跳转到主内容
iPhone 6s Plus Lightning 接口和耳机插口
你所需要的
  1. iPhone 6s Plus Lightning 接口和耳机插口, 五角螺丝: 步骤 1 中的图像 1,1
    • 在拆卸你的 iPhone 之前,将电池放电到电量低于 25%。如果您意外刺破一块充满电的锂离子电池,其可能会起火甚至爆炸。
    • 在你开始拆卸之前,将 iPhone 关机。
    • 拧出 Lightning 接口两侧的 2 颗 3.4 mm 五角(梅花形)螺丝。
    Make sure you use the correct screw driver tip to remove these screws, which for the iPhone 6s Plus is the P2, otherwise you may strip the tip of the screw making it 10 times harder to remove. If once the screw is lose, it will not come off, use a magnet to remove it.
    Miguel Perez - 回复
    If I do it by myself, will it damage the water resistant strip?
    I know iphone 7 have it ,but I am not sure 6s plus have it.
    Ganqian Zhu - 回复
    iPhone 6s has an adhesive gasket under the display, similar to the iPhone 7—however, it doesn’t add much in the way of waterproofing since the 6s has non-sealed openings in other parts of the phone. Water resistance on the 6s is primarily internal (seals around the logic board connectors, etc.). It may still be worthwhile to replace the adhesive on the 6s in order to help keep the display firmly seated so it doesn’t move/wobble at all under pressure, but the phone will continue to work fine whether you replace the adhesive or not.
    Jeff Suovanen -
    Salve nella procedura iniziale di smontaggio display con la ventosa non è menzionato il fatto di scaldare i lati del display per “ammorbidire” la striscia che incolla il display alla scocca.
    Non è necessaria la cosa o è consigliabile ?
    grazie
    Hello, in the initial disassembling procedure with the suction cup, it is not mentioned how to heat the sides of the display to "soften" the strip that glues the display to the body.
    Is not the thing necessary or is it advisable?
    thank you
    Daniele - 回复
    You’ve probably received your answer by now but for future enquirers, it does help the process of taking the screen off if heat is applied to the screen. If you have a hair Dryer use that on a low setting to heat the edges of the screen until it’s almost too hot to touch then slip very thin metal spudger around the edge to cut the adhesive. The carefully lift the screen with the help of the spudger and continue with your repair
    Cheers Wayne
    Wayne Lyell -
    How do I know that the Battery has ZERO Charging Cycles on it when it arrives ? Is there a (downside) to Higher Capacity batteries ? It is INCREDIBLY DIFFICULT to maintain a “Zero Chinese Products Lifestyle”, so how do I know that I’m not getting a deficient Chinese battery, potentially a refurb. battery ?
    integritybuilders - 回复
    When your repair is complete, you can use coconutBattery to check your new battery stats and cycle count. (A properly tested battery may already have a charge cycle or two on it.) Avoid higher capacity batteries on iPhones—they’re generally either gimmicks, unsafe, or both. As far as the quality of the part, that comes down to how much you trust your supplier and whether they guarantee the product.
    Jeff Suovanen -
    So I need to empty the battery to zero percent?
    johnpatrickanat - 回复
    Below 25%, exactly as stated in the instructions. There’s no benefit to draining it further than that, and in fact you’ll slightly shorten the service life of the battery by draining it all the way to zero. Follow the instructions exactly as written—if you go off-script, you’re a lot more likely to break something.
    Jeff Suovanen -
    So my screen shattered completely and the screen first had colored lines on tge while right side then it went out completely. If i get an lcd and digitizer replacement I'd that oing to fix it
    shellietheleo - 回复
    I would initially recommend a well-lit, comfortable area and placing the screws on a white piece of paper with the screw sizes written down (apparently there are magnetic mats, also). Also, I found placing the phone on a paper towel is good so that if a screw is dropped, it will lessen the likelihood of bouncing away.
    Lou Fazio - 回复
    I recommend that, before you even lift a screwdriver or plug in the hair dryer, get a piece of paper and a pencil. As you unscrew and remove the parts, write the size and/or number for that step and put them by their label. I also used a microscope to identify the screw heads (I'm 75 and my vision is not what it used to be). Laying them out in order, I just went backwards when putting them all back in. I used an anti-static cleaning cloth instead of paper, but I should think they both will work.
    N.B.: my kit had a nice pretty blue plastic sheet with a black outline on it. It was only when I put the whole phone back together and was packing up the supplies and tools that I realized it was a replacement gummi seal. A LABEL WOULD BE VERY USEFUL HERE!
    I am a retired engineer, and aside from the size of the bits and bobs, it was a piece of cake! Thanks...you saved me $75!
    P. Roberts - 回复
  2. iPhone 6s Plus Lightning 接口和耳机插口, 拆卸步骤大全: 步骤 2 中的图像 1,1
    • 可以选择使用iOpener或吹风机对iPhone的下边缘进行大约一分钟的温和加热。
    • 加热可软化固定显示屏的粘合剂,使其更容易打开。
    This is important. I’ve serviced a lot of iphones/ipads for my family as a hobby in the past.
    The adhesive was so tight, I cracked the screen trying to pull it/pry it off.
    I highly suggest heating at least the bottom edge enough to soften the adhesive
    garbage911garbage - 回复
    I didn’t have an iOpener, nor a heat gun; however I do have a small personal size hand pillow filled with feed corn. Two minutes in the nuke machine got it plenty warm, and smelled like fresh popcorn too.
    bradiac - 回复
    I would suggest that you are not shy with the hairdryer. A high heat on the bottom of the phone for at least a minute, if not more, if required.
