跳转到主内容
iPhone 6 LCD屏幕面板的更换
你所需要的
  1. iPhone 6 LCD屏幕面板的更换, 五角(梅花形)螺丝: 步骤 1 中的图像 1,1
    • 在拆卸 iPhone 之前,请将电池放电至 25% 以下。 如果意外刺破,带电的锂离子电池可能会着火和/或爆炸。
    • 在开始拆卸之前将 iPhone关机。
    • 移除 Lightning 接口两侧的两枚3.6 mm长的P2五角(梅花形)螺丝。
    When reconnecting be VERY careful not to over tighten. The connectors on the screen that these 3.6mm Pentalobe screws lock with are notorious for breaking off
    Blair Tryba - 回复
    what do i do if ive managed to tighten them too hard and now they wont come off?
    kristian686 -
    Before opening the phone, I gently warmed it using a buckwheat heating pad. This made removal of the adhesive strips (steps 20 to 24) easy.
    Howard Bales - 回复
    Exactly what I did as well, the gently warming made the adhesive removal work like a charm. The heat as well help to lift the screen easily, no need for the prying tools for me to open te phone.
    For the adhesive removal just pull it slowly to the bottom of the phone and keep in under tension.
    On reassembly, turn on the phone after getting all connectors back in place to verify all is working fine before putting all screws back in their spot.
    Maarten Vergauwen -
    Thanks for the suggestion! I heated up a hot/cold pack, and it worked great.
    Linda Chandler -
    I put mine back together but mine looks very different than this one. Why is it that when I make a call I cannot hear through the ear piece and have to put it on speaker. Also my screen doesn't go black when my face touches it
    Bailey Wilson - 回复
    Hey Bailey, which repair were you attempting? Is it possible you have a 6s, or maybe a 6 Plus? You may have better luck with faster troubleshooting if you post in our Answer Forum!
    Sam Goldheart -
    See its a long time ago you had this issue. You can try to remove the cable from front camera/sensor/earpiece from the motherboard port and gently push it back on. All the problems you relate to is thru the same cable. If this dont solve your problem, check if the earpiece is correctly placed onto the polarity poles, and that the proximity sensor is lying right down into the corresponding socket. If something is blocking the sensor, yeah then the screen wont turn on/off when you put it onto your ear.
    Kenneth Hilstan -
    I see in the preamble that when you replace your logic board, you would lose touch id functionality, so my question is what if you have the homebutton and thus the fingerprint reader for the logic board replacement, would touch id work?
    socratesmens - 回复
    The guide for the iPhone6 battery replacement needs to be revised. There are a couple of issues.
    1) While the battery cover has two screws, they are different lengths. Since they are very small, it can be hard to see the difference (until one tries to screw the smaller one into the longer hole). The video needs to mention this.
    2) The application of the adhesive strip if very different from what is mentioned. Also, there is a “one piece plastic” applique, and it is very unforgiving. The video should show this process in more detail.
    I believe the attention to this detail would help folks correctly install their iPhone 6 batteries, and with the recent Apple disclosed battery problem, would continue to show that iFixit is very committed to the end-user.
    Gary Long - 回复
    I felt a bit silly getting stuck at the end of a long repair, unable to screw one of these last screws back in. What worked was gently pinching the phone above and below the screw, to make sure the screen and back were perfectly aligned.
    Matt D - 回复
    Apple edits posts on their Communities website that link to this fix page justifying as follows:
    “We’ve edited your post because following the procedures at the site you provided may lead to damage to the user’s device.”
    What is certain is that following Apple Support’s advice of resetting our phones again and again never works whereas this fix works. Apparently Apple does not want people to know that their hardware fails and can be fixed, because then they would need to explain why they don’t offer neither the fixing service nor the fixing advice by directing us to this website.
    Brice - 回复
    Before you get started, I suggest you confirm you are replacing the correct camera. If you are thinking of a camera, the front is the side of the device with the main lens. On an iPhone this is actually known as the rear facing camera. Once the phone is disassembled your orientation can be distorted and it is not that hard to fail to realize your are replacing the wrong camera. Doh!
    William Miller - 回复
    I found it very useful to use a magnet sheet when doing these repairs. I use electrical tape or a sharpie to make a grid, and place each micro screw in a separate box on the grid.
    I work directly over the magnet sheet, so that if something drops I have a better chance at not losing it.
    If you do lose a screw, go over the work area with a fridge magnet. It will pick it up if it hasn’t popped too far away.
    Megan Telliano - 回复
    I agree. The Magnetic Project Mat makes your project incredibly easier and keeps your screws/parts organized. Here is the link for anyone interested:
    Cooper -
    or some masking tape with sticky side up and the ends folded underneath on a piece of paper, then you can write notes like
    “1.4mm for FOO bracket →”
    “7x2.3mm for EMI cover, different one by camera →”
    The arrows point as appropriate.
    If you drop something, put a flashlight on the floor & shine it across the floor — Turn off ceiling & other lights off to maximize the shadow from the flashlight.
    Bass Clef -
    These screws are tiny, and the first two are the biggest of the lot. Get a magnifying glass or good reader glasses.
    Jennifer Porter - 回复
    Which torx is this T?
    klemenecanze - 回复
    The screws are no torx screws they are Apple Pentalobe screws. You need to buy a Pentalobe screwdriver seen above.
    Claes -
    I have to use the P2 right?
    Aman Singh - 回复
    The best advice I can give is not to perform this operation over carpet.
    Bruce codding - 回复
    I'm an amateur, but I was able to replace the parts almost perfectly while looking at this explanation, thank you very much.
    irichin.3.26 - 回复
    was fairly easy more nerves than anything, one thing one should have on hand is alcohol just in case its needed. also if one doesn’t get the entire tape strips out, use the alcohol like suggested and lift the battery up. Then can grab the remaining tape strips with tweezers and pull it out. Easy to put back together just make sure the connectors are in. The screws are tiny so take your time. I plugged it in and it started charging and it worked. Great to have my 6 back for a trip as I wanted to use it for the camera, also my game phone so nice to have a battery that lasts. Yes having a flat place to put the parts and put them in separate area so they don’t get mixed up. It took about a hour with hunting for a spare bottle of alcohol.
    Greg Wischmeyer - 回复
    The first step should always to be to backup your phone as there is always a slim chance that even a simple battery replacement may render the phone inoperable and data on it lost.
    Jim - 回复
    Please do not forget to remove the SIM-Card tray!!
    Steffen Albrecht - 回复
    I didn’t need to remove my sim card tray when I did my iPhone 6 battery replacement. Why do you suggest to remove it?
    Jim -
    You dont need to remove sim card while battery replacement
    bertan - 回复
    Did mine today, with iFixit battery and iFixit tool kit. Did not need suction cup, to open case, as it had partially sprung open on left, as a result of a badly swollen battery. Supported base and screen with a bookend and rubber bands. This kept these parts at a 90 degree angle, so that screen did not need to be removed. IFixit screwdriver tips were perfect fit. Somewhat difficult to remove battery adhesive strips, but slow and steady got it done, after mild heating with hair dryer. Took about 3 minutes to reposition battery connector…just a wee bit tricky, to position correctly. Was careful to place top of screen in place first, and remainder snapped into place with light pressure, and replaced the 2 pentalobe screws.
    Will highly recommend iFixit for such a repair. Repair kit and battery, are first rate. I give this an 11, out of 10.?
    Len Drasin - 回复
  2. iPhone 6 LCD屏幕面板的更换, 给屏幕粘胶带: 步骤 2 中的图像 1,3 iPhone 6 LCD屏幕面板的更换, 给屏幕粘胶带: 步骤 2 中的图像 2,3 iPhone 6 LCD屏幕面板的更换, 给屏幕粘胶带: 步骤 2 中的图像 3,3
    • 如果你的屏幕玻璃碎了,可以使用胶带粘住整个屏幕,防止玻璃碎屑伤到你。
    • 使用胶带粘满整个iPhone屏幕,直到覆盖整个显示屏。
    • 这可以固定住玻璃碎片,保持结构完整,给接下来的维修提供方便。
    • 戴上护目镜,以保护你的眼睛免受任何在修理过程飞溅的玻璃碎片。
    • 如果破碎的玻璃在接下来的几个步骤中使吸盘很难粘住,请尝试使用强力胶带(例如布基胶带,然后用其提起显示屏。
    In case of broken glass you can make the suction cup much more effective by covering the glass with a broad piece of translucent tape which eliminate air leakage through cracks in the glass.
    lionno1 - 回复
    Il n’est pas nécessaire de mettre beaucoup de scotch.
    Au contraire plus vous mettez de scotch, plus il y aura de défauts et la ventouse ne collera pas.
    Une bande bien positionnée suffit.
    Chloé Bossuette - 回复
    I’ve used hot glue on low setting to remove all types of crystals. The hot glue will release with a little iso alcohol. No damage to glass or plastic faced crystals or screens. Use a narrow piece of wood as a prying handle.
    Emilio Gonzalez - 回复
    I recently had issues with removing the glass with the suction cup. I have done this many times with older generation iPhones but this time the glass seemed sealed on quite solidly. I told myself that the last option would be to use the screwdriver tip. After all my attempts, I transitioned to the option of using the screwdriver tip. Surprisingly, it was the easiest thing ever. I placed the 1mm flathead screwdriver at the interface between the glass and the cover (normal start location) and pried up very gently. Voila, the glass came up and I can’t even notice any dents or scratches. It felt much easier than the suction cup technique. If the suction cup is giving you a hard time consider using that 1mm flathead.
    forhereyesonly - 回复
    This is definetly the best option to open this thing up. I’ve spend 30min with trying to heat it up and remove it using the suction cup. I needed 3sec with the 1mm flat screwdriver and i t was’nt scary at all. No dents nor scratches here too. Thanks for your comment.
    Berggorilla -
    thank you!!!!!
    Adrian Phan -
    Great suggestion to use the screwdriver!! Thanks, it really helped
    obo12759 - 回复
    Duck Tape worked great for me. Thanks for the great instruction!
    Michael - 回复
    Tried several types of tape but finally used this screw driver solution. At first I wasn't pushing hard enough for fear of damaging things but with just a bit of extra force I was able to open it right up. Everything is fine with only a slight scratch on the frame.
    Wesley Shank - 回复
  3. iPhone 6 LCD屏幕面板的更换, 使用反向钳的流程: 步骤 3 中的图像 1,3 iPhone 6 LCD屏幕面板的更换, 使用反向钳的流程: 步骤 3 中的图像 2,3 iPhone 6 LCD屏幕面板的更换, 使用反向钳的流程: 步骤 3 中的图像 3,3
    • 接下来的三个步骤会用到反向钳,我们设计的一个让分离屏幕更方便的工具。如果你没有反向钳,跳过下面的3个步骤来寻找其他的方法。
    • 完整的反向钳的使用指导, 请参阅此说明
    • 将蓝色的手柄朝铰链的方向拉,以解除反向钳的分离模式。
    • 将支撑臂滑过 iPhone 的左边缘或右边缘。
    • 将两个吸盘放到Home键上方的屏幕——一个在前,一个在后(屏幕朝向自己的地方为前)。
    • 将上方吸盘向下压以施加吸力到目标位置。
    • 如果发现反向钳压在设备上的表面太滑或者不稳,可使用胶带来创造一个抓力更强的表面。
    I found that the single suction cup from the kit worked very well. It didn’t take that much force to separate the front panel from the phone. I think any suction cup that you are able to get a firm grip on will probably work as well. There isn’t any adhesive holding the front panel in. It just snaps in and out. If you have a cracked screen and no screen protector, it may be hard to get a good suction seal. If that’s the case, someone else here suggested applying clear tape to the front glass to get a good surface for applying the suction cup. In my case, I already had a screen protector that was still intact so the suction cup sealed easily.
    fiftysomething - 回复
    WORKED PERFECTLY… easy, no harm at all…. thanks a lot
    carlos restrepo -
  4. iPhone 6 LCD屏幕面板的更换: 步骤 4 中的图像 1,3 iPhone 6 LCD屏幕面板的更换: 步骤 4 中的图像 2,3 iPhone 6 LCD屏幕面板的更换: 步骤 4 中的图像 3,3
    • 向前拉蓝色手柄以锁定手臂。
    • 顺时针旋转手柄 360 度或直到吸盘开始拉伸。
    • 确保吸盘彼此保持对齐。如果它们开始滑出不对齐,请稍微松开吸盘并重新对齐手臂。
    • 当防夹产生足够大的间隙时,在屏幕下方插入三角撬片。
    • 如果反向钳无法形成足够的间隙,请将手柄旋转四分之一圈。
    • 不要一次旋转超过半圈,然后每两次之间要等一分钟。让反向钳和时间帮你完成剩下的工作。
    • 跳过接下来的三个流程。
  5. iPhone 6 LCD屏幕面板的更换, 手动打开手机步骤: 步骤 5 中的图像 1,1
    • 如果你没有反向钳这个工具,使用单个吸盘来分离前面板。
    • 将吸盘按压在屏幕上,位置在Home键的正上方。
    • 按紧吸盘以保障气密性。
    • 如果你的iPhone屏幕严重破裂,用一层透明胶带覆盖它可能会使吸盘粘住。 或者,可以使用非常结实的胶带代替吸盘。 如果所有其他方法都失败了,您可以用强力胶将吸盘粘在破损的屏幕上。
    This is nearly impossible on a screen that is shattered
    Erik Madsen - 回复
    You can put clear tape over it. it works.
    Owen -
    Try putting a strip of packing tape on the screen. That will make the surface smooth and help keep the suction.
    Joanna - 回复
    Argh!! Don’t put the suction cup over the home button to pull. While it works, it also breaks the screen at the weak point below the home button. Ask me how I know.
    -Tom
    tombuy - 回复
    How do you know Tom>
    Shawn - 回复
  6. iPhone 6 LCD屏幕面板的更换: 步骤 6 中的图像 1,1
    • 用一只手固定机身,另一只手轻轻地拉起吸盘,使前面板从机身上分离。
    • 不要着急慢慢来,用力要恒定、持续。iPhone的前面板固定得比大部分设备结实。
    • 在一只手继续拉吸盘的同时,另一只手使用塑料撬棍轻缓地将前面板和机身后盖撬开。
    • 前面板由数个卡口固定在机身上,所以需要吸盘和撬棍共同用力来拆下前面板。
    Pulling up on the suction cup helped get me started, but what worked for me was pulling up gently while sliding the plastic prybar gently along the seam towards the top of the phone (on both sides), and it came open without having to put excess pressure on the suction.
    lauren carroll - 回复
    Same here, just open the gap a little with the suction cup and then use the opening tool on both sides.
    Tobias - 回复
    Along with the suction cup I used some Command adhesive strips to hold the bottom of the phone to a workbench as they easily pull/stretch away when you need to remove them!
    Dion Sosa - 回复
    That’s a very clever idea, thank you!
    Megan Telliano -
    I did this too and left it throughout the repair. Super easy, and prevented phone from slipping and damaging the display cables.
    Felicia Johnson -
    Suction cup pictured here is the older version (with ring). I have one from my previous battery replacement on iPhone 5 and used that instead. The new one (gray with blue handle) kept on popping off. Overall, popping out screen was not as hard as it seems with these instructions, but do proceed with caution.
    youmingc - 回复
    Dion's idea to use removable adhesive strips was great, even better, use it to attach the iPhone to a clipboard. This will allow for a sort of Lazy Susan function while you work. I also used adhesive strips to attach my iPhone box to the clipboard as well and used that as a back rest (with rubber band) for the screen as pictured in steps below. This allowed me to very comfortably skip steps 13-19 as others have commented.
    Adam - 回复
    The new suction cup (plastic handle) is not so suctiony. Prepare for this thing to pop off a couple of times when opening the case.
    Chet Seidel - 回复
    Be very careful because it feels that it holds very tight but with the last pull it can fly away.
    Kristaps Grinbergs - 回复
    Be very careful when you pull up the display! Do not keep your other hand on the display surface or you can broke it!
    Luke Man - 回复
    I did all the suggestions here and it just wasn’t moving until I repositioned the suction cup up over the home button for more leverage. It finally came up enough to slip the plastic opening tool under the edge.
    Alan Derrick - 回复
    Well, my glass immediately and easily shattered. The only reason I’m attempting this is because Apple didn’t have time and the kids at Best Buy, while they accepted my appointment, admitted they had no idea how to actually do it. So… I’m off to Apple to spend a gazillion dollars I don’t have on a new iPhone.
    scottrell - 回复
    dont have a panel so idk know cant buy one help please !!!!!!!!!!!!!
    Kemonie Elliott - 回复
    Suction cup with blue handle is so stiff it would not hold a suction. I ended up putting it in very hot water for about 5 minutes before I was ready to use it, that did the trick.
    lgjerry - 回复
    The MORE iFixit plastic tools you have available for this step the merrier. It was effortless with two.
    Michael Russo - 回复
  7. iPhone 6 LCD屏幕面板的更换: 步骤 7 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 7 中的图像 2,2
    • 拨动吸盘上的塑料栓来解除真空密封状态。
    • 从前面板上取下吸盘。
  8. iPhone 6 LCD屏幕面板的更换, 打开手机: 步骤 8 中的图像 1,3 iPhone 6 LCD屏幕面板的更换, 打开手机: 步骤 8 中的图像 2,3 iPhone 6 LCD屏幕面板的更换, 打开手机: 步骤 8 中的图像 3,3
    • 以屏幕顶端为支点,从屏幕底端掀起前面板。
    • 顶部边缘的数个卡扣会起到类似铰链的作用。
    • 重新组装前面板时,将前面板的卡口对齐机身顶部,然后将前面板向屏幕顶部滑动,直到其上端与机身后盖完全扣合。
    It's not clear from the instructions but it is shown correctly in the pictures: when the front panel assembly is just open (at a small angle with the rear case) pull the top edge clips out of the rear case to slightly separate the two components, then swing the front panel assembly away from the rear case. I assume not doing so would potentially damage the connecting ribbon and/or the alignment clips. Just a guess...
    ethanlust - 回复
    Yes! I wish I had read this before working on my phone. I read the instructions as they are and slowly started to open the case. This is when I heard my screen crack. So in the future, slowly open and when you are about 40% of the way, pull the screen forward so that the top clips pull away (we are talking a cm at most). Sigh just ordered a new screen
    Albert -
    Ein Tipp zum Zusammenbau: Das Display ca. in 45 Grad halten und vorsichtig an die obere Kante des Gehäuses drücken, bis es bündig und glatt anliegt.
