最后一次充电至100%。
工具
拧下用于固定Taptic Engine旁边支架的三颗螺丝钉:
一个 1.3毫米的Y000型螺丝钉。
一个 2.7毫米的十字型螺丝钉。
一个 2.9毫米的十字型螺丝钉。
105等其他人完成本指南。
特别感谢这些译者︰
60%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
12条评论
I still did it in 30 minutes….but I am glad I stop repairing phones around the Iphone 6s ! Now it takes serious effors just to replace the battery !
One note on this repair: When reinstalling the standoff that connects to the Taptic Engine, I found that the pointy tip of the spudger fits really well into the little hole at the top of the standoff, and helps with getting it into place and screwing it down if you don’t have a screwdriver bit for the standoff. Hope this is helpful!
Are steps 18 to 27 really required if you’re just replacing the battery?
Hi Daniel!
The pull-stretch adhesive holding the battery has a tendency to tear when they are pulled at a steep angle. When they tear, removing the battery becomes much more difficult. We strongly recommend removing the Taptic Engine in order to give the adhesive the best chance of coming out in one piece.
Great guide and great quality of all your tools and replacement parts.