    Mark Taberham - 回复
  3. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 3 中的图像 1,1
    • 6s Plus屏幕四个边缘周围有黏胶固定, 若你选择要更换黏胶的话, 在你拆解之前, 最好是先准备好新的黏胶。若你本身不想更换新黏胶也行, 因为在功能上, 跟使用原有的黏胶没有太大差别 。
    • 将吸盘置于屏幕左下角, 进行拆解。
    • 如果您的显示器严重开裂,用一层透明胶带覆盖其表面可以会让吸盘吸住。另外,也可以使用非常结实的胶带来代替吸盘。如果所有其他方法都失败了,您也可以将吸盘粘在破碎的屏幕上。
    take out screws first!!
    Yoav Karmon - 回复
    Make sure you use the right screw driver tip for i phone 6s Plus, which is the P-2. If the screw will not come off once is lose, try using a magnet.
    Miguel Perez - 回复
    My cracked screen prevented the suction cup from sealing. SOLUTION: With a piece of clear packing tape across the screen, the suction cup will seal and pull.
    Jim Cowles - 回复
    I broke my iphone screen in the first step!
    Pierre Bertram - 回复
    This screen removal step got more wrestley than I anticipated. The adhesive is quite strong. I used a flat-ended razor tool that I have to begin the prying - I don’t know how I would have got it started without this.
    Lou Fazio - 回复
    Ok - just got my battery replacement kit and even got the opening kit for added insurance just in case. Settled down to startwork after carefully cleaning my (immaculate) screen - no scratches or anything, with rubbing alcohol, removing screws and warming with a hair dryer, only to find the suction cup provided in the kit is worse than useless! It won’t stick to the screen well at all. When it does - it pops off at the lightest pull :-( Now what do I do to get this started?!
    CoffeeCup - 回复
  4. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 4 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 4 中的图像 2,2
    • 使用巧劲拉动吸盘, 直到屏幕与后盖中间出现缝隙为止。
    • 注意, 若拉太大力会造成屏幕损坏。只要打开到让显示屏与后盖有个小缝隙即可。
    I had a shattered front glass panel so I could not get the suction cup to seal properly. I tried a couple of different ways to get good suction but to no avail. I eventually used a Stanley knife to pry up the corner so I could get the spudger into the opening.
    John Architzel - 回复
    A really high quality packing tape over the entire screen will usually be enough to use the suction cup on a shattered screen.
    djwooten -
    I used a suction cup on each side to provide counter traction. I braced the iphone between my knees and pulled apart while my helper inserted the spudger
    jkanne - 回复
    This was by FAR the most difficult part of this whole thing. I confess the spudger was not cutting it so I used a butter knife to get into the small opening first, then used the spudger to go around the screen.
    Julie Sanchez - 回复
    Hey everyone, if you never have done this part before be aware there is an extremely strong adhesive around the lip of the screen and once again is extremely strong. I had to get a friend to insert the pry/pick into the small gap while I used one hand to brace the phone down and the other to pull the suction cup without it digging into my hand. Go slow, it took me 5 tries because I didn’t realize how strong the adhesive was.
    bartmistrot - 回复
    I also had a badly cracked lower screen - that glass was actually threatening to pull off the phone in chunks during this step, even with packing tape. Resorted to @j2arch’s tip and inserted a utility knife vertically into the seam between the display and phone body. Was able to lever the glass enough to get the spudger in there.
    Jason Augustyn - 回复
    I have replaced sevrel screens for my sister in law and my niece. The packing tape has worked every time and that’s with it Shattered and pieces already falling out. You have to make sure the packing tape goes to the edge of the screen but doesn’t touch the frame. I have the plier like screen remover and use that it is much easier to remove the screen by your self with that tool. I also have the little finger suction cup that comes with the kit here. I bought the plier suction cup tool When I had to replace the screen that had the pieces of the screen missing and I don’t regret spending the extra money for that it has made a world of difference. I do this as a hobby it’s not a job for me. The electric divide repair kit from Lowe’s is also a very good kit to help. If you’re only going to do it once the kit that comes with the package is a great deal from ifixit. Well worth the money to spend the little extra to get the kit if you all ready don’t have the tools.
    Brent - 回复
    If you try to use the spunger near the home button and try to pry it can crack your screen. This happened to me.
    Jeffrey - 回复
    Same thing happened to me. This should be a big warning in these steps. If you have a small to moderate crack in you screen, but you weren’t planning on replacing the screen at the same time as another repair inside, there’s a risk of damaging the screen further and making it inoperable.
    DW7ACCT -
    I found it easiest to use two suction cups. One on the front as directed, and a second one on the back. Give the spudger to your assistant, and have them slip it in place while you pull the display from the case.
    gordojenkins - 回复
    I gave up with the suction cup as it wasn't working for me with a cracked screen. Having heated the bottom of the phone with a hair dryer with a high heat for a good minute or so, I used a safety scraper (essentially a razor blade in a holder) along the bottom of the phone to separate the screen from the body of the phone. I used the scraper vertically between the bottom of the screen and the phone body and levered it sufficiently so that I could fit the spudger between the screen and the phone body. My experience when I first used the spudger around the frame was that the cracks in the screen caused the screen glass to separate from the frame, so I had to re-do it and ensure that the screen frame was separated from the phone body.
    Safety scraper:
    https://www.amazon.co.uk/Unger-CD170-Win...