    Dann das Display langsam und vorsichtig anklappen und die Clips von oben nach unten festdrücken.
    SAS - 回复
    This entire process went smooth. Final step of re-assembly , the assembly does not seat into the framing. The white gasket seats on one side not the the volume button side. Alignment looks good. How much pressure does one apply on the reassembly?
    Bruce Fournier - 回复
    My problem is the front panel does not want to joint together with the rear panel… it feel like the front is too big but it look perfect but does not clip in place… Help…
    Tony Chicoine - 回复
    same problem, in the final step, the screen does not fit entirely. it looks like the size is not 100% correct, but 99%… one side of the case stays open…
    Andrea Andreoli - 回复
    Same thing here, with a new screen it doesn’t fit quite right during re-assembly. It sits just a little bit higher and doesn’t look seated.
    Adam Carl - 回复
    Some people have noted that the screen doesn’t seat properly on the case. Here’s how I solved it:
    The issue is that rectangular brackets on the back of the display aren’t latching with the corresponding clips in the base. I think the brackets are missing the gap between the spring plate and bracket with the latching bumps on it on the base. Here’s my solution:
    Position the top of the display slightly below the top of the case so the clips on the back top of the display start to engage with the phone case. Important: don’t push it all the way up!
    Now press both sides of the top part of the display until the display seats on the back. Make sure both sides are flush with the case.
    Repeat for the middle of the display. The bottom of the display will remain bent up because it will interfere with the bottom edge of the case.
    Now push/slide the display up so the top of the display lines up with the top of the case. The bottom should then snap into the base, and the display should be flush with the case all round.
    nigel - 回复
    Yes - important to get those two rectangular brackets in place first but not all the way as you say.
    JustinO'Brien -
    Hola soy de Guatemala Me pueden ayudar a saber si puedo cambiar las partes de un A1589 a un A1549 iPhone 6
    alvarezgarcialuizfernando - 回复
    Good thing am reading this prior to beginning any disassembly or re assembly. Thanks guys for the great tips
    Anthony Arenas - 回复
  9. iPhone 6 LCD屏幕面板的更换: 步骤 9 中的图像 1,3 iPhone 6 LCD屏幕面板的更换: 步骤 9 中的图像 2,3 iPhone 6 LCD屏幕面板的更换: 步骤 9 中的图像 3,3
    • 将前面板掀起至垂直,并且在你处理手机其他部分时用什么东西支撑撑着它。
    • 必要的时候,一听没有打开的罐装饮料可以很好地完成这个任务。
    • 用橡皮筋将前面板与支撑物固定住。这可以避免拉扯到显示排线。
    A picture is worth a thousand words! This idea at Step 9 is perfect and you can definitely do the entire rest of the battery replacement WITHOUT having to disconnect the display from the rear case. Just leave it secured exactly as shown in this picture and you're good to go. I just completed the repair and the most difficult part was just lining up the new battery connector! Excellent instructions and generally EASY repair because this step was so helpful!
    Ryan - 回复
    I did the same. Made the work go so much smoother!
    dcommins - 回复
    I do NOT recommend leaving the display and the rear case connected during this repair. If you run into any resistance removing the battery, or slip in the least removing it, you risk tearing the ribbon cables that attach the two pieces. I did and now I've got to replace the Front Camera and Sensor Cable. Sadness.
    Ergolad - 回复
    This procedure does not require the removal of the battery, so your comment is not applicable unless the batter is being replaced.
    Douglas Fichtner -
    I'm going to try it this way, because the odds of damaging the connector during removal seem greater than the risk of ripping the cable, however, I plan to cradle the phone in the "L" of simple, sheet metal bookend, and secure it using blue painter's tape. Seems more stable.
    bobcloninger - 回复
    If you do this step carefully- (rubber band the front panel, and carefully peel away the battery adhesive) you can SKIP 13 THRU 19!
    Larry House - 回复
    Rubber band and a large can of soup held the front in place. Go slow, steady firm pressure. Take the vibrator out though. Makes pulling the adhesive tape out much easier. Great video and written instructions!
    Sherman Homan - 回复
    I do NOT recommend leaving the display and the rear case connected during this repair. If you run into any resistance removing the battery, or slip in the least removing it, you WILL tear the ribbon cables that attach the two pieces. I did and now I've got to replace the Front Camera and Sensor Cable. MUCH Sadness.
    todd adelman - 回复
    Exactly!!!!!
    Bunny -
    I decided to do the repair on my iPhone 6 without detaching the screen. I ended up screwing two pieces of 3/4” x 3” x 6” wood together at right angles. I used 2 rubber bands to secure the screen to the vertical piece and 1 rubber band to secure the base to the horizontal piece. One of the two adhesive strips broke and I had to really work to get the battery out. The rubber bands held everything together nicely. The wood pieces were slightly wider than the phone which made it easy to hold everything together while I was working the adhesive strip out.
    brian - 回复
    Mine worked great install went perfect. Was like a new phone… for a couple months. Phone may be failing for other reasons, but there’s a ghost image in the shape of the battery in the display now. Very strange. The ifixit kit did give life to it for a while though.
    smahar - 回复
    Hey Smahar! If you still have your tools, I’d recommend opening your phone up to make sure the battery isn’t swollen. If it’s pressing against the screen, it’s possible that is the case. If it is swollen, I highly recommend you replace it, it can be dangerous to leave it in place.
    Sam Goldheart -
    I feel like I just pulled off a minor miracle, successfully detaching and reattaching those four connectors. In the past I have also used the lean-against-a-box variant. Now I carefully apply several short pieces of painter’s tape to create a temporary “hinge,” in combo with the lean-against-a-box variant. If the bottom piece could be SUCCESSFULLY SECURED [painter’s tape loops?] to my work surface this should avoid needing to deal with the four connectors. IMPORTANT NOTE: At the end of the day this repair will ALWAYS be about pulling the white stretchy adhesive tape out from under the battery. And again the painter’s tape comes into play. This last battery replacement when I started to pull out the two adhesive strips I also, several times, applied enough tape to combine the strips and form a single grab point. Also, removing the “vibration” block allowed the the pull angle to be insanely shallow. Slowly-but-surely, both strips successfully emerged and battery was totally released.
    Michael Russo - 回复
  10. iPhone 6 LCD屏幕面板的更换, 移除电池排线保护罩的螺丝: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    $19.95
    购买
    • 卸下电池排线固定架上的两颗十字型螺丝。
    • 一个2.2毫米螺丝
    • 一个3.2毫米螺丝
    • 在你的维修过程中,请务必确认每一颗螺钉的位置,并确保安装的时候让螺钉回到原位,避免因型号不匹配对手机造成的损坏。
    #000 needed here
    Dave - 回复
    ok well what exactly does 2.2 mm and 3.2 mm mean if a #000 is needed? why even mention those numbers?
    Cory Berends -
    Those are the screw lengths. They’re important to mention so that you don’t put the longer screw in the wrong place. If you start mixing up screws, you can end up with permanent logic board damage.
    Jeff Suovanen -
    I replace the antenna in the upper left-hand corner an in the bottom middle with the lightning connector because After disassemble it completely i lose my ability to have Cellular. After i replace both antennas i can find i nevertheless have cellular. anybody an idea ?
    kupies2011 - 回复
    With the phillips screwdriver included in the repair kit I cannot unscrew any of the interior screws because it is not the right size even though according to these comments all of the screws are #000 and on the product listing it says that the screwdriver I got is #000. Any suggestions?
    Wilson Styres - 回复
    Sounds like you need to adjust your technique. The included PH000 driver works fine; I’ve done many many phones with it.
    Jeff Suovanen -
    Upon reassembly I found the Red 2.2 mm screw won't seat. Is it possible it sheared off? The Orange 3.2 is solid in both holes but 2.2 doesn't securely fit in either.. Should I just leave off the 2.2?
    smcgreg - 回复
    My phone was missing this screw also!
    Gail Starr -
    Duh, had the cover on the wrong way. Switched it around and the screw fit. (:
    smcgreg - 回复
    When I insert the 3.2 mm screw... The phone shuts down, very weird because am not seeing what could cause this short...
    Juan Monge - 回复
    I’m having the same issue. Thinking about just leaving that screw out. Did you ever get your’s working?
    Cavell Blood -
    Using the Phillips 000 screwdriver included in the kit, I am able to remove the 3.2 mm screw, but not the 2.2 mm one.
    Dan Solovay - 回复
    None of the screwdriver heads in this kit are big enough for these screws!!! I now have an open iphone and i have to go to the store to buy a different screwdriver..I do not recommend this
    Elaine Eason - 回复
    I was unable to unscrew the 2.2mm screw with the provided screwdriver. I was able to unscrew the 3.2mm screw but not the 2.2mm
    Jameison Martin - 回复
    what did you do, i have the same problem i don’t know what to do. I should have read the comments at first now I am left with an open phone
    Francky Maemble -
    I'm stuck in the same boat here. The one screw came out no problem but the second isn't catching at all.
    Brian Adams - 回复
    Stuck with Jameison and Brian here... 2.2mm won't catch with all three provided screwdrivers.
    Matthijs Rog - 回复
    Agreed, the screwheads included in this kit didn’t work for me either. Fortunately my own toolbox has an appropriate screwdriver…. Seeing as how we are paying for this kit so we don’t need to purchase extra tools, iFixit should really include screwheads that actually work!
    Priscilla Cheng - 回复
    When putting everything back together, I took care of steps 10-12 (or, more accurately 12-10) after reinserting the SIM (so between steps 20 & 19). It was easier to do before dealing with reconnecting the screen.
    dhcohen67 - 回复
    why do i buy a kit from you guys but you don’t provide the necessary tools for unscrewing
    i dont have any screwdrivers at home the 2.2mm simply wont come off its ridiculous now i just have an open phone
    Michael Amara - 回复
    I had to use Phillips #00 for the 3.2mm (orange) and #0 for the 2.2mm (red). The #000 screw driver came in the toolkit is useless on both screws so I had to go out and buy new ones from a hardware store…
    Tung-wei Lin - 回复
    My two screws are the same diameter - 1.1mm, taking a Philips PH000 driver. However the one toward the middle is 3.3mm long, the one nearer the side is 2.2mm long.
    Alastair Lack - 回复
    So my kit didn’t come with the right screw driver, I should have read the comments first before buying.
    My iPhone 6 battery connector bracket has 3.2mm which the PH000 works. But the 2.2mm didn’t work with included Y000.
    What screw driver do I need for the 2.2 mm screw??
    John Palaganas - 回复
    The heads on both of those screws are identical. The included PH000 is the correct driver. There are no Y000 screws anywhere in the iPhone 6.
    Jeff Suovanen -
    The Phillips in the repair kit worked fine. I did 2 phones with it.
    Eric Craumer - 回复
    Just a followup to all the comments above for anyone who is confused: the drivers included in the repair kit work fine, assuming you know how to use a screwdriver correctly in the first place. There are quite a few folks who never learned, and that’s nothing to be ashamed of—in fact it’s common enough that we made a guide for it. Those bits were designed first and foremost to work with iPhone screws and have been extensively, extensively tested. You may come across stubborn screws or strip the heads if you’re not careful, and maybe that’s why some folks here are having trouble. In the very rare event that you actually received a malformed bit of some kind due to a manufacturing defect (which should be clear just from looking at it up close), reach out to customer service and they’ll get you squared away.
    Jeff Suovanen - 回复
    I just completed the battery replacement and I too found that the PH000 did not sit properly in either the 3.2 or 2.2 mm screws. Using a magnifying glass it seemed that the PH000 driver bit did not sufficiently fill the space of the screw. I happen to have the iFixit Pro Kit and used the PH00 driver bit instead, and this seemed to fill the space of both screws much better leading to successful extraction and replacement. My lack of experience with phone repair may have been a factor, but it seemed at least for my particular phone the PH00 was the proper driver bit for these two screws.
    Jimmy Doi - 回复
    The PH000 screwdriver I received cannot remove the smaller screw…
    Michael Pesenti - 回复
    So I spend 34 bucks on a kit of tools to repair my phone and they send the wrong sized screwdriver to get the battery cover off. Awesome. I can get the larger screw out but not the smaller one. What a waste of time and money.
    @michael_pesenti Those screw heads are the same; the screws are just different lengths. If you have the right driver for one, you have the right driver for both, unless someone put your iPhone together with the wrong screws.
    Jeff Suovanen -
    @jeffsu
    Nope. Actually turns out that ifixit just sent me a defective screwdriver that only was poorly sized and only managed to catch one of the screws. I had to order a new PH000 Screwdriver on Amazon and it got the screws out instantly and I was able to repair my phone.
    I used the “Maximum” precision set from Canadian Tire and the PH#00 works nicely for both these screws.
    Matt - 回复
    Screws in mine required different size drivers also - maybe because refurbished? But have had the same probs on mbps also. Felt silly but followed Jeff’s suggestion to look at the screwdriver best practice guide and realised I was stripping screws by using too small a driver - have a couple either side of the suggested size and use the largest one that catches - I mainly used PH#0 & 00, though some screws needed #000, and there wasn’t any consistency to which screws needed which driver.
    Trish - 回复
    You’ll want to secure each screw as you remove it - if you sneeze they will fly away and you’ll never find them. I recommend having a small bowl or container for each screw you remove and label them for reassembly.
    I was worried about getting the screws mixed up, so I used Sharpies to color-code each screw before I removed it (red, orange, or yellow - corresponding to the iFixit illustrations) When I marked the screw, the bracket got some color on it too, so when I was replacing the screw, I was confident that I was putting the right screw into the right position.
    I also made a template-board by tracing an outline of the phone in the center of a piece of cardboard, and then gluing pieces of masking tape onto the cardboard, sticky-side up, one piece of tape for each bracket I removed. I drew an outline of the part on the tape, and made a red or orange or yellow dot for each screw that came from the bracket. It made it super-easy to keep track of the disassembly and reassembly. Took a little longer, but I didn't damage the logic board by using the wrong screw, and I was relaxed throughout the repair.
    GPS and WiFi now work perfectly!!!
    Thank you iFixit and commentators
    Paul Austin - 回复
    Funny my one screwdriver fit all the screws with no problem!
    Thomas Hayes - 回复
    @Paul Austin: colouring the screws is a galaxy-brain tier idea, I will definitely be doing this!
    povman - 回复
    Are you just out of luck if you start to strip a screw? The first, 3.2 mm came out easily but the 2.2 mm is a little worse for wear. I’d be grateful for any tips you might have.
    Andrea Nixon - 回复
    Turns out the included PH000 head does work with both screws. They are both the same size gauge; only difference is the length. I had the same kind of trouble as most others trying to unscrew them. But if you carefully apply consistent direct downward pressure as you turn, the screw does disengage and unscrew. It helps to stand up over the work for more leverage. And it aids in keeping the screw driver head in full contact with screw head, so it doesn’t slip and strip the head.
    ARNOLD SCHWARTZ - 回复
    I am surprised by all of the comments about the screwdriver bits being the wrong size - I have done several iPhone repairs now with the tools provided by iFixit, and the screwdrivers work perfectly for me every time.
    Joe - 回复
    I bought the Ifixit tool kit on amazon for $70 and i don't see any 3.2 mm or 2.2 mm in the black box. does anyone know what screw i am supposed to use because i have no idea what i'm doing wrong. I opened the bottom screws on the Iphone 6 just fine but for the inside screws i dont see 3.2 or 2.2. can anyone help me? i hope I didnt waste $70 on the wrong thing.
    YuhBoiiJay - 回复
  11. iPhone 6 LCD屏幕面板的更换: 步骤 11 中的图像 1,1
    • 取下iPhone的金属的电池排线托架。
    Why in the YouTube video do you skip removing the battery connector
    mjcoughlin70 - 回复
    The YouTube video could use an update, but unfortunately YouTube does not allow that. Always disconnect the battery before disassembling anything else.
    Jeff Suovanen -
    One of the screws is longer than the other, use it for the higher inside hole.
    Bobby Slone - 回复
  12. iPhone 6 LCD屏幕面板的更换, 断开电池排线的连接: 步骤 12 中的图像 1,1
    • 用塑料撬棍从主板上撬下电池排线的接头。
    • 注意只在排线接口上用力,不要伤到主板上的接口插座。如果你撬到了接口插座,你可能会直接把接口弄坏。
    I skipped steps 13-19 and just left the front panel rubber banded while I removed the battery. I just made sure to be careful while removing the adhesive strips so as not to move around the body of the phone too much. Skipping the steps made the whole process much faster and easier.
    Tonima Chaudhury - 回复
    I wish I had done that.
    Gail Starr -
    Thanks for this awesome tip. Made the replacement go much smoother - saved me from removing all those other screws. I also recommend watching the ifixit battery adhesive strip video before proceeding with step 21.
    Andy Milne -
    Me too, no need to detach the screen (when you take care),
    Tom Long -
    In trying to replace my antenna flex cable, I attempted to skip steps 13-19 but eventually gave up around step 31/32 as I simply didn’t have the access I needed - the space was just too cramped with the screen still attached and I was afraid I would break something. If you’re a novice, don’t have good lighting and a magnifying glass, etc. you may just want to go ahead and perform 13-19. (Yes it will take extra time of course.)
    Perrin Haley -
    I also skipped steps 13-19 after reading the first comment.
    youmingc - 回复
    I skipped those steps too and was successful. Thanks for this tip!
    jaksbackpack - 回复
    Can disconnecting the battery connector while power is on ruin the backlight? Or can disconnecting the power connector at a different stage ruin the back light?
    mitch Toler - 回复
    You should power down the phone before disconnecting the battery. That said, the backlight should be fine. A blown backlight circuit is most commonly caused by disconnecting the display when the battery is still connected.