    Mark Taberham - 回复
  5. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 5 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 5 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 5 中的图像 3,3
    • 在屏幕下有个槽口, 位置正好在耳机插槽上方。这里是撬开的最佳位置。
    • 当吸盘还吸附着屏幕的同时, 将撬棒平面那头插进屏幕与后盖的缝隙, 也就是耳机插槽上方位置。
    This was by far the hardest part of the repair for me. Getting leverage while finding a way to prod with a spudger is a challenge in coordination. I used a second spudger with point holding the phone down by the headphone jack, with the other end of the spudger anchored to my desk.
    drpotter - 回复
    When warmed, the suction cup was useless. Using the tip of a knife blade, was able to get it separated enough to insert spudger.
    hutland - 回复
    For me this was the most time consuming task. I used a hair dryer for heating. I found a very tight adhesive. For a moment I thought of abandoning my efforts and take the assembly to a professional repairman. But as they say, patience is a virtue.
    After fiddling for about 20 minutes, I achieved a barely noticable opening. So I decided to change the strategy. Instead of applying heat all over the base, I preceeded with small steps with heat concentrated near the opening. I applied intense heat only for about 15 to 20 seconds and immediately working with spudger. It took about an hour to completely open the case. It worked.
    Thanks for reading.
    - Mr Gamma
    Gamma Pailvan - 回复
    I also struggled with this step. Lots of heat, 3 different suction cups, I finally could see a small gap... much too thin to fit even a piece of paper into. A video on another site said it was the easy way. I used a sharp craft knife barely into the seam between metal and glass and pried slightly. And it started up. Still a pain freeing the rest of the adhesive. Perhaps the adhesive really sets up over the course of 5 years? I have it hinged open now, so onto the next steps.
    Mark Tollefson - 回复
  6. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 6 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 6 中的图像 2,2
    • 用撬棒将缝隙左右边撑开, 使屏幕从机身上分离。
    just changed the screen, but due to the tape along side the screen , it is best to heat a little so the glue losses and you can get the screen off better, like indicated
    Bart Blanckaert - 回复
  7. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 7 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 7 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 7 中的图像 3,3
    • 将吸盘往上拉的同时, 将撬棒平的那头插进手机左侧, 屏幕与背盖间的缝隙。
  8. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 8 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 8 中的图像 2,2
    • 将撬棒平的那头插进手机左侧, 前面板与背盖间的缝隙。
  9. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 9 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 9 中的图像 2,2
    • 将撬棒平的那头插进手机右侧, 屏幕与背盖间的缝隙。
    • 将撬棒缓慢地沿着底部边缘移到右边。
  10. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 10 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 10 中的图像 2,2
    • 当你用吸盘将屏幕小心地掀开时, 使用塑料Opening工具将后盖撑住。
    • 請勿將屏幕完全掀开, 因为屏幕上还有排线连接, 如果掀开角度过大, 可能造成排线损坏。
  11. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 11 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 11 中的图像 2,2
    • 使用巧劲将吸盘往上拉, 将屏幕与机身分离。
    Remember to apply the screen gasket on the re-assemble. The gasket is provided in the kit but not mentioned here on the instructions.
    Won Hong - 回复
    There’s a link to the entire gasket replacement procedure in Step 21.
    Jeff Suovanen -
  12. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 12 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 12 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 12 中的图像 3,3
    • 以屏幕顶端为支点,将屏幕缓缓地向上掀起。
    • 将屏幕掀至约90º竖起, 并且在你操作的时候找个东西支撑着它。
    • 請勿將屏幕掀开超过90º, 因为屏幕上还有3条排线连接, 如果掀开角度过大, 可能造成排线损坏。
    • 用橡皮筋将前面板与支撑物固定住。这可以避免拉扯到显示排线。
    • 若在紧要关头时, 你也可以用未开过的罐装饮料撑着屏幕, 这也是可行方法。
    if the display cables are damaged how can you tell ?
    Smiley McSmilebot - 回复
    In theory, I like the idea of propping up the screen with a rubber band and box/soda can like this, but after ripping the FaceTime camera cable twice, I realize that this method puts too much stress on the cable because it places the screen so far back. Even in this photo, you can see that the cable is taut. I’d recommend just holding the screen with your free hand to put the least amount of stress on that cable as possible.
    Ben Estabrook - 回复
    I used my spunger to prop it open. Works great
    Redbird - 回复
  13. iPhone 6s Plus Lightning 接口和耳机插口, 电池连接座: 步骤 13 中的图像 1,1
    • 卸下电池排线固定架上的2颗Phillips #00 螺丝。
    • 1颗2.9 mm螺丝
    • 1颗2.3 mm螺丝
    • 在按照指南操作的同時,請仔細看顧所有的螺絲,並確保每一顆螺絲都能歸回原位。將任一螺絲裝置在錯誤的位置,都可能導致永久性毀損
    FYI - I used some blue painters tape wrapped around a piece of cardboard to hold the screws and brackets in place, in order, so they did not get lost. Some of those screws are MICROSCOPIC so be careful!
    I also suggest having very good lighting, even a camping headlight for hands-free well lit work space. You will thank me later :-)
    Julie Sanchez - 回复
    Use the bit labeled “PH000”.
    Joe Teichert - 回复
    PH000 bit just wants to free-spin in the 2.3 mm screw. no bite in the head at all. had no difficulty removing the 2.9 mm screw with the same Phillips. had to abandon battery replacement effort.
    Benjamin Stalcup - 回复
    For this part, neither PH000 or Y000 worked. Technically, it’ll set you back 31$ because you will need the PH00 screwdriver for this part, and the part where you need to open the screen. They have ph00 screwdrivers in every hardware store and even ifixit.com. just know that they put the wrong screwheads for you
    Jack Daniel - 回复
    Do not lose track of which hole these screws go into. They MUST be put back into the correct hole that they came out of. If not, you will get the dreaded “long screw damage” on the mainboard, and that will be the end of the show.
    Just remember where these screws go, and it will be fine.
    Harry McDow - 回复
    Ended up employing a Philips #0 from a regular jeweler/precision kit on the 2.3mm screw. Bits seem a bit off for this step.
    Vance Bell - 回复
  14. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 14 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 14 中的图像 2,2
    • 取下电池连结固定板。
    Does it matter if the brackets arent put back in the phone? I bought a used phone and brackets are missing. Thanks!
    Coupon Crazy - 回复
    Auch die Abdeckung ist angeklebt. Also mit etwas Vorsicht und Geduld rangehen.
    eckhardd@icloud.com - 回复
    If you have forgotten your High School German -
    The cover is also glued. So take some care and patience.
    Glen Paetz -
    My bracket actually has a black wire connected on the underside that is attached to the metal bracket (with screw) below it in the picture. I decided to leave it on and just move it to the side.
    Victor Ng-Thow-Hing - 回复
  15. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 15 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 15 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 15 中的图像 3,3
    • 使用撬棒尖头那端(或您亦可使用乾淨的指甲)将电池连结座往上撬开, 与主板分离。
  16. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 16 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 16 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 16 中的图像 3,3
    • 使用撬棒将电池连结座与主板从插槽分离,避免操作中不小心接触到电池。
    When putting the new battery in, make sure to line up the plug and not to the top of the battery… our battery was smaller so the plug would NOT have lined up if we used the top of the battery. ALSO, the plug was NOT 90 degrees so we had to finagle the plug. Also, make sure there is a clear CLICK when you plug in the connector or it may not work. Ours went in but guess didn’t go far enough so we had to take the screen off and push it harder until we heard the “click” then it worked fine.
    Won Hong - 回复
    There was some black goop/glue around the battery connector, and when I lifted the old connector, some of that glue fell into the receptacle. It was easy to fish out (with magnifying glass and tweezers) but if you don't catch it, you may not get a good connection.
    Steerpike - 回复
  17. iPhone 6s Plus Lightning 接口和耳机插口, 前面板组: 步骤 17 中的图像 1,1
    • 卸下图上的5颗Phillips螺丝。
    • 3颗1.3mm 螺丝
    • 1颗1.6mm 螺丝
    • 1颗3.0mm 螺丝
    • 在重新组装过程中, 请特别注意3.0mm 螺丝必须是拧在右上角的位置。如果放错地方, 可能会造成主板的损坏。
    I really don't see value in removing screen use box and rubber band keep at 90 degrees.
    John Parker - 回复
    I leave screen on as well for this. - Tho I prefer a 45 degree lean.
    Thor -
    I just changed my battery and also left the screen attached. I was lucky enough to get all 3 adhesive battery strips out clean so I didn’t have a struggle with the battery coming out. If I was going to need to get rough with it I was going to take the screen off at that point.
    Michael Gross - 回复
    To keep track of screws, draw a quick outline of the display cable bracket/cover, with five dots where screws should be. Drop the screws on the corresponding dot. Helps if you use magnet pad.
    Christa - 回复
    Better yet, print out the pictures from the iFixit website, and use clear tape (“Scotch tape”) to TAPE the screws onto the place in the picture where they belong.
    Tom -
    Which screwdriver from the kit do I use for which screw?
    Shiva Sharma - 回复
    I made a mistake and unscrewed the screw just north north west of the one circled in yellow. Of course I lost the screw. Can anyone give me any guidance about this? what does the wire connected to it do? What is the size of the screw, in case I have to replace it?
    P.S. This is another reason to consider the possibility of NOT removing the screen just to replace the battery: removing the screen presents a additional possible headache, especially for people like me with bad eyesight who probably shouldn’t be doing this in the first place.
    Tom - 回复
    It is a 1.4 mm Phillips screw holding the NFC bracket in place.
    Larry Lynch -
    I didn’t think this was necessary, bit I see it relieves stress on the front-facing camera and sensor cable connector; I did not disconnect the display connector nor remove the display screen.
    Lou Fazio - 回复
    I second this finding. I too did not remove the screws nor the bracket. The cables look a bit stretched, but certainly not strained.
    -Gamma
    Gamma Pailvan -
    This step of separating the two parts of the phone deserves careful consideration. In my case, I had propped up the display assembly with a box and rubber bands. However, only 2 of the battery adhesive strips came off easily. The effort to remove the battery with the display assembly attached was not a good move on my part. I jarred the ear speaker cable and after reassembly I had no camera or working ear speaker. Taking off these 5 screws and removing the three cables is not difficult. My suggestion: is you have ANY trouble removing the 3 battery adhesive strips, STOP, separate the two components, and then continue with the battery removal. Don’t struggle removing the battery with the display assembly attached. (I replaced the ear speaker cable, and all is working now)
    Richard Perl - 回复
    Thanks for this tip! I am having a really hard time removing this plate because one of the screw heads are stripped. So I’ll try removing the battery adhesive strips first to see if I can get the battery out without removing the screen.
    nathanfunk -
    Use dixie cups and label them for each part you take out. You can stack the dixie cups to keep them in order.
    Bradley Nolen - 回复
    I skipped this for the battery removal, but when I went to replace the seal, I had to remove it anyway.
    dgol69 - 回复
    I lost the bottom left screw of the five in this step - anyone know if it’sgoing to cause a problem? ‘m going to go ahead and put thephone back together anyway - wil report back withresult
    CoffeeCup - 回复
    OMG…. SO excited! It works! Seems that missing screw wasn’t an issue. The reason I’m so excited is, I’m a senior and have bever attempted anything like this before and was worried I’d mess it up, or it just wouuldn’t work for whatever reason. I know I never would have tried if it weren’t for finding this site, the great service, parts to do it and the videos/guides. Thank you so much ifixit. :-)
    CoffeeCup - 回复
    I changed the battery, without removing the screen, when I closed the phone the front camera and speaker no longer work.