    Jeff Suovanen -
    I did open the lcd without disconnecting the battery and my lcd wouldn't working
    Reza I. Permana -
    Thanks for that tip Tonima! This is another confirmation that skipping steps 13-19 worked out great!
    As an extra measure, in addition to leaving the front panel rubber banded in it's open, vertical position (I secured mine to a can of beans) and being very careful and controlled when removing the adhesive strips; before using the suction cup to separate the front panel from the rear case, I had secured the back side of the rear case to my working surface (kitchen table) with a strip of folded over duct tape (creating double sided tape). Such might not have been necessary as I held the rear case with one hand while removing the adhesive strips with the other, though it just felt safer having the rear case (as well as the front panel) well secured in place to help assure that I didn't accidentally cause any damage to those very fragile looking cables that were left connected, by any possible movements of either of the iPhone's halfs during the pulling to remove the adhesive strips.
    Russ Levey - 回复
    It happened to me, by prying the battery connector with another tool I broke part of the socket off the board. However, by placing it exactly back in place the connector could be placed correctly and it works. Lucky.
    Udo Schuehle - 回复
    I'd like a little more explanation on how to re-attach the battery connector. But in the end I lined it up and pressed gently down till it snapped into place.
    Garret Gray - 回复
    I skipped the steps removing the screen only because I didn't feel confident at all doing this. For someone who is used to electronics I would really suggest removing it because I imagine the whole process would've been easier. If there's a next time, perhaps I'll do that.
    Garret Gray - 回复
    The suggestions that recommend skipping step 13-19 apply to some other repair. We replaced the display, and to do so, steps 13-19 are, of course, necessary.
    Gabriel Zachmann - 回复
    When replacing the battery you should prepare the cable to sit in exactly as you see it in the picture. I had mine all the way back in (with sticky strips) and had to find a way to fit the cable in with the weird way it bends. Dry fit the battery with cable in place - lesson learned.
    Chet Seidel - 回复
    Good idea. All the instructions were great until I got to the last thing- reattaching the battery connector! I like your recommendation to dry fit the connector so you can get the right bend to the connector ribbon first.
    Tom Rohrer -
    I wish I had seen this also, I feel like this should be in the guide. Mine seems to be working out but I had to force the connector into place a little bit.
    Kevin Harvey -
    I wish I had seen this first! I also had the issue, now I have a permanent discoloration of the screen where the connector is pushing against the back. Hoping that it doesnt lead to other problems. This site is really lacking on the reassembly steps… shame..
    thomasjmaclean - 回复
    I'm just wondering if my computer would still recognize my phone with the battery disconnected?
    Sare - 回复
    It appears that I haven’t properly connected the battery back up, since the hard reset didn’t work. I did my best to connect the battery before adhering it to the battery spot, but the connector doesn’t seem to “click” or otherwise confirm that it is properly positioned. The left side of the connector (closest to the battery) seemed slightly raised, which made me wonder if I had done it correctly. So I’m probably going to have to try using my last adhesive strips to lay it in better to allow for a better connection. I’m also worried that I may have damaged the connection spot. Is there anywhere on here where this is discussed? This is my second battery replacement, but first on this particular phone, which is apparently a refurbished one (and which has a slightly different looking connector cover).
    Alex Kosmider - 回复
    Ah, it helps to discover that it’s actually a 6S rather than a 6.
    Alex Kosmider -
    For those of you replacing the Digitizer you to need follow steps 13 - 19.
    lowestseries - 回复
    Doing a lightning connector replacement - skipped steps 13-19 as well. No problems.
    cambo.robertson - 回复
    Hello, Is it necessary to do step 13 to 18 if I only want to change the battery?
    What does can happen if I don’t make all step?
    Juan - 回复
    I can’t seem to get the battery connector to connect to the logic board. Is there some reason it doesn’t click or do something to hold it in place before the battery connector bracket?
    Leif Rambjor - 回复
    @lrambjor No special technique; just line it up and press down, and it should snap into place. Make sure there’s no dirt/debris in the socket; give it a blast with some compressed air if needed. And make sure you’re not trying to jam an iPhone 6s battery into an iPhone 6 (or vice versa)—they aren’t compatible.
    Jeff Suovanen -
    So her guys I skipped 13 but when attaching the ribbons( which is the LCD,camera etc ) I got a little smoke while trying to attach the ribbons and now i am not seeing anything but the phone is vibrating and coming on but i cant see anything
    What is the reason
    juniour Bowens - 回复
    Who are you kidding? Plastic tool” is cute, but totally useless for lifting that battery connector off the logic board. But the smaller of the four long-handles Metal tools iFixit sells as a set worked perfectly well.
    Michael Russo - 回复
    Reattaching the battery connector was one of the more difficult parts of this repair. Once you place the battery on the rear cover and the adhesive sticks you cannot make any adjustments to position (even though I tried to just place it as lightly as possible at first). I did a dry run attaching the connector and placing the battery before removing the adhesive cover but I did not get it to sit the quite the same after removing the cover. I had to fiddle with the battery connector quite a bit to get it in place.
    Raymond Rinaldi - 回复
  13. iPhone 6 LCD屏幕面板的更换, 移除前面板排线保护罩的螺丝: 步骤 13 中的图像 1,1
    • 卸下前面板排线固定板上的五颗十字型螺丝。
    • 三颗1.2 mm螺丝
    • 一颗1.7 mm螺丝
    • 一颗3.1mm螺丝
    • 安装过程中错误放置螺丝会造成iPhone 主板永久性损坏。
    Be careful when replacing the screws, not to accidentally put the 1.7mm screw into the center hole, where the 1.2 screw belongs. This can cause "Long Screw" damage, and render your phone unusable.
    damianodessgillett - 回复
    I don't have the magnetic pad but use duct tape face up in a tray. I write the step number and color of the screw on the sticky surface and let the screw stand heads up on the goo. The screw is presented for the driver when reassembling.
    griffn - 回复
    I seriously draw a picture of the part, and mark where the screws belong, then place the screw on its location on the drawing! I so don’t want to screw it up(no pun intended)
    lisa OBrien -
    Can't stress enough how important it is not to mix up these screws! Using the 1.7mm screw for the lower left fixing will cause "long screw damage" and kill the backlight on the phone. I believe @damianodessgillett made the same point. Wish we could display a small warning message here to be extra careful for future fixers!
    kev - 回复
    I use a screw ID technique similar to griffn's; I print out the PDF version of the guide, then Scotch-tape each screw type to the guide at the step where the screw was removed. The screws are then distinguished by size and type at the point where they need to be reinstalled.
    adlerpe - 回复
    i am trying but only could open 2 screws and cannot open the rest of them, can you help me??
    girlsrock742 - 回复
    @girlsrock742 - I'm new here, but from what I've seen, questions like yours don't get answered. I have 2 suggestions:
    # Be more specific about what your issue is.
    # Make sure you're using the right screwdriver. (Get a magnifying glass & make sure the screwdriver fits nicely in the screwhead.) This guide is included in a guide I'm looking at, and my guide has a comment that #000 phillips is required for the battery connector bracket above, not #00 as documented. (That comment did not convey to this guide....)
    Good luck!
    Bass Clef - 回复
    Nate, you are my hero at the moment! Phillips head screw driver PH000 resolved my issue. Greatly appreciative of your chiming in on this comment! Appreciatively, C.
    Carol N -
    Thanks to @griffn & @adlerpe! I've updated the tools list to include the magnetic pad, and -- for us infrequent fixers -- I made a note in the intro text to describe the sort of thing you two noted here in place of the mag pad.
    Also, to @damianodessgillett & @kev - I've submitted an update to the instructions to add the caution you recommend to the step. Hopefully others will avoid the pain of the Long Screw damage.
    Bass Clef - 回复
    It's possible to damage only a slot of flex cable ? I've opened my iPhone 6 but now front camera, speaker and the proximity sensor are not working. I've bought a new flex cabe to test it, but I have to be sure about that.
    cruz.giovanni - 回复
    I'm so worried I'm going insert the wrong screw. Does anyone have any suggestions to knowing how to properly tell the size of each screw? I bought a screw set and a magnetic pad but still have the same issue. Not knowing the correct placement of each screw. I'd definitely appreciate any help.
    Patric - 回复
    Hi Patric! We use a set of calipers to measure our screws, failing that you could use a very fine ruler. If you don't have any kind of measuring equipment, line the screws up on the magnetic mat and sort them by size there. Ideally you only have screws from this step! If you are trying to determine the size of all the screws in this guide, it's probably best to get a real ruler/caliper for the fine distinctions.
    Sam Goldheart -
    Do you have to remove the display to replace the battery?
    Michael Aguilera - 回复
    It's not absolutely necessary to remove the display, I kept my display propped up throughout the operation. Removal of the display doesn't seem to offer any particular benefit, unless you have problems with the adhesive strips.
    Adam - 回复
    I agree that it is not necessary to perform steps 13-19. I just successfully replaced my battery and skipped steps 13-19. I kept the screen assembly out of the way be securing it with a rubber band to a heavy candle jar. Note that even Gwendolyn, in the video for this batter replacement, does not mention disconnecting the screen.
    Robert Blackburn -
    Hi. I messed up with the screws in the cover guard sheet for the display ribbon and my iPhone 6 plus isn't turning on. Does that mean the logic board is dead or the battery ? Should I throw the phone in the garbage can ?
    nzf - 回复
    Did anyone even answer your question? I'm having the same issue
    Sare -
    I can confirm it's not necessary to remove anything other than battery bracket. If you support the screen against something as in the picture, just make sure you hold the iPhone absolutely still with one hand while pulling out the adhesive strips with the other. I also used a small piece of tape to hold the screen in place against the box while I worked.
    I am now a very happy customer and am looking forward to another few years life from my awesome iPhone 6!
    Matt Whiteley - 回复
    There is no need to do this step. No need to remove these 5 screws. Just make sure the screen is propped up against something strong and this step is unnecessary for the proper removal and re-insertion of battery.
    arunhn - 回复
    100% agree. Step 13-19 are totally unnecessary and just adds the risk of breaking the display connector. “Don’t disassemble stuff that doesn’t need disassembling.” Just ensure there’s no strain on the display cable when removing the battery, i.e. by placing the phone on a non-slippery rubbery surface and fix the display to something sturdy with rubber bands.
    Dormouse -
    I left the front panel connected and it was much quicker. But, if you have to wrestle with the battery, it is much safer with the front panel removed. If you have worked on a few phone before, I'd try removing the battery with the front panel connected. If the battery is giving you problems(like if you tear the strips and have to heat the backside), you can always come back to this step.
    Joel Horie - 回复
    I strongly recommend you leave the display connectors alone if you can. My battery came out without a fight, but I found the display connectors to be almost tragically delicate, and I had white lines in the display when I booted it. During the subsequent attempts to remedy that situation, things went down hill and now I'm waiting for an entirely new display to try to rescue the phone from repair oblivion.
    kevin hekman - 回复
    I also skipped all of the screen-removal steps and had nary a problem. Just rubber band the screen around whatever it is propped against and I believe you'll be fine.
    Billy Bob Baler - 回复
    Hello! I put the screws on in the wrong order and I believe my backlight is dead, iTunes still recognizes my phone when I plug it in, but the screen is blank. Is it possible to replace the logic board or is the phone useless forever?
    Tanya Lyn Willard - 回复
    You probably connected the cables wrong, try doing this step again and carefully correct your cables.
    June Beltran -
    Remove each screw, tape it to a piece of letter paper, mark what spot it came out of. red, yellow, orange and the 3 reds. This way you can not possibly put them back in the wrong spots.
    smahar -
    I totally recommend doing this step first before removing the battery connector bracket, it will be much easier and comfortable with the screen out of the way.
    Also I recommend drawing the bracket on a piece of paper and place the screws on top of the respective position on the drawing, this way you won't be confused when putting them back.
    June Beltran - 回复
    I accidentally lost a 1.2mm screw while doing a screen replacement. Will this make the phone malfunction in anyway after I close it back up or its fine?
    Walter White - 回复
    DO NOT DO THIS STEP. It is totally unnecessary to remove the connectors, and they are a really big pain to put back in, and there is risk of damaging them, and it adds a lot of time to the process of replacing the battery. Just securely prop up the front panel, and then if you gently heat the back of the phone when removing the adhesive strips, the battery comes off easily. I could have saved myself about 2 hours and a lot of frustration if I had just left these connectors in. I wish the instructions here would just include this step (connector removal) ONLY IF the battery doesn't come out easily.
    J Marr - 回复
    Exactly, just like J, Marr indicates, this step is not necessary. Just make sure you're careful to not move the phone too much, otherwise you can damage the film connectors. Other than that I even heated my phone to remove the adhesive, and thank God, nothing bad happened to it.
    Mc Floyd -
    It’s only necessary if you’re like me an need to fix the screen or water damage (mine fell in water…)
    jacobdanderson -
    Ergolad - 回复
    How can't you do step 33 if you don't do 13-19? iPhone 6.
    predylindsay - 回复
    This procedure is for replacing the iPhone 6 battery and there is no Step 33. You may have been referred to this page from another procedure. Keep that in mind while reading the comments here that may or may not apply to your original procedure.
    Don Lawton -
    I'm missing something here, I want to swap out the screen. How does one skip steps 13-19 if wanting to remove the screen?
    BW Lee - 回复
    This procedure is for replacing the iPhone 6 battery. You may have been referred to this page from another procedure. Keep that in mind while reading the comments here that may or may not apply to your original procedure.
    Don Lawton -
    Any tips for removing the 1.2 mm screws? Mine won't budge at all with the PH000 and I'm afraid I'm stripping the screws.
    MClare - 回复
    I had to use the larger bit for ALL of the screws as the small one was too narrow at the tip to actually grab anything. It worked but made it a bit more difficult.
    Heather Best - 回复
    Is it really necessary to remove the front panel at all, can't you just ask a friend to hold it in an upright position while you work on the battery?
    Peter - 回复
    I also skipped steps 13 - 19. Just be very careful not to apply to much stress to the connectors in between the screen and the base. For me I also used another box to keep the base from sliding around while removing the battery.
    Patrick Reed - 回复
    You cannot skip these steps, of course, when you want to replace the display (which was the kind of repair we did).
    When putting the little connectors in place again afterwards, I can recommend to hold the connectors to the display using a little rubber band. That way, they don’t get in the way when you put them in place one by one.
    You SHOULD do the steps of removing the display. I have done battery replacements on several dozen phones. Of the ones I did NOT remove the cables, 2 of them had issues directly related to components related to these cables (front facing camera, earpiece speaker, etc.). Although tedious, I recommend removing these connectors to prevent any short circuit when reconnecting the new battery.
    ACMT - 4 years.
    jonbessom - 回复
    I skipped this step and just affixed the screen to the Iphone box with a rubber band during replacement. I decided to take this risk to prevent some of the other issues that have been discussed when removing the screen. I understand it is risky because if you slip or need to use any significant force to remove the battery, disaster awaits. On my repair, it worked out fine and I ensured that I took my time and kept the bottom of the phone held to the worksurface.
    Michael Kirkpatrick - 回复
    There are only 2 screws when i opened mine.The centre one and the left top corner one..Is it okay to use it like that..Please help
    Naresh Annepu - 回复
    If you can try to leave your display how it is. I removed it and it ended with white stripes and touchscreen not working. After a while it touch started to work and stripes went away. I think it was static electricity.
    If you decide to go ahead with this step… I did it prior to removing the battery bracket and found it to be easier. Having the screen off made things a lot easier during the battery removal process.
    Eric Craumer - 回复
    Two of the screws are damaged and I can’t open them. What can I do to remove the bracket?
    L He - 回复
    Stay organized with the screws with just a piece of paper. Lay them out, mark ‘em up. Go slow, take your time.
    Sherman Homan - 回复
    I'm noticing some questions I have that others are asking yet no one is answering. You're all talking about the same problem that I find completely pointless. If you skip steps and it works, good for you move on. There are real questions being asked. Someone asked about losing a screw, would that effect anything? You all talk about the importance of having the screws organized, yet don't explain if someone either loses the screws or have them put into the wrong places. Since no one talks about it, I figured it wasn't as important as you all claim it is. Now my phone seems to not want to do anything anymore. Stop arguing with each other about something so miniscule like skipping steps. 40 comments on this part and 5 people actually have real problems but no answers. So, if anyone actually took the time to read this, my questions are; what happens if the screws are put in the wrong order?(other than the obvious long screw damage) and what happens if we put the phone back together without some screws?
    Sare - 回复
    @sarery I’m a little puzzled by your question. If you’re not willing to put the screws back in the right place as instructed, despite all the warnings in both the guide and the comments, why would you want to attempt this repair in the first place? But nevertheless I will try to answer. Some screws, if left out, have no noticeable effect. That’s the best you can hope for. Other screws perform a vital function such as providing a path to ground. Some screws are made of nonferrous materials—getting those mixed up can interfere with things like compass functionality. And putting a wrong screw pretty much anywhere can result in cross-threading or component damage. The reason we go to the trouble of providing all these screw markings and measurements is to help you put your phone back together in perfect working order. Which you may still be able to do, if you are careful, and patient. Good luck.
    Jeff Suovanen -
    Thank you very much for that information. That's all I and I believe some other people were curious about.
    That's what I thought this website was for, not post fighting over who's the smarter one and not putting others down. This isn't Facebook
    Sare - 回复
    well said Sare - perhaps if folk stuck to the subject instead of proving how clever they are (not) there wouldn’t be 44 comments to scroll through to find an intelligent answer
    philbjh - 回复
    For those who are removing the digitizer, you do need to remove the bracket to get access to cable.
    lowestseries - 回复
    Definitely do NOT disconnect the screen for the battery replacement!
    The battery replacement worked like a charm but now I am left with whit e stripes in the screen and touch screen functionality is lost despite many tries to get the screen reconnected.