    Mr T - 回复
  18. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 18 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 18 中的图像 2,2
    • 从主板上取下屏幕排线固定板
    Be careful on this step: with my iPhone, one of the connectors (the home button/fingerprint sensor) was stuck to the underside of the bracket and I almost strained its cable.
    kevin - 回复
  19. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 19 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 19 中的图像 2,2
    • 请特别注意此步骤。只需断开排线与座子的连接即可,千万不要连着主板的座子一同撬开。
    • 使用塑料撬棒断开前摄像头排线和传感器排线与座子的连接,并与主板分离。
    FYI, in the video she uses the spudger for this but I think either one will work.
    Julie Sanchez - 回复
    I found prying from the right to be better
    Lou Fazio - 回复
    Is there any need for this step if only the Battery is replaced
    mrrreid - 回复
    I don’t recommend using the spudger for this as you can do more damage that way. I scratched the black square thing underneath.
    Laura Houghton - 回复
    I managed to remove the battery without disconnecting and removing the display first. This avoids possible difficulties in these steps (see below).
    One has to be careful that, while fighting with the battery strips, the display remains in its 90º position
    alfasw33 - 回复
  20. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 20 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 20 中的图像 2,2
    • 使用塑料工具, 断开传感器排线接口, 与主板分离。
    • 重新组装传感器排线时, 请注意不要按压传感器中间的地方。正确应该是先按压一边, 之后再按压另一边, 因为若按压中间的地方, 可能会使零件变形, 造成传感器损坏。
    Thanks you i fix it
    God Hand - 回复
    “When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage. “
    The following note above was so helpful. I was speeding through the process of getting things back together, since it seemed easy to connect the digitizer cable, but I kept pushing it in the middle and I wouldn’t connect. Until I read through this step and realized it was easier if I would’ve connected one side and then the opposite side right after.
    Jeffrey Robinos - 回复
    Don’t be too shy when pushing the ends of the digitizer connector back to place. If it does not connect properly, you might face the “half backlight” problem, even if you did not kill any LCD filter. Also check carefully, that you don’t clamp parts of the sticky sealing material placed around the connector inside the connection area.
    Norbert Andreas Richartz - 回复
    This part was a very frustrating experience for me.  I thought that my replacement screen was just poor quality, as it worked when it wanted to work.  Pressing home/power repeatedly sometimes brought it back, charging to 100% also brought it back.    The actual problem was that it is very easy to get some of the gasket material caught in the connector, which I couldn’t see until I used my jeweler's loupe.  I used 91% alcohol to carefully clean all of this off until all pins were shiny, and it took about 6 tries to get it right.  However, the screen’s been running well for 2 days now.  I already bought another screen replacement which I have for a spare as it was 100% not the problem.
    chumblyf - 回复
    I followed all the steps, so the sound is missed. What could be happened? thanks a lot. Fabio Balbino
    Fabio Balbino - 回复
  21. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 21 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 21 中的图像 2,2
    • 在此步骤中断开或重新连接电缆之前,请确保电池已断开连接。
    • 将 Home 键/指纹传感器电缆从主板上的插座中直接撬起,断开它。
    How much is this to replace?
    Alistair knight - 回复
    And where could I buy from?
    You can buy these at iFixit: [关联产品丢失或禁用: IF314-000-3]
    drgon - 回复
    After finishing the assembly I got the message “Touch ID cannot be enabled on this phone”. I found this connector was loose. Plugged it back in and that fixed it.
    Bryan Province - 回复
    Thanks for the tip. Same thing happened to me, some leftover adhesive was in the way!
    Sean - Lua Tech -
    Always make sure to disconnect the battery before you do any work on the phone replacing any parts the digitizer or anything. And before you start make sure the phone is turned off you don’t want any power surges. If you also have a static electricity bracelet that also is a plus to use but isn’t a necessity just a nice piece of mind. Some cases you do need to use one so you don’t discharge static electricity to an electrical component and mess it up.
    Brent - 回复
    Be very careful in this step. I noticed it’s very easy to tear the flex when trying to lift it out of its socket from the right side.
    shoeib - 回复
    What is the cable and how is it connected/fixed to the motherboard between the bottom socket and the screw hole.
    Mine came loose somehow?
    Jason Engelsman - 回复
    I figured out my own question its the Wi-Fi diversity antenna cable. But how is it connected/secured to the motherboard?
    i pressed on the center of the digitizer connection. and the bottom half of my screen didnt work. i then took that same front panel assembly and tried to install it on another old iphone 6s+ and i had the same issue.
    can i still fix it?
    what exactly is broken now?
    alejandro rueda - 回复
    @mynameisoli Honestly this just sounds like a defective screen to me, but it’s hard to say for sure. Look closely at the connector at the end of the ribbon cable and check it for damage. If it’s slightly bent/curved, all the pins won’t make good contact in the socket. You can try bending it back so it lays flat, but you have to be very careful not to damage the connector or contaminate the pins with skin oils, so it’s tricky—and it may be harder to return as “defective” if you mess up the connector. So try this at your own risk. Apart from that, I would just return it and try a different display. Good luck!
    Jeff Suovanen -
    The 6s plus screen repair kit i bought has the wrong size cable here on the replacement part. SOL.
    Alex Richardson - 回复
    Once I accidentally disconnected the display assembly cables before disconnecting the battery. Now the home button and fingerprint sensor doesn’t work. Any solution to this?? I have tried a different home button, even that doesn’t work.
    a3roar - 回复
    I changed the battery on my iPhone and put all together again and charged it. When I pressed the home button the lock screen with my picture appeared and when I pressed it again the screen with the digits from 0 to 9 appeared. I was asked to enter my passcode, but when I did that nothing happened, the phone did not open.
    What could be wrong? Is the home screen cable not fully connected or what could be the reason for this?
    THORDUR JOHANNESSON - 回复
  22. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 22 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 22 中的图像 2,2
    • 至此,屏幕可以彻底与机身分离了。
    • 在重新组装的过程中, 若你有准备新的胶条, 请先将旧的胶条清除干净, 再将新的胶条黏贴上去。
    For instructions on home button swap out to the new screen you just installed, go here
    iPhone6s Plus Home键组件更换
    Superior Office Systems - 回复
    Do you know whether the adhesive contributes to waterproofing, or just for stability/adhesion?
    Christa - 回复
    @kitabel The iPhone 6s case isn’t waterproof, so I don’t think adhesive around the display is contributing anything other than stability. The 6s series does have some water resistance, but it’s mostly internal and not something Apple advertises.
    Jeff Suovanen -
    If you have a replacement adhesive for the display, you may need to install it before reconnecting cables to the components. If the adhesive wraps all the way around the display, it will be impossible to install it once the display is reconnected.
    Matthew Olwell - 回复
    These instructions worked great for me. Thank you!
    Chris Enloe - 回复
  23. iPhone 6s Plus Lightning 接口和耳机插口, iSight 摄像头: 步骤 23 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口, iSight 摄像头: 步骤 23 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口, iSight 摄像头: 步骤 23 中的图像 3,3
    • 将黏在iSight摄像头固定板上的胶条清除干净。
  24. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 24 中的图像 1,1
    • 从iSight摄像头固定座卸下2颗Phillips螺丝。
    • 1颗1.9mm螺丝
    • 1颗2.4mm螺丝
  25. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 25 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 25 中的图像 2,2
    • 卸下摄像头固定座。
  26. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 26 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 26 中的图像 2,2
    • 将摄像头连接座与主板分离。
    • 请注意此步骤, 在作业过程中, 只需要将连接座分离即可, 不包含主板的接口。
  27. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 27 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 27 中的图像 2,2
    • 将撬棒平头那端插入摄像头与后盖之间
    • 轻轻地撬开摄像头。
  28. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 28 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 28 中的图像 2,2
    • 卸下摄像头。
  29. iPhone 6s Plus Lightning 接口和耳机插口, SIM 卡托: 步骤 29 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口, SIM 卡托: 步骤 29 中的图像 2,2
    • 使用SIM卡取卡针或是回纹针插入SIM卡退卡孔中。
    • 用力的向里面按压, 使卡托弹出。
  30. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 30 中的图像 1,1
    • 从iPhone卸下SIM卡托。
    • 当你要将SIM卡装回时, 请注意卡托与SIM卡方向。
  31. iPhone 6s Plus Lightning 接口和耳机插口, 主板: 步骤 31 中的图像 1,1
    • 移除一颗固定NFC 固定板的 1.4mm 菲利普丝十字螺丝。
  32. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 32 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 32 中的图像 2,2
    • 卸下NFC固定板。
  33. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 33 中的图像 1,1
    • 移除两颗固定音量控制排线固定板的 2.7 mm 菲利普斯十字螺丝。
  34. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 34 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 34 中的图像 2,2
    • 卸下音量控制固定板。
  35. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 35 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 35 中的图像 2,2
    • 使用撬棒的平头断开音量控制排线接口, 与主板分离。
  36. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 36 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 36 中的图像 2,2
    • 使用撬棒尖头那端, 将天线排线与主板撬开分离。
  37. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 37 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 37 中的图像 2,2
    • 使用撬棒尖头那端, 将Wi-Fi天线排线与主板撬开分离。
  38. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 38 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 38 中的图像 2,2
    • 使用撬棒尖头那端, 将电源键排线与主板撬开分离。
  39. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 39 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 39 中的图像 2,2
    • 将天线排线从逻辑板上撬起,断开天线排线的连接。
  40. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 40 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 40 中的图像 2,2
    • 此用撬棒平头那端, 将Lightning 接口排线与主板分离。
  41. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 41 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 41 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 41 中的图像 3,3
    • 将位于主板右边的天线排线, 从兩個夹子中夹起。
  42. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 42 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 42 中的图像 2,2
    • 卸下图中的三颗菲利普斯十字螺丝。
    • 一颗1.3mm 菲利普斯十字螺丝
    • 一颗2.6mm 菲利普斯十字螺丝
    • 一颗2.2mm 压铆螺柱螺丝
    • 你可以通过iPhone专用的压铆螺柱螺丝刀或螺丝刀组更轻松地卸下它们。
    • 简单来说,小型平头螺丝刀可以完成这项工作 —— 但要特别小心,确保它不会滑动并损坏周围的部件。
  43. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 43 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 43 中的图像 2,2
    • 卸下固定板。
  44. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 44 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 44 中的图像 2,2
    • 将位于左上方的天线排线, 从第一个主板的夹子底下夹起, 并往电池方向慢慢轻推。
  45. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 45 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 45 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 45 中的图像 3,3
    • 继续上个步骤, 把天线排线从主板的第二与第三个夹子分离。
    • 使用撬棒尖头那端, 轻轻的将天线排线与中间主板的夹子分离。
    • 请勿尝试通过拉动排线来将其卸下,因为它很容易损坏。
    • 为了让排线可以顺利地与主板连结, 你必须将排线将排线置于主板上方, 并同时置于音量控制排线的下方, 如同第一张照片所示。
  46. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 46 中的图像 1,1