    Indiana Jones - 回复
    Hello, well I accidentally put the screws back in the wrong order after replacing the charging port, phone turns on but stays on Apple screen, any suggestions? Thank you
    d.rando90 - 回复
    i have replaced my iphone 6’s screen twice now, first the phones fingerprint sensor wouldn’t work ( the original one ), so i replaced the entire screen ( new fingerprint sensor), but still doesn’t work and now the phones brightness is extremely dim on both screens. So now both screens now are dim and finger print sensors dont work.
    Regan Murray - 回复
    I have some issue with the 3.1 mm screw. Only this one can’t put it back, but I take off the metal that can turn it on. (I just feel 2~3 circle to turn the screw.) What it’s happen?
    AndyKao - 回复
    Bottom left 1.2 screw assembly broke off from the mother board and now my phone will not power up . Can there be another reason for the phone not switching on . How important to the function of the phone is the broken screw assembly ?
    Gary Brinkworth - 回复
    The phone will power on and work just fine without any of the screws in this particular step—the screws are for securing the bracket and keeping the connectors from popping out. I’m not sure what your issue could be, but a missing screw isn’t it! I’d probably start by reseating all the connections and giving it another try. Check the board carefully for damage. Try posting your question in our Answers forum with all the details and you may be able to get some troubleshooting help there. Good luck!
    Jeff Suovanen -
    Thanks for your reply
    even though the screw assembly has broken away from the mother board, this screw assembly was soldered in would not damage the back light or power to the phone ?
    Initially thought I would skip these steps, as many people said to skip steps 13-19, but I tried proceeding without removing the front panel, and my adhesive strips simply would not remove, even with heating….so off the front panel came. Putting it back (connecting the cables back) was definitely a little panic-inducing, but managed to do it without damage - definitely watch some youtube videos!
    Hannah Hyun - 回复
    Most companies standardize the screws on their products, but since Apple does not want you to fix your phone on its own, it has set a trap for you to damage it. I think that this criminal action may be entailing a lawsuit.
    br_flavio - 回复
    I have to use PH000 right?
    Aman Singh - 回复
    Xmas day here 2020 and i decided to skip separation of the screen from the base. got the battery out no problem. did remove the vibrator plate and felt that really helped to remove the adhesive strips. just keep the screen nicely propped up and you should have no problems. not seeing any reason at all to remove the cables and screen.
    keith florine - 回复
    Are there any other alternative i can use to unscrew the 1.7 mm screw?
    mormi mormi - 回复
  14. iPhone 6 LCD屏幕面板的更换: 步骤 14 中的图像 1,1
    • 从主板上取下前面板排线固定板。
    I can’t get the top left screw back in if the cable bracket. Any reason why. My phone has power and back light is coming on. But screen is blank
    Joan Fitzgerald - 回复
    In my case the top left screw - the orange screw - stayed in the front panel assembly cable bracket and would not come out. Later on I realized that the standoff screw which is underneath stayed fixed in the 1.7 mm screw. In fact this was no problem and I didn’t need to figure out how to remove the standoff screw at step 36. I just put it back in altogether and it worked fine. I actually removed both screws at once.
    Anja S - 回复
  15. iPhone 6 LCD屏幕面板的更换: 步骤 15 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 15 中的图像 2,2
    • 在接下来的四个步骤中,使用撬棒时注意只撬排线接口,而不是接口插座。
    • 使用撬棒或手指甲断开前摄像头和传感器排线接口。
    I can not get these electrical connections to reconnect. If there is some secret to this it should be noted. I now have a phone all taken apart and can not get it back together. It makes no sense to only give directions to take a phone apart and not to put it back together.
    douglas hughes - 回复
    Use sideways bright light and peek underneath as you mate the contacts to align properly. Press very gently and evenly. Others have written that too much pressure in the center may warp the contact.
    mahoffman - 回复
    I'm having the same problem as above...really upset and frustrated at this point. :( 2/4 connectors (top and right) will 'click' just fine...the other two (bottom two) for the life of me wont connect!!!! :( any suggestions? i feel like i have tried everything. Sucks that is only thing stopping me screen from being repaired....
    alyssaavaldezz - 回复
    Hi alyssa. Were you able to connect the cables? I am having the same problem
    Veronica del Rio -
    regarding cable connects - if two of the ribbon cables are not properly overlapped around each other, then it will appear as if cable #2 will need to plug into the closest jack, which is actually for cable#3. Look at the two connectors carefully - they are opposite gender and can't be interchanged.
    David Panak - 回复
    This is good advice, and usually the problem people experience here. There is a very specific way the ribbon cables are layered, and if not correct when reassembled, the reach of the cables will cause you to assume which cable goes where and to try to insert the wrong plugs into the wrong sockets. Please do not try to force them. If they don't snap in easily, examine them closely, and you'll see the plugs and sockets are slightly different sizes, with one wider than the other. Better to take care to note how the cables layer during disassembly, or perhaps mark them to avoid this frustration on reassembly.
    gybeho -
    omg…. thank you!!!!!!!!!!!!!!!!!
    Stephanie Mille -
    Check order of cables. From screen replacement.
    lee moran - 回复
    my problem is that the connectors are different the screen i replaced it with the connectors were longer than the broken screen even though there the exact same type of screen
    andrew midgett - 回复
    Probably just have the cables out of order. Check the posts above.
    gybeho - 回复
    "gybeho" Ok, but it's impossible to install flex cables out of order. Each one has diferent sizes of docking...
    cruz.giovanni - 回复
    it is very possible to install flex cables out of order. to most people working on their first screen replacement they do not have the experience to notice that their flex cable connection is different than the dock connection. this causes them to press harder and force the connection into the dock, ruining the connections, if they do not think the they have the cables out of order
    Dakota Navarrete - 回复
    I'm with Andrew Midgett. The connectors are just plain different in size and orientation. My phone matches what's shown in the picture above. You can see an example of the replacement part if you search Amazon for "Sanka LCD Touch Screen Digitizer Frame Assembly Full Set Screen Replacement for iPhone 6". And Sanka isn't the only iPhone 6 replacement that looks like that, so no hating on that manufacturer here.
    Does this mean that some iPhone 6 phones have one set of connectors and some have a different set? FWIW, the model on the back of my phone says A1549.
    PG McLaughlin - 回复
    Update: Searching for iPhone 6S instead of 6 on Amazon, I see lots of replacement screens with connectors that look a lot more like what I have and what's shown in the picture above. (One connector has a horizontal orientation, the other is vertical. I can't be sure whether the pins or dimensions match otherwise.) Any wisdom here?
    PG McLaughlin - 回复
    Had the same problem with the correct layering of cable harnesses. Perhaps an additional photo showing the correct layering would be helpful for 1st timers?
    William Breen - 回复
    +1 for a photo showing the correct layering and routing of cables. I accidentally routed the home button ribbon above the digitizer ribbon and beneath the power and backlight ribbons. The uneven pressure it put on the digitizer connector after tightening the plate caused my digitizer to not recognize touching the display or made touches appear off center.
    drpotter -
    For everybody who thinks they can skip these steps I commend you. No way I would have been able to get my battery out - two broken strips - without removing the screen. Re-inserting these cables was not really difficult - once the first one is back in place the rest follow quickly.
    Chet Seidel - 回复
    I tried to reconnect these for ages until I watched a video of someone else doing it.
    Don’t try to line up the connectors by looking at them with the screen leaning on a soda can, just hold the two halves in each hand and line the first one up by feel. Really. After that it’s plain sailing.
    Even with great lighting I couldn’t make this work with the bits on the bench - yet when I picked them up it was really easy to feel them line up. I had all four popped back on in about 60 seconds.
    Pitt Monqui - 回复
    Please how much is the battery if converted into Ghana cedis?
    Pappy Joe - 回复
    1 Ghanaian Cedi equals $0.19 United States Dollar. Therefore, the $30 USD iPhone battery kit equals 161.04 Ghanaian Cedi.
    Don Lawton -
    Got it all connected properly but front facing camera won’t work. I heard that connector snap into place but it just doesn’t work anymore. I even took it all apart again and redid that connection but nothing. Bummer, but I’m not a selfie person, I only used it when I was holding my dog on my lap. Everything else works fine after the battery re-install so…whatever.
    C Trigger - 回复
  16. iPhone 6 LCD屏幕面板的更换: 步骤 16 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 16 中的图像 2,2
    • 用撬棍或手指甲断开Home键排线接口。
    Muy buenas....una pregunta tecnica...si el botón falla o no está bien conectado...al conectar este conector ¿ se apagaría el teléfono?. Repare mi iphone y al conectarlo se me apaga el movil, sin embargo si no lo enchufo el movil enciende perfectamente.
    Gracias.
    Berta fernandez - 回复
    I have the same problem. The phone turns on when I disconnect the home button cable, but turns off some seconds after I reconnect it. Does anybody have a solution?
    Tim Wende -
    If you look in the prior steps , it clearly says to disconnect the battery when disassembling and reassembling.
    Anthony Arenas -
  17. iPhone 6 LCD屏幕面板的更换: 步骤 17 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 17 中的图像 2,2
    • 在连接或断开这一步中的排线之前,请确保电池已经断开连接。
    • 用撬棒或手指甲断开显示排线接口。
    • 重新组装手机时,显示排线可能会从插座上松动,这回导致重开机时屏幕显示白线或者直接白屏。如果出现这种情况,只需再次装好排线并将手机电源重置一次。重置手机电源最好的方式就是将电池排线断开再装上
    you missed the name of the second connctor. there are four total
    copykatt - 回复
    My screen is completely black and i can see the lights turning on when i press the home or lock button. Maybe this cable got damaged ?
    Gabriel Hirata - 回复
    Perhaps you bought a faulty screen. Often this is the case when it shows completely black.
    William Mullan - 回复
    When I was preforming this step, while reassembling, I had to connect the digitizer cable four times. On the last time, before screwing the Front Panel Assembly Cable Bracket on, I reconnected the battery connector and turned my phone on (ensuring that I was careful not to damage any cables!) to ensure that all cables were connected correctly and that the screen was fully functional.
    Christopher - 回复
    NO NO NO ! i am a professional iphone repairman and i strongly recommend against using ANY tool to disconnect the flex connectors if u slip or use to much force you will damage the connector and may cause permanent damage to the phones logic board rendering it completely UNrepairable! Instead gently use the edge of your fingernail and pry up and the connectors will usually come off with very little effort .
    taylor sparks - 回复
    Fingernails work great as well! However, there's nothing wrong with using a tool, as long as you exercise a little caution. If you've ever seen one of Apple's iPhone service manuals, you'll note that they use the exact same tool as iFixit (Apple calls it a "black stick" and iFixit dubs it a "spudger.")
    Jeff Suovanen -
    I'm pretty sure ifixit are pros, I used them 4 times to fix phones and no problems with using tools for flex cables.
    Dave - 回复
    If you still have white lines after you've tried reconnecting the connectors and power cycling. Just do a hard reset a few more times, let the phone stay on and wait a while. As long as it's not damaged, the lines will fade over the next hour or so. Your phone will be as good as new.
    grjos - 回复
    If my screen is giving me white lines and occasional ghost clicks on the right side does anyone know if it’s possibly only a faulty cable vs needing a full screen swap? I’d rather not waste a perfectly good screen.
    Andrew Hill - 回复
    what if my phone wont turn back on even after following all these steps carefully . i even put the old screen back on and it wont turn on still???
    Daniel Murcia - 回复
    what if the batery was not disconnected?
    Sergio Midence - 回复
    Re-connecting display data cable was trickiest part for me - my eyes are old! I had to do it a couple of times as the cable had indeed popped off its connector, resulting in a black screen when turned on. Needs lots of patience and good lighting, also helped to have a really good look at plug and socket under magnifying glass to see how they fit together, and to reconnect using finger rather than tool - this helped me feel when I had eventually connected properly.
    Trish - 回复
    Followed steps to a “T” - got phone up and running successfully! However, there is a vertical line in the center of the screen that changes color with whatever button is being displayed in the center screen. For example, a dead battery icon shows a red vertical line, acknowledging a blue “OK” button when setting up the phone shows a blue vertical line, etc. Essentially it’s not a black screen or white lines. Could it be that the display data connector is not correctly attached or perhaps a faulty connector?
    Cyndi - 回复
    I finally got the cables to reconnect. I actually was being to gentle pushing them down. Line them up gently then firmly press them in place.
    halac6 - 回复
    i went through all the steps, except i forgot to disconnect my battery, now my phone has lines and i can see horizontal pixels (as in the images are not smooth anymore). when i performed power cycle, the screen is still the same. What can i Do
    kingsley Jide - 回复
    During the reassembly, the ordering of the ribbons on the iFixit part at the top of the phone were mis-layered. The display data cable connector and the digitizer cable connector (steps 18 and 19 in the guide) were swapped in there ordering. This was fixed by my disassembly of the camera bracket following the guide 'iPhone 6 Front-Facing Camera and Sensor Cable Replacement'. This allowed me to fix the layered ordering of the connectors.
    Ryan - 回复
  18. iPhone 6 LCD屏幕面板的更换: 步骤 18 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 18 中的图像 2,2
    • 用撬棒的平头断开触摸层排线接头。
    • 当你要组装触摸层排线时, 请不要按压接头的中间地方。按压接头的一端, 接着再按压另一端。因为若是按压接头中间时, 有可能造成触摸层变形损坏。
    Reassembly was harder than other i devices I have worked on. A bench light from the side helped a lot with the first cable, the digitizer. The others went a bit better in this crowded space. I had screen lines when testing it out before closing the top, so reinstalled all four connectors here with the aid of a side light and happily, that worked!
    griffn - 回复
    i crossed over the first two cables initially, when re-assembled; make sure by the WIDTH that you are trying to connect them in the right order.
    awr - 回复
    How many times can i peel these connections without braking the connection between screen and logic borad
    falken1337 - 回复
    Is this the breaking down process for the Verizon version of the iPhone 6s? I know the flex cables were different for other versions and with my last iPhone I made the mistake of ordering one that had completely different cable places. Someone please send me a link to one that fits the Verizon 4.7 display!!!
    Bailey Duncan - 回复
    This break down isn't for a 6S. It is for a plain 6 (no S). Yes there is some differences because of the 3D touch feature.
    Keith Mullins - 回复
    So what is the fix if there is digitizer damage? Replacing the screen?
    After reinstallation, I am encountering issues with an area of the screen that is not responding to touch. Everything else works fine.
    Anyone have any ideas how I should proceed?
    Jonathan Rivera - 回复
    I had the exact same problem. I tried 10-20 times and the screen had vertical lines in the middle and the touch function didn't properly work. Then I discovered the issue. I had damaged the first connector (lcd connector) when reassembling the screen.
    What I did was to carefully with a tweezer press the damaged ones in to the correct position. Than I heard a solid "click" when I attached it and I got really hopeful.
    I finished with the rest of the connectors and put the bracket and screws back to Place and hit the powerbutton. IT WORKED!
    So, look at the first connector with a magnifying glass, the shortest one, closest to the camera. Maybe I got a little lucky when I managed to fix the connector without replacing it. Good luck. I feel your frustration all the way to Sweden.
    // Simon
    Simon Tengstrand -
    I mean digitizer Cable= the first connector (lcd connector).
    Simon Tengstrand -
    I had the most issues when reassembling with this step. The plastic tool is a fail in my experience since not enough pressure could be applied using it. I just ended up using my finger and that worked 10Xs better. My advice, watch a few YouTube videos of people reconnecting the connectors and you'll be fine.
    grjos - 回复
    I have dis-connected and reconnected several times with the white line appearing each time. The screen however seems to be responsive. I did lose a 1.2 mm screw. Is it the missing screw or did I damage the digitizer connection?
    Charlotte - 回复
    I finished with the rest of the connectors and put the bracket and screws back to place and hit the powerbutton. IT WORKED!
    I had three screws left when I did some repairs on my iphone 4 and that didn't matter. It worked like a charm :)
    // Simon
    Simon Tengstrand -
    Simon Tengstrand -
    Be especially careful in this step or your iPhone won’t respond to your touch after reassembling.
    Ume Nishikino - 回复
    My home screen button is not working after reassembly, not only the Touch ID but the actual button doesn't work. I have iPhone 6S . How can I fix this? Thanks
    Sissy -
    I noticed that I had bent this connector. Barely. After about a dozen connect/reconnect attempts, bent it back and everything works as intended. Prior to bending it, was getting white lines and touchscreen was unresponsive. After bending and reconnecting, fired up exactly as it had prior to disassembly.
    Heywoz - 回复
    Thank you Simon - this was really helpful. I too suspected I had broken the digitizer connector also. Tried reconnecting 5 times before I saw your comment with resulting white lines and no touch screen. Applied moderate gentle force using long nose tweezer across width of connection and clicked and worked. Glad I read the comments as was looking at new digitizer purchase prior to reading your comment.
    Will - 回复
    I Had two repairs on separate phones, and got sloppy on the second one and pressed the middle of this connector with my finger. It bent the right side ever so slightly. I thought I’d read the comments before ordering a new screen and I’m glad I did. I then took a closer look and saw on the right side the two rows of points at the end weren’t running parallel anymore. Using the tweezers from the kit I squeezed the misaligned rows back true and tried one more time to install, focusing on the right (previously damaged) side first to ensure it snapped into place. Voila! All is well.
    Excellent instructions, great products, and REALLY HELPFUL COMMENTS! Thanks!
    Clint Casanova - 回复
    This was the hardest step for me. The iHold helped a lot. Used my fingers for all the connectors. Just make sure the cable that goes to the lowest connector is placed above all before trying to insert any.
    Pau - 回复
    I’ll strongly agree that this is the most difficult and time consuming step of reassembly. As Pau has stated it is vital that the cables are layered in the correct order before you begin attempting the connections.
    Check back to Step 21. It’s not clear from the photos, but the ribbons can be run under each other. The display connection and the home button connection can become transposed at Step 21.
    If in doubt, check the size of the connections and re-order accordingly.
    Dom Gernon - 回复
    After reassembling I have 3 letters on the virtual keyboard that don’t do anything anymore. It is the B, H and U. Could this be related to this (another) connector. (the screen is also broken but this time I only replaced the battery an it worked before this
    Erik Wegman - 回复
    Bonsoir je voudrais savoir si c'est possible que l'a ou l'on coche la nape de l'écran tactile peut se de fixé
    Et comment faire si c'est le cad
    francoislevi akolia - 回复
    My first attempt resulted in loss of touch response to a vertical column of app icons on the screen. From the Safari app at the bottom to the top of the screen, every app icon in that column was unresponsive to touch. Couldn’t open them. And this was true for every screen, including a corresponding bundle of letters and numbers in the same screen location when trying to use the keyboard. I did a hard reset any number of times without success until I finally realized the pattern: the vertical column of unresponsiveness.
    I remembered the caveat about connecting the digitizer cable — don’t press the center, do each side — and figured I must have made a bad connection. So I opened up the case again and went all the way down to the digitizer connection and did it more carefully, as advised. Sure enough, problem solved. Take the precaution.
    William Damkoehler - 回复
    Replacing the digitizer cable was accomplished by moving the base to line up with the flexible connection then using a finger to press into place feeling that the connection was correct worked, then pressing into place with a click of confirmation. the rest of the cables fell into place afterword.
    Teri Wright - 回复
  19. iPhone 6 LCD屏幕面板的更换, 前面板与机身的分离: 步骤 19 中的图像 1,1
    • 至此,前面板可以彻底与机身分离了。
    Is it not possible to start here? Just leave the screen assembly attached and only replace the home button?
    Joeri Boersen - 回复
    Please don’t do that. You will break your cables almost assuredly if you leave it attached to your phone trust me
    Curtis Jordan Lenox - 回复
    Is front camera supposed to be attached to the digitizer?
    Neos Kosmos - 回复
    It would be worth noticing, either at this step or below, the order of the stripes. Reassembling the fron panel requires them in the correct order, and “follow the instructions in reverse order” is not enough if there is not a detail on how the cables are ordered.
    Roger - 回复
    I successfully left the screen assembly attached while replacing my battery. I even had my adhesive strips break off and had to spray isopropyl underneath the battery and then grab the strips with tweezers, but I was still ok. I can see why it’s recommended to detach the screen assembly, but if you rubberband it to a stable support and are careful not to jerk the lower case, it’s possible to accomplish the repair while skipping several steps.
    eswecker - 回复
  20. iPhone 6 LCD屏幕面板的更换, 内置听筒: 步骤 20 中的图像 1,1
    • 从听筒扬声器/前置摄像头支架卸下Phillips 螺丝
    • 一颗2.3mm螺丝
    • 一颗3.0mm螺丝
    • 一颗2.2mm螺丝
    Again, you need a #000
    Tobias - 回复
    Can changing the earpiece disable the Touch ID?
    Ricardo Ramirez-Mendoza - 回复
    I read somewhere that if I change the earphone speaker. It will disable the Touch ID once I put the phone back together. Do I have to sacrifice one of these if I want my earphone speaker to work?
    The earpiece speaker itself has nothing to do with Touch ID; a correctly performed repair will leave Touch ID perfectly intact. Touch ID will only be disabled if you damage the home button hardware or the ribbon cable that connects it to the logic board. That cable runs from the home button, behind the display shield, and up to the top of the phone near the earpiece speaker. So yes, if you are unfortunate/careless enough to damage it in the process of replacing your earpiece speaker, that could disable Touch ID, although Touch ID is no different from any other component in that respect! ;)
    Jeff Suovanen -
    I completely ripped my home button ribbon, that being attached to the LCD shield/Front Panel (steps 36-38, step 38 to be more precise). I can confirm you CAN replace the shield\attached ribbon cable. This DOES NOT disable touch ID/you do not have to ask Apple to resync the button identifier.
    Just to be clear, this is assuming that you do not damage the actual home button assembly steps 29-35.
    (My replacement was from a supplier who reclaims parts from iPhones, so it would/should be an Apple original)
    Chris K - 回复
  21. iPhone 6 LCD屏幕面板的更换: 步骤 21 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 21 中的图像 2,2
    • 拆下听筒扬声器/前置摄像头支架的前面板。
    Be sure that the replacement part has a little black squared sponge facing the camera. I have purchased some replacement displays in the past (assembled with front camera) and some of them didn't had that sponge. The result is a front camera not pushed onto the display glass and this will cause backlight leaks into the front camera.
    ferbarragan88 - 回复
  22. iPhone 6 LCD屏幕面板的更换: 步骤 22 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 22 中的图像 2,2
    • 在前面板中的凹槽处撬起前置摄像头。
    its better to slightly heat the display from front in order to loseen the adhesive which is glued with the strip to display
    vara prasad - 回复
    Be sure to remove the plastic bracket (clear piece) that holds the camera in place from the old screen and add it to your new screen, or else your camera won't seat the right way against the screen and you'll have to take everything apart to place it in.
    marcus derkson - 回复
    Take note of where the cable is placed. When I put everything back together my cable assembly was behind the others (as I reassembled this ‘area’ into my new screen before continuing to the home button). As the cable was behind, the four connectors being attached to the main board were not in the right sequence, so I had to manoeuvre them (a bit more fiddly than you would imagine).
    Chris K - 回复
  23. iPhone 6 LCD屏幕面板的更换: 步骤 23 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 23 中的图像 2,2
    • 拿起前置摄像头,取出扬声器模块。
    • 尽量不要触碰听筒或者线缆-皮肤上的油脂可能损伤他们或者影响连接。 如果你不小心触碰到了,使用一点异丙醇来清洁并等待一些时间让他晾干。
    Like me, you may have accidentally touched the speaker, springs or 4 gold contacts on the cable. I used the tweezers to remove the speaker but it magnetically got stuck to the tweezers so I removed it with my fingers and accidentally touched the contacts. Use your own judgement, but I've had good results using a tiny amount of 70% isopropyl alcohol on a Q-tip and cleaning these 4 gold contacts and the springs on the speaker piece. Beats replacing the speaker for $25. Perhaps the #iFixitTeam can lend some advice on this step, in addition to the warning about not touching it. :-)
    Brian Hernandez - 回复
    Man, great guide getting to the speaker, but I have to replace the mesh as well. Not sure why we couldn't just include that in the guide since we already went this far! Doesn't seem to be anything too good on google results for this last step either... bah!
    TheFranko NoneYa - 回复
    I have had problems with two phones after replacing a screen. The sensor that turns off screen when talking does not turn off screen. May this be because i touched this contacts?
    Ronny - 回复
    That's a problem with your proximity sensor (tiny thing with 2 'eyes'), which is on the same flex cable as the front camera.
    Didier Daniel -
    Hi Ronny, im having the same problem. have you found a solution for it? if u have, please help me out
    Fabius Pradeep -
    It may be that when it was time to remove it from the screen, you put a lot of pressure on the component and damaged it
    Yuri Henrique -
    Make sure the screen that protects the speaker is free of ear wax. It can be stopped up with ear wax and limit the output of the earpiece speaker. About 50% of the ones I have come across this was the cause of low earpiece volume. Use a small nylon hobby paint brush dipped in 91% rubbing alcohol to clean it.
    scottingram - 回复
    After assembly my speaker didn’t function. However upon checking the flex cable was not snuggly snapped in place. After twice reassembly got it working again. So maybe before cleaning the contacts, check the flex cable connection first.
    Sahrul Anwar - 回复
  24. iPhone 6 LCD屏幕面板的更换, 前置摄像头和感应电线: 步骤 24 中的图像 1,2 iPhone 6 LCD屏幕面板的更换, 前置摄像头和感应电线: 步骤 24 中的图像 2,2
    • 将前置摄像头用手扶着, 再使用撬棒尖头那端将光度感应器与前面板断开分离。
    i have a question.
    my homebutton cable was broken. so i bought front plate.
    and i have original home button too.
    so, if i change broken plate and new plate, can i using touch id??
    kjh657 - 回复
    You should actually be commenting in a home button step (such as 30), so you get the right visibility. But if by front plate you mean the display (digitizer, lcd, and front glass) then no, this will NOT fix touch id problems. If the problem is damage to the home button out it's attached cable you are out of luck, as those are unique to each iPhone. However if the ribbon cable (the one attached to the large shield) is damaged, then that is replaceable. A new lcd shield should come with the home button ribbon attached, or you can buy the ribbon separately and just replace that. The shield is much easier to replace and about the same cost.
    Charlie Yarbrough -
    When replacing, make sure the proximity sensor is replaced correctly and seated fully inside the plastic bracket. Not doing so can cause loss of functionality in the sensor preventing the lcd from turning off when it's supposed to during calls etc.
    Charlie Yarbrough - 回复
    Could you explain this any further? I recently replaced this because of a bad microphone and now the proximity sensor isn't working. I transferred the plastic/rubber gasket/bracket thingy over. I've disassembled and reassembled the thing 3 times to make sure the sensor is properly seated, no luck. The ambient light sensor for auto brightness works just fine, which I think is actually the one with the plastic part, unless I'm missing something?
    Is it possible the new cable assembly just has a bad sensor?
    Bennet Pullen -
    I confirm what you say. Bought a phone with proximity sensor not working. Turns out it didn't have the plastic bracket where you put the sensor in.. :)
    Didier Daniel -
    I think I’m having the same problem. When I removed the ambient light sensor, the black brick that seems to be the proximity sensor pulled off the cable and I had to pry it off the face. I had a great deal of difficulty lining up the two parts even after getting both of the little liners in place. I’m not sure what I could do to improve the alignment. The speaker, mic and camera are all working fine.
    Tom Comeau -
    When reassembling, ensure that the plastic bracket for the proximity sensor is removed from your old cable assembly and that you put it with the new cable. I found that if you put the plastic bracket in the recess in the front panel first to ensure that you get it in correctly.
    Christopher - 回复
    It is crucial that you make sure that the little black plastic bracket around the ambient light sensor is removed with it when lifting it out of the recess. It is very easy to not notice that it stayed in the recess and really difficult to make out any difference between the removed cable and the replacement cable. It took me a few tries to realize that the bracket was still in place and was why I couldn’t seat the replacement cable properly.
    dhcohen67 - 回复
    BLACK plastic bracket???? As this is crucial, I have been trying to locate a black bracket for the last hour or so, magnifying these images, watching different youtube videos etc … is there definitely a black bracket? Or could you be referring to the CLEAR plastic bracket that can be (just about) seen next to the white recess of the Ambient Sensor, in the pictures of this step?
    I would also like contributors to comment on the WHITE recess of the Ambient sensor (a shown in the pictures of this step). I have a replacement screen that does not have a white recess, it is completely black (looks like it is ‘just a hole’ going through to the glass on the front). I can see no way of removing the white ‘cover’ from the original screen …does it matter?
    Chris K -
    There is a white rectangular parts (about 2mm*3mm) on the front sensor , so remove it with the tip of tweezers. If it cannot be removed, it can be easily removed by applying warm air from a hair dryer.
    syusan - 回复
  25. iPhone 6 LCD屏幕面板的更换: 步骤 25 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 25 中的图像 2,2
    • 折叠前置摄像头和感应电线,这样才能拆到麦克风。
    When I was replacing my cable, I had part of the old cable stay in the in the front panel and had to remove it before I could put my new cable in during this step.
    Christopher - 回复
  26. iPhone 6 LCD屏幕面板的更换: 步骤 26 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 26 中的图像 2,2
    • 仔细地把麦克风的一端撬出,其上有粘合剂使之粘在前面板上。
    oddly enough my replacement screen didn't come with the earpiece rubber or front-facing camera clear "recess" pieces. Prying them off my old screen was tedious and in the end I didn't have new adhesive to apply. What would you guys recommend?
    I had to remove it completely and then apply some glue, very tiny just to keep it in place. However, my replacement part does come with an adhesive for the microphone.
    azriaris1 -
    Just pry gently with a small screwdriver in the upper right corner and the glue will drop
    Kvalvik69 - 回复
    Thanks this helped a lot! Was really scared doing it how the picture described it.
    nik.nation9 -
    My replacement part had a clear plastic that you need to remove so the microphone will stick. It is very thin so I pulled out the whole rubber part a few times before being able just to remove the clear plastic that shields the glue (part bought from ifixit.com)
    Christian van der Leeden - 回复
    I had the impression the double sided adhesive strip is thicker than normal under the microphone, and found it more difficult to lift than in other areas (other than the home button connector, which is adhered to a metal backing, making it extremely difficult). Fortunately, I did not rip the ribbon. Perhaps applying some heat would be advised.
    Q Why is there a microphone in the ‘earpiece’? Surely there must be a microphone nearer the bottom (where your mouth would be). Are there two, perhaps for speaker/conference?
    Chris K - 回复
    [|My microphone came with a small tab out to the left that was for adhesive. I peeled the white protection off and folded the copper colored adhesive tab under the microphone. Worked fine.]
    W4MWD - 回复
    Back on the air again! Great site for me to save money and keep my phone going after grandson “fixed it”.
    W4MWD - 回复
  27. iPhone 6 LCD屏幕面板的更换: 步骤 27 中的图像 1,1
    • 从前面板移除前置摄像头和感应电线。
    Before installing the new cable you might need to do the following. I just did this installation last night and I had to do these things. 1) There is a clear plastic piece that goes around the sensor. It might have stayed in the phone face or it might have come out. If it came out it needs to be installed around the sensor. 2) There definitely will be a little black plastic cover over the notification LED. That needs to be taken off the old cable and put on the new cable and in the right direction. 3) On my new cable there were 2 copper colored protectors that needed to be removed before installing the new cable. Remove those. 4) The cable to the front facing camera is too long. Notice where the excess cable was bunched up on the old cable. This was a difficult fix. The parts are so small. Assembling the area around the speaker is difficult. There are multiple places where the cables slip over little plastic bumps. Knowing about those little plastic points will help.
    Kent - 回复
    My phone isnt powering on after changing screen. Proximity sensor is broken could this be why?
    kyler - 回复
    Thank you for posting such great pictures of detail parts and (those blasted little rubber gaskets!) and how they are situated. This is an excellent guide.. Yours is an example I wish others would follow. Pictures from the angle low and in close are so helpful finding where that little rubber thingy (Yes that’s a technical term) goes and which direction it should be in.
    Rongwey - 回复
    Kyler sometimes that happens here too. Go back in carefully and double check the battery plug. Disconnect it and reconnect leaning down to look under the edge of the connector if necessary. Sometimes it helps. Other times just plugging the phone into the charge cord for a minute helps.
    Rongwey - 回复
    Kyler, the proximity sensor detects objects close to an active phone, so the touch screen can be shut off when the phone is in close proximity to your face (so your caller doesn’t get a bunch of “beeps” from keys being pressed by your face).,,
    Next to the proximity sensor (below it, in the last picture) is a tiny, insignificant-looking piece of white tape. If I remember right, it’s only present on black screens. It’s important—transfer it. Without it, the ambient light sensor can’t work, and the phone can’t dim its screen automatically in dark rooms and brighten it in sunlight. It took me ages of doing this before I found a place where someone had pointed that out. I mean, it’s just a tiny white sticker. Seems to be true, though.
    In re: Kent’s #2 above, I was fortunate to find new proximity sensor and camera frames on my new screens, and inside each proximity sensor frame is a small black piece over the notification LED (where it will be under the proximity sensor). Is that it, Kent? I hope so.
    Bonnie Baxter - 回复
    My new camera sensor isn’t folded like the one previously installed in the phone. I know these cables are very fragile and I don’t want to tear them. Where can I find a guide to properly fold the sensors so they fit correctly into their positions?
    Austin Martin - 回复
    They are very resistant to be bent in certain positions, try to bend with your fingers making very slow movements and look at the position where the flex of the previous front camera was
    Yuri Henrique -
  28. iPhone 6 LCD屏幕面板的更换, Home键: 步骤 28 中的图像 1,1
    • 移除2枚固定home键托架的1.9 mm飞利浦螺丝。
    Tobias - 回复
    My new part had the left home button bracket screw installed. You need to remove it (and can re-use it) before putting the home button bracket back on. If you are attempting this repair, you probably don’t need this tip. But just in case!
    eschrank - 回复
    Confirming what eschrank said. When re-assembling the home button onto the new front panel assembly remove the pre-installed screw, place the home bracket on the assembly then re-use the pre-installed screw to fasten the home bracket (left side).
    Gregory Hall - 回复
    After I finished reassembling my phone, I had an annoying clicking noise when using the phone. I opened it again and found a lose screw sitting near the jack module! It’s the one you can see in step 21 picture, over the circled one on the right. It shouldn’t be removed (there’s no reason) and I absolutely don’t know how it got lose. I’ve put it back where it belongs and will see how things go. (If I don’t add anything after this comment, that means everything’s back to normal.)
    gourgou - 回复
  29. iPhone 6 LCD屏幕面板的更换: 步骤 29 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 29 中的图像 2,2
    • 从前面板移除home键托架。
    It is possible to over-tighten these screws, causing the home button to malfunction.
    doog - 回复
    Helpful - thanks for the heads up! :)
    Will Reid -
    It is also possible for the tiny metal piece (not really a screw) that goes over the center of the home button to come out of the bracket & be lost, which will cause issues for making contact when the button is pressed. Now I can't seem to find any kits with a complete replacement...not sure if this is going to affect my fingerprint id capability because I'm having another issue of my phone being disabled due to the cracked lcd that caused the security code to be input several times which has locked me out completely. I'm still trying to find a way to not lose the pictures and videos that I haven't downloaded to my computer. Anyone have any ideas on either issue? Thanks in advance! ;-)
    Dawn - 回复
    Are the home buttons for a 6 plus and 6s plus interchangeable?
    Sheila Smith - 回复
    HI THERE, I WAS WORKING ON IPHONE 6g. I REPLACE THE HOME BUTTON AND AFTER I FINISH THE PHONE WAS DEAD. I WENT BACK AND REPLACE LCD SHIELD PLATE. AND STILLS THE PROBLEM. WHAT ELSE CAN I DO? ANY ONE DOES HAVE ENCOUNTER THIS ISSUE BEFORE CAN YOU PLEASE HELP ME. rosyavellaneda6@hotmail.com
    Rosie Godinez - 回复
    When going backwards, and reassembling, this is where you change from Phillips #00 driver, back to Phillips #000 driver.