    • 卸下位于SIM卡读卡器下方的 2.0mm 十字螺丝。
  47. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 47 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 47 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 47 中的图像 3,3
    • 小心地抬起, 但不要移除主板, 使用塑料三角撬片. 从底部靠近Lightning 接口附近的地方抬起。
  48. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 48 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 48 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 48 中的图像 3,3
    • 将主板掀起至90度的位置, 让位于上缘的天线连接座露出。
    • 千万不要试着将主板完全移开, 因为Wi-Fi/蓝牙的天线都还与主板连接着。
  49. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 49 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 49 中的图像 2,2
    • 轻轻地将主板倒放在桌上, 主板的上缘轻靠在后盖上即可。
    • 使用撬棒平头那端, 将Wi-Fi/蓝芽天线排线, 从主板上的接口分离。
  50. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 50 中的图像 1,1
    • 卸下主板。
  51. iPhone 6s Plus Lightning 接口和耳机插口, 扬声器組件: 步骤 51 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口, 扬声器組件: 步骤 51 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口, 扬声器組件: 步骤 51 中的图像 3,3
    • 使用撬棒平头那端, 将Lightning 接口排线与扬声器分离。
  52. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 52 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 52 中的图像 2,2
    • 卸下图中的3颗Phillips 螺丝, 用来固定Taptic Engine线性马达排线的固定板。
    • 2颗3.5mm 螺丝
    • 1颗2.7mm 螺丝
    • 同时将固定板也卸下。
  53. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 53 中的图像 1,1
    • 卸下图中的5颗Phillips 螺丝, 用来将扬声器固定于后盖的。
    • 2颗2.7mm 螺丝
    • 1颗2.5mm 螺丝
    • 1颗1.5mm 螺丝
    • 1颗1.7mm 螺丝
  54. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 54 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 54 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 54 中的图像 3,3
    • 将位于后盖右边的天线排线, 从橡皮垫中夹起。
    • 若液体损坏指示贴纸沾到水, 会造成很难将天线排线安装回去。因此在过程中, 发现贴纸剥离的话, 请轻轻地将指示贴纸摆回原位。
  55. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 55 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 55 中的图像 2,2
    • 使用镊子将Wi-Fi天线排线与Lightning 接口排线分离。
  56. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 56 中的图像 1,1
    • 卸下2.6 mm Phillips螺丝, 用来将扬声器固定于后盖上的。
  57. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 57 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 57 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 57 中的图像 3,3
    • 使用撬棒平头那端, 将扬声器组从手机中轻轻抬起。
    • 卸下扬声器组件。
  58. iPhone 6s Plus Lightning 接口和耳机插口, Lightning 接口和耳机插口: 步骤 58 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口, Lightning 接口和耳机插口: 步骤 58 中的图像 2,2
    • 使用撬棒尖头那端, 将Taptic Engine线性马达排线与下缘的排线分离。
    Maybe it would be best to have people remove the screws first? Otherwise prying the flex cable (which is very thin and not super flexible) may result in it breaking from the Taptic Engine. Just a thought.
    Kayne Caplinger - 回复
    The cable is plenty flexible, hence the name. ;) Remove the screws first if you like, but there’s no harm in doing it this way.
    Jeff Suovanen -
    can i remove the lighting connector without steps 27 to 35?
    Kweku Opong-Peprah - 回复
  59. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 59 中的图像 1,1
    • 卸下固定Taptic Engine线性马达的2颗Phillips螺丝。
    • 1颗3.1mm 螺丝
    • 1颗2.1mm 螺丝
  60. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 60 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 60 中的图像 2,2
    • 卸下Taptic Engine线性马达。
  61. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 61 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 61 中的图像 2,2
    • 使用撬棒平头那端, 将Lightning 接口与后盖间的剩余黏胶断开。
  62. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 62 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 62 中的图像 2,2
    • 卸下图中的5颗Phillips螺丝。
    • 1颗2.9 mm 螺丝
    • 1颗1.9 mm 螺丝
    • 1颗1.5 mm 螺丝
    • 1颗1.6 mm 螺丝
    • 1颗1.3 mm 螺丝, 位于后盖下缘的地方。
  63. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 63 中的图像 1,1
    • 准备一个iOpener, 加热后, 置于手后盖下方, 用来软化固定Lightning接口排线的黏胶。
    • 放置约一分钟, 让黏胶确实软化。
  64. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 64 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 64 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 64 中的图像 3,3
    • 使用塑料三角撬片, 从排线右上方地方与后盖中间撬开。
  65. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 65 中的图像 1,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 65 中的图像 2,3 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 65 中的图像 3,3
    • 慢慢地使劲, 将撬片慢慢推至排线下方, 并将黏胶断开。
  66. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 66 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 66 中的图像 2,2
    • 持续地将撬片慢慢地往排线下方推进。
  67. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 67 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 67 中的图像 2,2
    • 使用撬棒尖头那端, 将3.5 mm耳机插孔撬开。
    Save the sealant rubber from the jack and the lighting connector if the new one does not have it.
    István Borsányi - 回复
  68. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 68 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 68 中的图像 2,2
    • 使用撬片将位于后盖左下方的麦克风分离。
    make sure you don’t remove the little black plastic part that goes between the microphone & case, it was firmly attached to the left microphone.
    Rhonda Tregay - 回复
    The instructions don't mention it, but the photo shows the microphone by the headphone jack also being eased back, which we did have to do; agree with Rhonda's comment, and separating those parts took persistence.