    Robert de Schepper - 回复
  30. iPhone 6 LCD屏幕面板的更换: 步骤 30 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 30 中的图像 2,2
    • 使用撬棒将home键排线连接器抬升起来,使之从home键脱落,以此来断开home键连接器的连接。
    During this step, I couldn't separate the two connectors. I accidentally managed to tear the flex cable which passes under the LCD shield/plate and up to the other LCD connectors which attach to the motherboard. Can this cable be replaced to restore Touch ID functionality if everything else is intact?
    I can't see any special chip on that part, just seems like an I/O connector?
    James - 回复
    Yep you can. Touch ID functionality won't be lost.
    Didier Daniel -
    I have managed to separate the connector with quite a lot of patience and perseverance. Although there is no sign of physical damage on either side (button end, button-cable/plate end) the Touch ID functionality was lot. Assuming that the damaged side is that of the button cable/plate, this item is not sold on the EU store.
    Massimo Pinto -
    I have found by gently heating the broken screen side with a heat gun or reworker, it makes removing the home button and the connector so much easier to remove with the tip of the spudger and a press on the home button from the front side
    darren - 回复
    During reassembly the home button did not function. I verified the connectors were seated correctly but no read of touch nor of even pressing to return to home screen. This was resolved by me following the guide 'iPhone 6 Home Button Cable Replacement' to swap out my old, original shield plate with the one on the iFixit unit (effectively replacing the home button cable connector with my original one).
    Now up and running.
    Ryan - 回复
    Disconnecting the connector is tricky. Take your time and don't rush it. The pointed spudger end is a little thick to get under there, so I used a corner of the flat end, very carefully.
    DJ Billings - 回复
  31. iPhone 6 LCD屏幕面板的更换: 步骤 31 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 31 中的图像 2,2
    在这个步骤中使用的工具:
    iOpener
    $19.99
    购买
    • 轻柔地将位于顶端左侧的home键抬升起来,使之从前面板脱离。
    • 请勿始终向上推home键-您只需让一个角脱落,这样您就能用撬棒方便地翘起它。
    • 这层膜很薄。假如您感觉您马上要将按键撕坏了,请施以微热(使用 iOpener,热枪或吹风机)并再试一次。
    I used a hair dryer on this part. It made removing the home button extremely easy. Just take it slow
    peterhubner - 回复
    I too used a hair dryer and slow pressure as did Peter. I found that the adhesive would slowly release if I just held a little constant pressure with my finger and waited.
    Patrick Langvardt - 回复
    This being my first time I found that this step and the following steps to be the most difficult and time consuming. It required A LOT of patience because the rubber membrane and the adhesive holding the cable really don’t want to release without sufficient heating and I was concerned about overheating the assembly. Using a hair dryer on the slowest setting finally worked.
    fiftysomething - 回复
    Cette étape demande vraiment de la patience. J’ai juste attendu en exerçant une faible pression et au bout d’un moment ça s’est décollé.
    Il ne faut pas mettre trop de pression et avoir un bon éclairage pour voir l’état de la membrane au fur et à mesure.
    Chloé Bossuette - 回复
    I made the mistake of not using a hair dryer, I slowly pried the part up but in doing so the adhesive strip was no longer reusable. With no glue in the house I used a piece of the old battery adhesive strip as I changed the battery first. I cut the strip into very fine pieces, placed them under the steel cover plate in order to pinch the rubber gasket. Changing the battery and glass plate was easy but the tiny adhesive strip held me up for over an hour. Without the adhesive strip on the rubber gasket the push button will not work. I need to find out what glue is suitable for this application.
    Joseph O'Brien - 回复
    Joseph, I use this tape. The version I use is made by 3M. I find it’s a good compromise—strong enough to hold well, but loosens with heat and isn’t so strong that you rip the membrane (or whatever delicate phone part you’re working with) should you need to remove it. I’m not endorsing Amazon; you can get this stuff on eBay, from most phone repairers, etc. It comes in 1mm, 2mm, 3mm, 4mm, 6mm, 8mm, 1cm—just about any width you’d want, and is fairly easy to work with.
    ​1mm x55M Clear Double Sided Strong Adhesive Tape For Phone LCD Screen Repairby GENNEL DirectLearn more: https://smile.amazon.com/dp/B019OSYR1Q/r...
    Bonnie Baxter -
    Hair dryer worked the best!!! just be patient, takes like 5 min… use the tip of the spudger and skratch a little bit on the corner.
    Renata Torres Balderas - 回复
    I used the heat from my halogen bulb desk lamp and it did the trick right-away
    Rich Tea - 回复
  32. iPhone 6 LCD屏幕面板的更换: 步骤 32 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 32 中的图像 2,2
    • 使用撬棒轻轻翘起HOME键
    Don't get in a hurry with the ribbon. Heat and a gradual constant pressure did the trick.
  33. iPhone 6 LCD屏幕面板的更换: 步骤 33 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 33 中的图像 2,2
    在这个步骤中使用的工具:
    iOpener
    $12.99
    购买
    • 使用撬棒较细一头轻轻将HOME键撬起,注意屏幕与HOME键之间的粘合剂。
    • 如果您无法轻而易举地分开线缆,请使用诸如iOpener或者吹风机来加热粘合剂,使之软化,然后再试一次。当心,不要损坏线缆。
    This step really requires patience- I had to heat the area several times and “spudge” from both sides before the cable successfully loosened. Even under a strong magnifying glass, it will look like the middle section with the tiny circuit board is fused into the plastic, but it’s just strong adhesive, which eventually softens.
    Dan - 回复
    Dan, is there any source that indicates the maximum temperatures to which you can heat the different areas of an iPhone when necessary to loosen adhesives? Or time/power parameters for specific heat guns?
    Tomas Delaveau -
    This part almost killed me. In the video, they’ve already loosened the adhesive so she pops it right off. The hair dryer should be set to hot and low blowing. It’ll take a few minutes & a few tries) to loosen the adhesive. I aimed at all sides of the cable (ie at both ends where the cable meets the case & straight on at the circuit board). To finally get it off, I mixed up using a spudger to play with it and a very fine tweezer to finally get a good enough grip to pull the button assembly off.
    dhcohen67 - 回复
    I believe is better to heat the panel from te outside because the heat transfer would flow in a way that the adhesive will be at a higher temperature than the cable
    Tomas Delaveau - 回复
    would love to know temperature allowances/tolerances here. how hot is too hot? What temp does the adhesive relax at?
    flow in - 回复
    How do you remove the metal backplate shield's connector [which interfaces with the home button] glued to the plastic coating on the screen?
    Valtér Hégér - 回复
    The rubber gasket adhesion was minimal when I removed the button. I cleaned and replaced it, but it had no adhesion. I’m not sure if that’s how it is meant to be.
    Teri Wright - 回复
  34. iPhone 6 LCD屏幕面板的更换: 步骤 34 中的图像 1,1
    • 分离粘合剂和HOME键之后,便可分离HOME键。
    • 如果是更换碎屏,HOME键上可能会有玻璃残渣,更换新屏幕前,请先清理干净。
    One thing to note for re-assembly. You have to make sure the home button is firmly in place. Otherwise, a lack of adhesive will cause the home button to sink into the iPhone after it's fully assembled when you try to press it.
    rskrobe - 回复
    Are you sure that you screwed the metal plate back in far enough? I don't have any issues and can't believe that Apple would rely on adhesive to hold the home button from sinking into the phone. Especially as it's the most pressed button on the iPhone.
    Thomas Hallett -
    Yeah, you have to buy new gaskets if you want you're home button to stick to the digitizer frame when pressing. Don't believe me? Just see what happens when you press the button without new adhesive :) And heck I bought 50 gaskets for only $5 from China.
    Didier Daniel -
    On the old screen,there were 2 little rubber covers that fit on the screw mounts (that hold the pentalobe screws from Step 1) that I transferred to the new part.
    jefowler4th - 回复
    I would add a few extra steps to this (i had to disassemble and reassemble 5 times).
    First, adding the Ifixit forward facing camera replacement, and I would add the steps 12-16 fromt his guide on how to take off the heat shield (also has the fingerprint cable).
    http://www.instructables.com/id/iPhone-6...
    Thanks again.
    Roland Bodenheim - 回复
    after placing the home button again, it dose not read my finger prints anymore! any idea? Thanks.
    Khal Sh - 回复
    For all the iphone 6 series once the original home button ribbon is torn or damaged the touch ID will never work again. Even if you replace the home button/ribbon. This is a security feature implemented by Apple. Once the original cable for the phone has been damaged or replaced, the touch ID functionality is gone forever.
    Tony - 回复
    Dear After replacing the cracked screen successfully I turn it ON and the apple logo keeps coming and going as if it is like rebooting continuously any IDEA?
    Cesar
    cesarclaudio - 回复
    I'm having the same issue. Did you ever get a response to your question?
    Kevin Rivera -
    This is missing a step ... most replacement screen assemblies also are missing a small metal plate that sits under the place where the home button connector and flex cable connector rest. Apparently without this metal the touch ID cannot be enabled. That said .. I'll not know on this phone since after following these directions and finding out I needed to pull apart the home button a second time to place this metal plate there the connector would not separate and it ripped the flex cable from the connectors completely. Now it's time to get a new home button and touch ID will never work on this phone again :(
    cueball - 回复
    My new screen comes with the home button cable, if I just swap the original home button to the new front panal will I retain touch ID? Or do I need the original cable too?
    nathanation - 回复
    if you want touch id to work the cable going from the home button to the logic board must be changed also
    https://www.youtube.com/watch?v=8IEWAQiu...
    Eric Ocegueda - 回复
    That isn't what my home button looks like? It didn't have the little sensor on it, just the button and it still worked but now doesn't... Anyone know why?
    Emie Jayne - 回复
    despues de serguir la guia fue exitosa solo que tengo un problema no reconoce la huella me dice error al configurar el touch id alguna solucion???
    CHARLES - 回复
    When I was transferring my home button, it was covered in tiny shards of glass as the instructions warned. I found I was able to remove many of the shards and to clean up the button by wrapping a piece of scotch tape around my finger sticky side out and then gently dabbing at the shards.
    davechar - 回复
    https://support.apple.com/en-us/HT205628
    Does this iOS update mean that it is no longer necessary to replace the cable going from the home button to the logic board as well?
    Peter Barnett - 回复
    The only “problem” that I had, was that the home button connector on the iFixit replacement screen assembly was “floating” and made it very difficult initially to connect the home button cable connector. i eventually glued it down to the screen assembly with some Pritt glue and the connection was easy.
    Peter Barnett - 回复
    Thanks for everything.
    I just bout the Fix Kit from iFixit, I did every step 9-11 times, carefully. Everytime I try to turn on the phone when everything is assembled it won’t turn on. The screen remains black eventhough the phone is on and itunes can detect it. if I put the broken screen back I get the creen powered on.
    Is my recently aquired screen replacement broken? Thanks
    Will - 回复
    Solved. The new screen was not working. I now hace some stains on the upper part of the screen.
    Will -
    I had set my phone up as an erased “new iPhone” prior to the repair. After completing this repair my Touch ID appeared to be working normally and I added 4 fingerprint profiles. After a few hours Touch ID failed and the fingerprint profiles disappeared. Attempting to add them again would not work. After performing a “Hard Reset” the previously entered fingerprints returned and functionallity has been completely normal for a couple of days now. I will repost if another failure occurs.
    Steve Mattson - 回复
    When moving original home button to new screen, a tiny dab of adhesive from a Pritt Stick helped hold the cable onto the front panel. Great guide, all worked well, and touch ID working, thanks.
    Mike Cowley - 回复
    My home button was extremely loose when installed in this fashion. To help remedy it, I installed the gasket sandwiched between the button and glass instead of on the rear face of the button. Not perfect, but a much better feel. Prior to that, the button actually stuck out further than the glass.
    kwschnautz - 回复
    So my repair went off without a hitch, but my home button when I click it kinda has a hollow-like sound/feel to it, is it something I did wrong?
    Peter Keller - 回复
    You didn’t show removing the top part, camera, etc.
    William Wong - 回复
    I did not have a hair dryer on hand so I used the metal tweezers very carefully to lift the gasket and connector. Reinstalling it was tricky but I found sticking the connector back onto the two tiny pins made it a lot easier to guide the button into place.
    Nicholas Hooker - 回复
    I replaced my battery and my screen on an Iphone 6 for under $100. My phone looks and works like new. Great online tutorial, just go slow and be careful. I dropped a screw in the carpet and thought I was screwed. By some miracle I spotted it, the size of a pin head. Use a magnetic try if possible and do the work over a tile floor. I’m 66 years old, you can do it!
    Thomas m Burke Jr - 回复
    On the screen I purchased from iFixit, the the connector’s cable was .5mm too long so that it wouldn’t fit on the two tiny pins. But I have put it all back together and it works great.
    Greg Scott - 回复
    My IFixIt kit worked well. Gifted to me by a friend along with the project tray. The tiny screws are hard to handle, but the guide got me through. The phone charged and turned on like the screen was never dead. Only thing is the home button doesn’t respond to fingerprints. No big deal for me. Thanks for the great products and instructions.
    Lo'real Barrow - 回复
    The new screen from your Store came with not one—but 2—screws, and they were loose in the package. I used one where the photo shows a screw in the top right of the button bracket, but I didn’t compare the new screen to the old one further to figure out where the second one *might* have been needed. So far, phone is restored, and I’ll only go back to place the screw if the phone ever acts up (or someone here comes on to warn me of certain doom). Thanks once again iFixit for the part, the tools, the video, the step-by-steps, and this community. Could not have done this without any of you!
    Sue Livingston - 回复
    There seems to be a step missing? The little connector that the home button is plugged into seems to be glued pretty hard onto the frame. How is that supposed to be loosened?
    mortenskogly - 回复
    It's not glued in, it's "plugged into" the logic board. You just need to unplug it. Take your time and gently pry it up from one corner. Eventually it will pop off.
    DJ Billings -
  35. iPhone 6 LCD屏幕面板的更换, LCD屏幕面板: 步骤 35 中的图像 1,3 iPhone 6 LCD屏幕面板的更换, LCD屏幕面板: 步骤 35 中的图像 2,3 iPhone 6 LCD屏幕面板的更换, LCD屏幕面板: 步骤 35 中的图像 3,3
    • 移除图中Phillips#00号螺丝, 这些螺丝是把LCD保护板固定到前面板上:
    • 一个1.7 mm螺丝
    • 六个1.6 mm螺丝(每边各三个)
    I just cant get those screws out! im stuck.
    kntinos10 - 回复
    I to am stuck at this point on two screws any solution.
    Janice Scott -
    I, too, am having enormous problems removing all these screws. The first 1.7 mm came out without trouble, but the 6, 1.6mm screws are terrible. I've made it down to the last one and I'm afraid that the screw head is becoming stripped. I'm working with about a half-dozen tiny-headed Philips head screw drivers and am no longer getting any "bite" to turn the screw.
    ellamama - 回复
    You need to press pretty hard with the driver in order to get it to bite. If necessary, hold the flat of your spudger behind the screw so you can apply more pressure without bending or breaking anything. If you've completely stripped the screw, you might be able to get away with just snipping the metal tab off with a pair of wire cutters and letting the other five or six screws do the job alone. Otherwise, you'll probably need to replace the entire display assembly (one that comes with a new shield already installed).
    Jeff Suovanen - 回复
    I’ve tried to take out the screws for around half an hour and failed, put everything back together and ordered a new set of tools. Started the whole process again today only to get stuck here again. I just can’t get them out.
    Kauther - 回复
  36. iPhone 6 LCD屏幕面板的更换: 步骤 36 中的图像 1,2 iPhone 6 LCD屏幕面板的更换: 步骤 36 中的图像 2,2
    • 将LCD屏蔽板的前置摄像头那端稍稍往上抬起。
    • 注意 , 不要试图一下子将显示板完全移除,它的Home键排线那里 , 仍然有黏合剂粘在前面板上。
    impossible to unscrew the last 3 screws. help!
    suesamp - 回复
    where you able to unscrew the last screws? i'm having the same problem but only with 2
    Hector Torres -
    When assembling back the shield plate, you have to ensure that the LCD cable (the one with the long metal) is put under the shield plate.
    azriaris1 - 回复
    Yes exactly! I forgot this twice! Its very annoying. maybe the author could write this in step 32? Would save a lot people a lot of time :)
    Joris Ott -
    What is the exact purpose of that LCD cable with the long metal bar?
    Peter Barnett - 回复
  37. iPhone 6 LCD屏幕面板的更换: 步骤 37 中的图像 1,3 iPhone 6 LCD屏幕面板的更换: 步骤 37 中的图像 2,3 iPhone 6 LCD屏幕面板的更换: 步骤 37 中的图像 3,3
    • 把一个小撬棒放在在显示板后面轻轻撬动,小心将Home键排线提起来,成功后可将液晶显示屏移除。
    • 剥开Home键电缆时要格外小心。 这是一条非常脆弱的电缆。 如果您感觉有很大的阻力,请停止并使用吹风机或iOpener以软化粘合剂,然后重试。
    • 之后,即可取下LCD屏蔽板。
    I have found that using a fresh razor blade is a little easier than the spudger alone. First lift up the small tab on the left of the connector. Then very carefully slide a corner of the razor blade under the left corner of the connector, making sure you are under the metal backing. Slightly lift up with the razor blade to make room for the spudger. Slowly lift the connector with the spudger and viola, it should come loose!
    Damon - 回复
    Absolutely, I had to do this on my last iPhone 6 repair. I was worried that I'd ripped the ribbon cable slightly but I was fortunate and it hadn't torn.
    Kronkk37 -
    Golden advice ! From now on I'm doing it the same way. So much easier and safer ;) Thanks buddy !
    Didier Daniel -
    I spent 15 minutes trying to do this with just the spudger. I went and got a razor blade and had the cable off in 30 sec!!! this is definetly the easiest way to do it
    Aria Farahani -
    There is a metal part attached to the bottom of the ribbon. Be careful to pull that up and not attempt to separate the ribbon from the metal. I started doing this and it took a good deal of force and then finally got enough light to see that I could get under the metal. The metal comes up much easier.
    holtkamp4 - 回复
    Thank you sooooooo mutch ! I was doing exactly the same thing !
    Drissouille -
    Heat up the area first and use a metal spludger to lift up under the metal plate, when heated, it lifts very easy.
    Glen - 回复
    I've had one flex fail (even though not physically damaged), by lifting the heat shield up and removing the connector that way. The result is the phone does not register properly with button, and Touch ID doesn't work. I now use a fine point tweezer to get in under the metal plate on the rear of the connector with a bit of heat. This seems to be the least invasive way of doing it. You need to check Touch ID is registering after each screen change due to the possibility of Error 53.
    Matthew Kerr - 回复
    In my opinion, using a razor blade is extremely risky. In fact, I won't even use a spudger, because I find this cable to be very fragile. Here's what I do: Firstly, heat an iOpener in the microwave for 30 seconds, remove it for 2 minutes, then return it to the microwave for a further 30 seconds so it's extra warm. Secondly, lay the iOpener flat directly on top of the connecter for 90 seconds to loosen the adhesive. Thirdly, move the iOpener out of the way, then with one hand, lift the metal plate from the top end (closest to the front facing camera) to a 45 degree angle, or just enough so with your other hand you can fit your thumb under the flex cable towards the bottom of the metal plate. Now you want to grip the flex cable with your thumb underneath and your index finger on top as close as possible to the connector itself, then slowly and carefully lift both the plate and flex cable simultaneously towards the bottom of the phone. I found this video to be helpful: http://youtu.be/mh-cbErzGNo
    Jayden Monkley - 回复
    You can see a pull-tab on the left side from a chip (which is glued to the surface under it). This pull-tab is free to take - no glue under it. Just grab it and gently move to the right - to the chip. It's the easiest way to unglue this home button cable. No blade or other stuff needed!
    dv1977 - 回复
    I agree with dv1977, the black pull-tab on the left side of the chip is a great starting point. Heat will also help, so use an iOpener or something similar to heat the glue.
    Tobias -
    Seconded! This should be the only way to do it. It's really difficult to get the spudger under the metal underside of the ribbon cable otherwise!
    Thomas Hallett -
    Yes I agree to you. This should be the original orientation and not use the spudger for that.
    Jupiter -
    Hi @dv1977, are you saying the black tab shown in the third picture of this step (almost directly where the point of spudger is), would have pulled the home button and connector ‘easily’ off? Wow, if that is the case, this step should be updated by iFixit. I completely ripped mine as I followed the ‘LCD Shield Replacement’ guide, which gave the impression it was a ‘simple’ matter of carefully (and persistently) using the point of a spudger. I have bought a new shield, in the hope the cable is ‘just wires’, and the intelligence (id) is within the actual button assembly.
    Chris K -
    UPDATE: My replacement shield/attached ribbon, works perfectly. No loss of touch ID.
    Chris K -
    I just did my first swap ever on a 6, and I had the phone powered back on and all components tested within about 3 minutes. I've changed hundreds of 4, 5, 5c, and 5s though, so I'm sure that experience helped. I didn't have to disconnect the battery at all, just very careful with how I removed everything. If you can afford it, GET THE FIX KIT. I've got a whole container of leftover tools from other screens and I didn't even touch them. I used the new fix kit and it helped so much. Transplanting the old home button was a breeze, nothing torn at all. RTFM like I did, and anyone should be able to swap any of these components without an issue.
    kylemmancuso - 回复
    Removing this cable is rather tricky if you follow the instructions in the manual. I think i repaired about 20 iPhone 6's by now, all using a metal spudger or a boxcutter knife. How? Gently lift black ribbon as seen on the pictury, starting on the left side as seen on the picture. Once you see the small metal connector, which is attached with a mild adhesive, stop pulling. Gently wedge the metal spudger under the connector, starting at the bottom left. With a mild pressure the connector will simply "pop off". If it doenst work with the spudger, try using a boxcotter, just be careful you put it under the connector and not between the cable and the connector.
    Kenneth Hordijk - 回复
    Doesn't replacing this effect Touch ID
    simon chieng - 回复
    As long as it is done successfully, Touch ID will not be impacted.
    TheJB -
    Maintaining touch ID is the point of transferring the original home button and its cable to the new display. As long as the motherboard is paired with its original home button and cable, touch ID will be maintained. There’s an identifying chip on the back of the home button, and matching information on the motherboard somewhere (I don’t know where its encoded).
    This is called serialization. Apple seems to be doing it more and more—with the latest iOS and the newest phones (iPhone X series and above, I think), they’ve done it with batteries as well. An “Apple authorized” technician (i.e. employed by Apple, not by you) can “reset” a new battery so it matches your phone, but if anyone else changes the battery, battery health will not work, and you’ll get a warning that “Apple cannot verify that the installed battery is a genuine Apple part” or something like that.
    This is one of many reasons we need Right to Repair legislation. Please help!
    Bonnie Baxter -
    I failed the last part and i broked the cabel is there anything what i can do?
    samisaukkonen91 - 回复
    If the cable is broken, you'll need to purchase a home button assembly and install it in your phone. You'll lose Touch ID functionality, but all other home button functions should act as normal.
    iPhone 6 and 6 Plus Home Button Assembly
    TheJB -
    During this step, I did mistakenly disconnect the cable from the metal connector underneath. However, I was able to remove the metal connector using a spudger and transfer it to the new screen along with the home button cable assembly. Fortunately, touch ID still worked, in addition to all standard home button functions.
    I do think it would be great if iFixIt could add a note about this metal connector during this step as it plays a very important role.
    TheJB - 回复
    I did the same thing! How do you reconnect the metal plate???
    Ian Hodgson - 回复
    Watch out for the metal under the connector! I speant 15 min trying to get the connector unstuck and I didn't even realize you were supposed to remove the metal as well and leave it attached. Ripped my cable because of this (luckily it was an already-broken practice phone). Very important!
    Landon McCoy - 回复
    Don't try to use a spudger behind the metal plate. It is extremely difficult as you can't see if you really could reach the metal under the connector. I ripped the cable doing this way! You better try to reach under the metal from the bottom of connector (not from behind the metal plate!)
    Yang - 回复
    SUPER HELPFUL! Very much appreciated. Thank you!
    JRKoop - 回复
    It’s very important to note that you want to remove the small metal plate underneath the black cable. Use the tab on the black cable near the edge of the phone, gently pull it up until you see the metal plate, then pry underneath the metal plate, and it will just pop up if you put something very small behind it (I used a set of very pointy tweezers).
    Josh A - 回复
    The littel tab of black to the left of the tiny brass connector is a pull tab to aid in removal. As above yo can lift that end (use a thin blade as necessary) and that will help pull the connector loose.
    Jamees Kirwin - 回复
    Start pulling off the side tab with a razor blade thin spudger, such as an iSesamo. To peel the main connector I found the easiest way was to tilt the front panel forward and look inside from the other end, enough to discover that there a metal plate right beneath the connector. You want to place the iSesamo right beneath that metal plate and the whole thing comes off.
    Pau - 回复
    I was able to remove the cable with heat and put it back on the new display. It did not stick so good, but the cable was connected with the one from the Home Button.
    However the TouchID didn’t work but the home buttone does. Is this cable responsible for both and if so is it possible that only the TouchID wires in it have some damage/issue? Thanks for the answers
    Vladimir Palukov - 回复
结论
要重新组装设备,请按照逆序阅读这些说明。
1212等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Sam Goldheart
于10/18/12注册
465,777 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
123条评论
Did this replacement and the finger scaner stop working. I didnt damge anything im a experienced technician the button still worked but the finger print doest work. I thought the firmware was corrupted and I updated the phone. It now shows an error and can not be restore to normal functionality, its stuck in restore mode . I had to reassemble the phone and set it to pay and paid a fee for a new one.
matthewlevy300 - 回复
Wow man, i'm sorry to hear that.. Hate that kinda things.
Niels Aasted -
I have same issue , i tried many time to restore the phone after Touch ID failed , but restore cant be completed because of error #53 ,
basilaldossari -
Same problem! Same backround! Need help :/
mmummler -
Is there any more reason to disconnect the battery on the 6 than any previous iPhone? I've repaired countless 5,5c and 5S without disconnecting the battery. Never a problem.
DNATECH LONDON -
I had this issue once, with an apparently broken TouchID when the cable was perfectly preserved and everything.
I played around with some spare parts and it turned out that the culprit was that the display was not OEM- the TouchID has to pass info through the display to the motherboard and non-OEM displays disrupt this process.
The way to fix this is to purchase a new display again from a more reliable source that has a trustworthy OEM claim.
a059970 -
ok just swapped a lcd and home button flex cable that connects to the motherboard. Now the phone is not turning on at all... Plugged in does not show any charging and has no heat coming from the phone at all. Testing to see if lcd backlight is damaged does not show anything as the vibration button switched does nothing
Anything else helpful might help with this.
JasonW - 回复
I have the same problem. Have you fixed this?
amyleighox -
On step 34, every attempt I have to pry that sensor cable off the front housing I keep breaking the cable. Any idea on how to effectively remove it so I don't have to keep re-purchasing this part?
jta0017 - 回复
Warm it up a bit with a heatgun, makes the bonding adhesive a bit softer and you can then lift it up safely with a spudger.
Paul L Daniels -
Actualy you don’t have to pry the home button connector, you could just change backplate from old display to a new one with home button attached to a connector on a display backplate .
Дмитрий Када -
Same problem, same backround! Dont really know what to do! Did you find an answer?
mmummler - 回复
Shouldn't there be a disconnect-battery step, before attempting to remove the screen cable hold-down panel?
Paul L Daniels - 回复
See step 11 to 13 bro..
Archy Nilo -
Hi, I managed all the disassembly fine getting all the cables off safely and remembering to take the battery lead off, however now its together the screen works but the digitalizer is very sluggish and feels not as sensitive. You need to put a whole finger on it rather than just your tip. Has anybody had anything similar?
Andrew P - 回复
Hi Andrew, I have the same problem, how did you fix it?
lt33 -
I've read that aftermarket screens react slower. I'm not 100% sure tho, so you'll have to check if that information is correct.
Didier Daniel -
Hi
The last step in screen reassembly, when pressing the bottom Bart of the screen, I broke the lower part of the screen.
Seems like so thing is pushing it up.
Don't know what to do,,,, very !#^&@@ off....
Be careful
eliasgh - 回复
I have the same issue. Did you ever figure out what to do?
Jody -
Is there a guide to replace the glass only?
Marc Hershey - 回复
Don't do it! I strongly discourage! I am in the midst of it and its just not worth it.
Brenda -
I took the front screen off to fix some water damage. I put it back together and started charging the phone. I am getting white lines on the screen but the touch screen is not working. Help!
John G - 回复
Sounds like you might have damaged the digitiser where the cable exits. Very easy to do. Happened to me once and I didn't notice at all at the time
rpaschke -
I can't workout if the LCD Screen is glued to the Digitizer, on the phone the LCD is working it's just the front panel... will they separate ?
Wayne Taylor - 回复
LCD is fused to the digitizer. You need to scrape off and rebond the glass if you want to just replace the glass. You need a UV light and UV glue in order to fuse the new glass to the old digitizer. It's easier to just replace the whole thing but it's slightly more expensive to do so.
ryanatakahashi -
They are laminated together at the factory. But with some very expensive tools and the right equipment, it can be done. As you will see on this video, the edges of the glass & digitizer have to be heated and then separated with dental floss and then the adhesive has to be removed with a hot blade. https://www.youtube.com/watch?v=6VRnOwyQ...
Darrell Castleberry -
I didn't take the battery out. I disembaled and reassembled everything carefully without damaging anything but now my phone won't turn on! Is there anything I can do?
csi - 回复
basically IOS 9 made t so if you update your phone with a different fingerprint scanner than your phone came with you get an error 53 upon updating theirs really nothing you can do to help that, just a heads up don't replace Touch ID!
benjigarcia19 - 回复
Followed this guide to replace the broken glass panel on my iPhone 6. I took my time and worked slowly as this was the first iPhone I've ever disassembled. After reading some of the comments, I did disconnect the battery between steps 9 & 10 before doing any of the following procedures. I had some tense moments removing the camera and the home button. They were glued down pretty well, but I eventually got them off. Assembling was pretty easy, but one thing to take notice of is the order of the ribbons attached to the screen. I had to take the camera out twice because the ribbons were not in the correct order to connect back to the power board. Also my home button cord got disconnected when I was putting the case back together. On power-up the button did not work. I had to go back in and remove the plate surrounding those cables and found it was disconnected. I put everything back together and it is working perfectly. No issues with the screen, the cameras, the home button, or the finger print reader. Success!
robstewart - 回复
How did you replace the cables that were in the wrong order? Im having the same problem!
laurensmolic -
So did you use a different Home Button or a replacement? My understanding was that if a replacement is used, then the fingerprint reader will no longer work. The original home button is synced to that phone and no other fingerprint reader will work with it. Just interested. I'm getting ready to do this myself. Have a great day and thanks for posting.
My first tip is if this is your first breakage, and your phone has never been opened, just take it to Apple, it's £79 in the UK, cheaper than buying the screen from most places, and you know it's legit. Onto my SUCCESS, it took a while after numerous minor errors putting it all back together, but after going over the images again, I succeeded. Don't get me wrong, this wasn't a walk in the park, but steady hands and perseverance and you'll get there. For a while I was getting two errors when trying to get it back up and running, and it was stuck in restore mode. I had both 9 and -18 error codes. However, after going back into the iPhone, and popping all the cables off at step 12-15 and then reseating them again. It finally got going again ready for me to test it all. The only other problem was the touch button, but after reseating it a couple of times, I realised I was screwing it up too tight and so finally got it to work. So relieved & happy, but my next iPhone I'm just going straight to Apple.
DanO - 回复
Followed the guide step by step, not a single issue! Thank you!
SMcC21985 - 回复
My first time ever taking apart any phone. Did the fix in about an hour. Be careful with the adhesive on the home button. Mine got a bit mangled and although the button still works like it should, gone is the 'click' sound that it used to have (which I'm actually happy about). Otherwise, great instructions!
david - 回复
I removed my OEM screen then refitted it, and bam! - no more Touch ID :-( Also when the iPhone's screen's gone black (after timeout), it no longer wakes up with the home button!? I have to press the power button now to wake it up, then enter the passcode. Boring!
I then bought a new display online, did the same repair again and replace the screen (with my original home button/camera/mic/speaker etc) and it's still the same: I now have a nice new screen (no longer cracked), but no touch id and no wakeup with home button.
Interestingly, when I try to set up the touch id, it goes to the touch id setup screen, and then immediately gives this error message: "Unable to complete Touch ID setup. Please go back and try again."
Also, when I try updating to OS 9.2.1 (already downloaded), it 'verifies update', then gives this error message: "Unable to Install Update An error occurred installind IOS 9.2.1."
The options are 'Retry' (same result) or 'Remind Me Later'.
Now what!?
naughtyG - 回复
Did you ever remedy this? Had the EXACT same issue and stumped as to why it's occuring - very strange...
Topper -
same for me, moved the original home button to the new screen. all but this is well: my touch id is gone, and no wake up with home button. need to tap power button to wake it up, if the phone has been resting for a while.
omniraal -
Found my error for the same problem: my home button cable had been slightly damaged, i had to look extremely thoroughly on the connector. I bought a new cable and followed the guide here on ifixit.com, and boom: perfect result! Phone is now as good as new!
omniraal -
I changed my screen and now my earpeice does not work, cant here people talking, only can hear on speaker phone. Front camara works and so does the proxy sensor. I might have touched the flex cable connector for those components so i was thinking maybe oil from my finger might be the problem with not hearing people talking. What would be the best way to clean it and see if thats the problem. Or any other ideas would be great .
Greg - 回复
Did you get a resolution to your problem? I am having the same issue. I am thinking maybe I should just buy a new ear piece but wanted to see if there was another option first.
Jennifer Reese -
Thanks!
Worked like a charm with iFixit replacement screen (and a small pack of snacks found in ifixit box). Touch ID came out pretty easy after heating up the glass just a bit and works without issues after replacement.
Pavlo Sulimenko - 回复
Did you replace the Home Button as well? And if you did, did your fingerprint ID work? Or were you able to salvage the original Home Button? I hear that's where all the fingerprint ID issues are coming from. Thanks, Darrell
Question about the battery removal.
I followed the instructions,(which did not include removing the battery). Disassemble went great. Reassemble didn't work so good as my patience is fried and I want to take to a repair store to let them do it. They refused it saying b/c I did not remove the battery, I created an electrical arc and they wouldn't touch it. Before I do it myself, is this true? I see above people also did not remove the battery and it worked fine. Pros? Cons? Advice?
Brenda - 回复
The list of needed tools and parts for this repair could be more clear. The repair kit should be listed at top (it's not listed at all). Also, the repair kit page lists the "iOpener" tool as required but that tool is not used for this repair.
dtype1 - 回复
Followed the guide step by step, not a single issue! I've never replaced or repaired anything on an iPhone before so this was my first try at anything like this. Instructions were great and everything went perfect! Thank you!
troyhowatt - 回复
I replaced the rear lens on my phone. followed the steps to disassemble and reassembled. My phone now won't turn on. But when I plug into PC the PC recognises the phone. No vibrations etc coming from the phone. Tried charging and the camera felt a bit warm. Any ideas?
amyleighox - 回复
I am having a lot of trouble reattaching the cable connectors . They seem to be in the wrong order. Any suggestions??
laurensmolic - 回复
I finished. The first time I assembled everything all was working perfectly except for the earpiece - I couldn't hear anything. I saw on another posted question that someone responded that the gold prongs on the the earpiece had to be aligned "just right", or it wouldn't work. Additionally, the metal cover shouldn't be screwed in too tightly. I realigned and was a little less restrictive with my screw tightening - and now I am up and running. I am so happy! I totally ruined my screen and really was shocked that it still worked. Thank you to everyone who takes the time to give advice and assitance!