    Matthew Dearden - 回复
  69. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 69 中的图像 1,2 iPhone 6s Plus Lightning 接口和耳机插口: 步骤 69 中的图像 2,2
    • 重复上个步骤, 将右方的麦克风也卸下。
    The Spudger really works well to align the new headphone jack up when reinstalling the new lightning connector assembly
    Andrew Baird - 回复
  70. iPhone 6s Plus Lightning 接口和耳机插口: 步骤 70 中的图像 1,1
    • 卸下Lightning 接口排线。
    • 安装或替换Lightning接口排线之前:
    • 使用一个塑料工具来去除排线后的后壳上残留的粘胶。
    • 将替换件和原来的对比一下,找出任何不同。您可能发现原来的耳机接口上粘有一个橡胶圈,如果需要的话应将其转移到替换件上。
    • 测试一下替换件是否合适,然后安装前撕掉所有的保护膜。
结论
如要组装的话, 请按逆序操作。
166等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Evan Noronha
于02/05/15注册
226,081 声望
创作了168篇指南
24条评论
Hardest thing I have every done!! But well worth it. Now I know I need to go up on my labor price!!! :-) Thanks a ton from South Carolina!!
apriltanner1975 - 回复
Just did this. Agree with everyone else, just flip the speaker over to get to the lightning connector assembly. Changes the repair time drastically
ztune - 回复
I just completed this repair, replacing the Headphone Jack/Lightening port, battery and iSight camera all at the same time. I removed everything as it explained in the guide, but can totally see how not removing the logic board would save time and isn't 100% necessary. I imagine that peeling the upper portion of the headphone/lighting port is slightly easier with the logic board removed, and you don't have to worry about that antenna cable. If I did it again, I would probably still remove the logic board.
Michael Cornforth - 回复
you would have to be crazy to remove the board. just flip the speaker up on its back and rest against logic board. 20 mins should complete this . i cant stress enough that board or camera does not need removed . PERIOD
Smartfone NI - 回复
I completed this and it starts charging, but the home button stop working. It still sense my finger print, but it does not respond when i click on it.
Any help?
Poh Chun Hou - 回复
In my experience that would be either a bad connection at the display connections or a damaged flex cable somewhere.
Sam Luber -
Does anyone have any idea why my SIM card is now not recognized ?
Tom Hogan - 回复
I am moving all the parts of my iPhone 6s plus over to a new housing because mine is badly damaged does anyone know what that gold paste is under the big flax cable for all the io ports?
Do i need to buy some more if so where ?
pls help with any advice…
Max - 回复
needs a step for the rebuild on when to peel adhesive strips since they are underneath.
Rhonda Tregay - 回复
Just finished, including putting up tools. 2 hours. I agree with Chris and markrodhumm on leaving out some of the steps.
Terry Dunlap - 回复
Hey guys, just replaced my Lightning connector and it works great now. However when i’m not on wifi I have no service or it jumps in and out a lot. What could be the problem ?
Dillon Lackus - 回复
Before doing anything in this article or taking or sending your phone or device in to be serviced:
Take a tooth pick, or a brand new never been used before toothbrush, or some canned air and using a flashlight to see inside the port, clean out any gunk, dirt, lint, or other obstruction from the charging port and try plugging your phone/device in again. Also, try a different charging cable to rule out the possibility of a bad cable. I know Apple cables are expensive, but it might just be the cheapie cable you purchased at a convenience store that is the culprit.
Yes your repair might actually be this simple.
By the way iFixit, excellent article!
John - 回复
Is it possible to only replace/repair a faulty headphone jack on it’s own?
OR does the part, come only as one piece; iPhone 6s Plus Lightning Connector and Headphone Jack Replacement?
I’m currently having my iphone 6s plus repaired by a local iPhone repair shop for a faulty lightening connector (phone not charging). I also have intermittent issue with my iphone being stuck in headphone mode but after a software update it fixed and worked for a while but recently gone back to being stuck in headphone mode SO I am now curious if the iPhone repair shop will fix this headphone jack issue at the same time by replacing the Lightening Connector.
Hence my question: Is it possible to only replace/repair a faulty headphone jack on it’s own?
any feedback would be appreciated, I’m concerned and currently lack confidence in the repair shop at their lack of honesty in the past.
catelyn.dowell - 回复
Hi Catelyn,
The headphone jack is attached to the Lightning connector assembly in such a way that it is replaced together as a unit.
Arthur Shi -
I cant reinforce strongly enough to follow John’s suggestion,
CLEAN OUT THE PORT before trying this repair.
sounnder - 回复
Great, simple step by step instructions to follow.
Cost me parts and 2 hours of my time instead of spending on a brand new phone.
Thank you.
imayoda - 回复
I replaced my unit since the charging port stopped working. Now the charging port is working but the speaker and microphones aren’t. Which steps do I need to revisit to fix this issue?
Ahmed Hassan - 回复
Don’t have a dog near you doing this. You will end up having to measure every single screw before assembling it just to realize that two are already missing….
Lukas - 回复
You know, it was a lot easier putting it back together than I thought it would be. I'm really proud of myself, knowing that I had the skill to successfully repair a freakin' iPhone.
Thank you a billion for this guide!
Grey - 回复
Well done Grey! That was not an easy guide to complete!
Arthur Shi -
I just completed this repair. I can’t believe it worked. I agree with the others that removing the display seems unnecessary as you can keep the antenna in place and just move the speaker instead of removing it. Great service, though. I still can hardly believe it actually worked. I fixed my dodgy headphone jack that was giving me a lot of grief.
Felix - 回复
I successfully repaired my 6s Plus by transplanting the rear camera and lightning/headphone jack assembly from a badly damaged donor phone. I was worried about all of the adhesives, but the whole process was pretty straightforward with this guide. Looking forward to getting another couple of years out of this phone!
tsndrs - 回复
I know it’s 2024. I had an old iPhone 6s Plus hanging around. This guide walked me through step by step and I was able to charge the phone perfectly. All features and functions work correctly! What a great place and community. My first phone repair of many to come! Thank you for posting this. If you have trouble make sure you reassemble everything correctly
Avengedgaming - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 39
过去 30 天: 151
总计 131,649