Alison - 回复
Yeah, did it and it works!!!! soooooooo happy!!!!!!!
Nina Potenza - 回复
Touch ID stopped working after the replacement. What could be wrong?
lvb - 回复
I dropped my phone several days ago and now the screen won't display anything. My wife has the same phone as I do. I swapped displays with hers and I still didn't get anything. Any idea what else I could check?
Cliff Roebuck - 回复
Hey Cliff. Usually, (if you didn't break your screen) all that has happened is that one of your ribbon cable connections on the inside of the phone has come loose or partially unplugged. There are a lot of other things that could have happened but this is an easy DIY check before you take it to someone who will most assuredly ask for a substantial amout of your hard-earned cash. Now, you will have to order an iPhone repair kit unless you have Pentalobe screwdrivers. But this little tool kit can come in handy for more than just your phone. Here's a video that might help you out if you can tolerate his loud voice. https://www.youtube.com/watch?v=ny8mHGHX... .
There are many kits out there but here's something on Amazon for you to gauge by. https://www.amazon.com/Warmstor-Complete...
Good luck to you and let me know if this works for you.
i have a question.
kjh657 - 回复
Yes. If you change the cable on the plate, your Touch ID will still work if it's the original button. It's only when you change the button itself that Touch ID functionality is lost.
Didier Daniel -
Hello all,
Just did this without breaking any cables, or so I thought...
Reassembled everything and phone turned on (success) but I have lost the touch ID capability, the home button still works so I can use the phone but is this a security measure from apple? I used the existing home button.
Thanks
Tom - 回复
First time ever replacing a iPhone 6 lcd and screen, love the pics, you make it very easy to follow!! :-)
apriltanner1975 - 回复
I'm doing a screen replacement with a new screen that doesn't already have the home button cable attached to the digitizer. How do I get the cable from the old screen to the new one so I can connect the home button?
juliamcrae - 回复
Exactly what was expected for an experienced tech.
Excellent guide!!
Thanks Monte
Montgomery James Kern - 回复
Completed the guide but my screen is not flush with the body any more. But it was no problem putting it in. TouchID etc. are working fine, it is more in the middle part where the screen has a noticable height (bump). I have the impression it is higher than the original part (the eustore.ifixit.com front cover). But happy that the display works!
If the display doesn't properly clip in, be sure all the cables are properly arranged, and make sure your battery hasn't swollen up. If you have issues, don't hesitate to contact EU customer support!
Sam Goldheart -
Is it necessary to buy all parts listed at the top right? I thought only a screen would be needed of that is what has been damaged.
William Mullan - 回复
The parts listed at the top are the parts that can be replaced using this guide. If you're just replacing the screen, you only need to buy the screen =)
Sam Goldheart -
On the *very last step* of disassembly the home button cable would *not* come up. It finally tore. Post mortem analysis showed that it took a *lot* of pressure to remove it -- I don't know how one would get this off without tearing. I am going to go cry now. Bye.
Wayne Cochran - 回复
For the home button, it helps to lift a corner of the gasket from it's adhesive to the phone, then work it up from there. So sorry it tore :(
bwojciehowski -
Hi guys, did this today, all works well except:
- i have some irregular white vertical lines. They come and go
- sometimes I have green dots on the left of the screen. They also come and go (but come more seldom)
- the display looks odd. Just as if the resolution was not the correct one
I tried re-opening and checking the display data connector, it looks like it's in place.
Any idea? All went well except: during re-assembly, the display data and the front camera ribbons got mixed up so for a couple of minutes I was trying to insert the front camera ribbon into the display connector ... Hope I didn't damage it :(
Any help is welcome.
Guillaume Klein - 回复
When re-assembling I accidently switched the front facing connector and the digitizer, which broke the digitizer socket on the main board. Now the phone is bricked. Please notice that you need to guide the digitizer cable under the other cables after mounting the back plate, otherwise it is easy to switch the two long connectors, and then you breake the socket and your phone is dead.
Tom - 回复
Hello, my Iphone 6's screen was broken. I bought a new one.
I read these differents steps but at the end my new screen doesn't work.
I used a torch and i could see the apple, the message very slightly I thought i have a problem with my backlight but i don't know what i can do!!!
I bought another screen but i had the same problem!
Please help me!! thanks
KLEBER - 回复
Good guide for pretty much every step except for removing the home button ribbon cable during the LCD shield plate (step 37) look at dv1997's comment! This is a much easier and safer way of doing things! There is a metal plate which is part of the underside of the ribbon cable which is very difficult to get the spudger under by going under the shield plate. It's much easier to get it from the front using the ribbon cable pull tab on the side.
Thomas Hallett - 回复
A cutter / utility blade can do wonders too :)
Didier Daniel -
Just successfully finished replacing a screen using this guide, for my very first time. In total, it took me three hours, taking breaks in-between and reading through all comments that have been posted.
My best advice is to be patient and take your time with each step. The most tedious steps were #22-26 (front camera assembly), #31 (home button) and #37 (home button cable). Be patient and read all comments regarding these steps.
During step #37, I did mistakenly disconnect the cable from the metal connector underneath. However, I was able to remove the metal connector and transfer it to the new screen along with the home button cable assembly. Fortunately, touch ID still works, in addition to all standard home button functions. I do think it would be great if iFixIt could add a note about this metal connector during this step; it plays a very important role.
I used only tools from the iFixIt "Classic Pro Tech Toolkit", in addition to an iSesamo. I purchased the replacement screen from iFixIt.
TheJB - 回复
Good guide! Everything worked perfectly fine and I had no problems along the way :)
Kamiel Cherlet - 回复
Step 37 was the worst, as there is intact a small metal plate, that comes off with the adhesive, which cannot be seen on the instructions/pictures
but its all working, thanks a lot!
Rich - 回复
Success! Great guides here on Ifixit! With lots of kids I have replaced about 5 screens on various devices. Finally getting the hang of it. I had an issue with the "order" of the ribbon cable when reassembling, but they were easy to "reorder" them without any further disassembly... Just do it carefully and they will be corrected!
Thanks!
Karl - 回复
Front Facing and Rear Facing Camera aren't working.
Everything appears to be working well except when I pull up the camera, all I get is a back-lit black screen, for both the front facing and rear facing camera. Any ideas? I had a hard time getting the front facing camera onto the display properly, but I don't understand how that would effect the rear facing camera.
takjackson - 回复
some of my google searches says something about a jumper might be missing off the logic board, but I can't tell from what I am looking at.
Image: https://imgur.com/a/hJgV1
Other comments suggest putting the original screen back on and testing it, unfortunately that is not an option as my LCD was busted.
takjackson -
I placed the screen flats above the shield, while they have to go under it.. this is the only way the screen stopped flashing.. what is the impact ?
Abdallah Samy - 回复
Thank you amaizing easy to understand. cheers really apreciate it!!!
thecanvasman - 回复
Do you think about it? https://goo.gl/photo...aN8XCYD2D3kwZh7 Very strange.
WAPIK - 回复
Broken link? Strange indeed.
Stephen Missah -
It is always necessary to disconnect the battery. If you don't disconnect the battery, you can blow a filter that is responsible for the back light on the screen.
brittany.nicole111 - 回复
I have next the same problem. All sensor is clean, good position. I dont know what is problem.
WAPIK -
I have a broken screen. I have a non-working phone that is an exact replica.
1. Can I exchange the entire fronts, without removing the glass? Just swap the entire unit?
2. How does this effect Touch ID? In expect the old fingerprint ID's would die, but can I add them again so they work?
Thank you.
SlotcarBob - 回复
If you want to retain touch-id functionality, you'll have to transfer the original Touch-ID hardware to your new display assembly.
Lance J -
I've successfully changed my screen but I still have those white horizontal lines as mentioned in step 17. I've tried reconnecting the display data cable but it didn't change anything :(
The lines are located right at the bottom of the screen.
Thanks for your help!
Adrien Simon - 回复
Everything went smooth, but I have light leak on top, only when screen is attached to rest of phone. Problem doesn't exists when testing screen outside backcase, phone is not bended, original screen was fine. Any ideas?
https://goo.gl/rA7gCo
maclaw - 回复
CARE WITH ATTACHMENT FOR HOME BUTTON! My home button cable connector was fused to the gold connector bars beneath at step 30 (gold bars attached to the LCD shield plate) so my home button doesn't work now. I tried to separate gently with the spudger but it just damaged. If you are in this situation, I suggest removing all the 7 screws at step 35 and lifting the home button, home button cable connector and the LCD shield plate as one unit. This worked but I had already damaged the connector cable from its attachment.
IF YOU DAMAGE YOUR HOME BUTTON FUNCTION, in settings, general, accessibility, AssistiveTouch allows a moveable "home" button on the touch screen.
Hope that helps someone.
ebeck_ - 回复
I just replaced a front assembly with the home button connector so stiffly attached that the tab to the left of it broke off while trying to lift it. This happened while resting the display on a very hot iOpener. Some phones simply have a much stronger adhesive. My only advice is to gently prod at the connector from the left with the sharp pointy end of a spudger until it eventually comes lose. In this situation, I was eventually able to lift the connector off undamaged, but I feel like it could've been easier the way you've mentioned, by keeping the two parts of the connector together!
drpotter -
If I remove the home button from the old front panel and just put it on the new front panel will it save the fingerprint function.
Antonio the Tinker - 回复
In a word: yes.
Jeff Suovanen -
I've tried everything imaginable to get Touch ID to work. I've been informed by Apple that Touch ID needs to be reset by an Apple technician for the cost of a screen repair ($129) or "other damage" ($299). Can anyone confirm, or is there a magic potion for this?
jaskegreen - 回复
If your Touch ID (home button) hardware is damaged, only Apple can replace it and restore fingerprint functions—the sensor is keyed to your phone at the factory, and no other sensor will work without help from Apple. This is by design, and prevents people from compromising the security of the system by simply replacing the sensor. So yes, if that's your situation, Apple is your only option. (You can replace a damaged home button, but it will only ever work as a home button—no Touch ID.)
Jeff Suovanen -
Great instructions. A bit worried at times, when putting the screen back together but all works great. Thanks
Ashley Green - 回复
I have a question! before I decided to change my LCD screen myself, I took it to a place that told me they could fix my "no response touch screen" problem, they didn´t then offered to replace it for like a million dollars so I decided to do it myself since I have replaced the battery myself on an old iphone many years ago, the thing is when I opened it following all the instructions, I found that the EMI shield (front panel assembly cable bracket) with all the five screws, the one that covers the flex cables, all missing!! so I went ahead and changed it anyway and closed the iphone back up, still no response on the touch screen, the phone turned on and everything, is it possible that the reason my phone is not working is that is missing the EMI shield? on other forums I read that it should work anyway, help please
Dr. Drea - 回复
I'm a noob but, wow! This is a good guide. However, i have a missing screw, idk what it is, went back and checked, had everything, but, oh well. Also left pink protector on back of lcd but everything fit, so, cool?
Aiden Jacob - 回复
Beautiful step by step! Take your time though… it felt i was preforming surgery
mikeyb540 - 回复
the whole repair was quite straightforward. these alternative instructions were helpful at points: http://www.instructables.com/id/iPhone-6... as was this video: https://www.youtube.com/watch?v=mh-cbErz...
before finishing the last step of pushing the screen back into the body of the phone, I turned it on and checked all of the functions - the camera, the light sensor and the touch pad. The touch pad wasn’t working, so I turned it off again, and re-seated the home button cable. when i started it up again, it worked properly. Thank you IFIXIT.COM! and many thanks to all of the other folks who commented here.
banderson - 回复
so I’m about to purchase this iFixit replacement display to repair my wifes iPhone 6 that she’s just dropped and smashed the screen. Am I going to have problems with touch ID not working with the new display? The current home button is still working fine, but I’m concerned if when repairing the phone the new screen causes the touch ID to stop working. Any comments
Matt - 回复
It works fine! :) https://www.youtube.com/watch?v=Ef7HnSjJ... - I’d advice following this too when putting the phone together because the above missed out a few steps
Stephen Missah -
NOTE/WARNING:
These instructions don’t mention the lens and proximity sensor holder/supports. Don’t forget to take them off your old front panel! I would recommend following this video https://www.youtube.com/watch?v=Ef7HnSjJ... when putting your device back together. Simply doing the above in reverse is not enough!!!
Stephen Missah - 回复
When I turned the phone on afterwards, the touch screen didn’t work. The screen looks fine but I cant press the code.
I was struggling with step 15 when I reassemblied, since the connector cables needed to be folded to swich places before they left the front panel. I had then tried to connect the wrong bracket. I cleaned the connectors before trying to put them togheter again, but not really sure if I touched them again anyway.
The removal and reassembly of the home button went smoothly. The touch ID didn’t work since earlier, but the button itself work.
Anyone who knows what to do?
Lena Blosfeld - 回复
The digitizer cable connector hadn’t clicked in deeply enough! When I released the two cables on top, it jumped up by itself. Some persistent but smooth pressing in small cirles, with the finger covering the whole connector at the same time, solved the problem. It works!!!
Lena Blosfeld -
Followed this and other guides to replace the screen and battery. Very nice. Thanks.
spike - 回复
Again, an invaluable guide. I’ve used this several times, never for my own phone thankfully!
James - 回复
I did the screen replacement. Everything went well. But when I click the screen into the frame a grey spot appears on the display. When I unlock the screen from the frame and test it again the spot is gone. Does anybody know why this is happening?
Luc - 回复
Update: problem solved. I did also a battery change and the battery connection cable was pushing against the screen and gave a spot on the display. I reinstalled the battery cable and pushed it a bit lower and now the screen is fine!
Luc -
I followed the directions given exactly and now I just get an battery drained icon, and the phone wont charge. what did i do wrong and how do i fix this?
timothy thomason - 回复
GREAT GUIDE. Got mine working the first try. The only suggestion I would make is have closer-up pictures of the cluster of ribbon cables at the top right….took me a while to figure out I could reorder them pretty easily. Before I figured that out I was CONFUSED.
Chris - 回复
Hi Chris! Click on any guide photo to get a bigger version, click on the magnifying glass on the image and you’ll get a huge version of the photo! Hope this helps you with your next repair!
Sam Goldheart -
Read these instructions, work methodically and make sure you carefully watch where you put your screws (I Blu-Tacked them to my bench) and you will succeed in this repair. The only tense moment for me was removing the home button. I highly recommend heat from a hair drier to soften the adhesive. Also, getting the button back in the new print panel assembly correctly without creasing any of the membrane is difficult - if you grip th button with your thumb and forefinger through the home button opening it can help. But yeah - all functionality including Touch ID has been preserved for me.
James McIntosh - 回复
Muy buena guía. He realizado paso a paso todas las indicaciones y , salvo un pequeño despiste con el orden de los cables flex de la pantalla, todo ha ido genial.
Funcionando pantalla nueva y touch id.
Very good guide. I have done all the instructions step by step and, except for a little cluelessness with the order of the flex cables of the screen, everything went great.Running new screen and touch id.
Antonio Ureba Anillo - 回复
Hi, I was wondering what will happen if you don’t replace the LCD front shield plate? I missed that step but my phone seems to be working fine. Will something happen in the long run if I don’t go back and install the shield plate in my new screen?
Angelina - 回复
Thank you for this incredible helpful guide. I had to replace a broken LCD/Digitizer and I was able to successfully do the repair straight forward. The most difficult part I guess was to put back the front camera / sensor / mic / speaker conglomerate ;). I recommend to use a magnifier to be able to put back all those little screws.
Daves - 回复
I just replaced the broken screen with a pre-assembled screen and digitizer display and I put in a new battery as well. When I power up the phone the white apple logo appears perfectly for four seconds but then it disappears for eight seconds and then reappears for four seconds and so on, it would appear, for infinity. I tried the old battery and reconnected the cables but same problem. I have also connected the phone to an imac to charge. anybody seen this problem before ? I tried a hard reset as well holding power and touch pad at the same time but same result
Sean Wren - 回复
i think your problem may be that you don’t have a secure connection with the battery because when you try to charge your phone without it connected it will do exactly what you said happened
Blake Miller -
Success!. No problems.
Erik Simonič - 回复
You know these instructions are great. I have fixed a handful of phones myself. There is no shortcut to the time involved, but if you take your time and follow you can be successful!!!
Thanks a bunch you guys!!!
NFM Venom - 回复
I replaced the display with the iFixit replacement part. The replacement procedure was a piece of cake. However, the quality of the display is sub-par compared to the original. First thing I recognize was that the you cannot look at the display from even a small angle. Secondly, it is not scratch resistent. And worst of all, it broke after 3 month. I had it in my pant’s pocket together with my keys. Somehow, the keys cracked the screen at the top at the mic slot rendered the phone unusable. That’s it. I am will bite the bullet and take the phone to Apple and have the display replaced with the original Apple part. Too bad Apple does not allow other companies to sell ORIGINAL parts.
Alexander Nowak - 回复
thank you so much for the guide, have been tinkering with iphone 6s and 6, had to change the digitizer again and this time had to also do the whole steps until the end. i didn’t expect i had to also remove the shield plate. lucky its on this guide. thank you again. phone running beautifully now.
nads - 回复
just had my iphone saying it is over heating after replacing the digitizer. not sure why. any recommendations?
nads -
anyone experiencing heating after whole digitizer replacement, check your front camera if it is working, if not might be like mine where it is not working and the cause to the overheating. might be the flex cable of it.
nads - 回复
I replaced my screen with the iFixit Kit and transferred the home button successfully. After reassembling the iPhone the wifi signal is weak. When lifting the screen from the housing the signal becomes strong, putting back the screen onto the housing it is weak again. Any ideas? Some shortage?
Axel - 回复
Good a proper guide with screw sizes ans cautions when accidents are likely to happen. Thanks sam
Robert Hopkins - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 97
过去 30 天: 451
总计 927,421
