跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Pro Front Camera Assembly Replacement
你所需要的
  1. iPhone 16 Pro Front Camera Assembly Replacement, Prepare the phone for disassembly: 步骤 1 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Prepare the phone for disassembly: 步骤 1 中的图像 2,2
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
    添加评论
  2. iPhone 16 Pro Front Camera Assembly Replacement, Tape over any cracks: 步骤 2 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Tape over any cracks: 步骤 2 中的图像 2,2
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    询问修复机器人
    添加评论
  3. iPhone 16 Pro Front Camera Assembly Replacement, Mark your opening picks: 步骤 3 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Mark your opening picks: 步骤 3 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Mark your opening picks: 步骤 3 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    询问修复机器人
    添加评论
  4. iPhone 16 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: 步骤 4 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: 步骤 4 中的图像 2,2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
    询问修复机器人
    添加评论
  5. iPhone 16 Pro Front Camera Assembly Replacement, Heat the bottom edge: 步骤 5 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Heat the bottom edge: 步骤 5 中的图像 2,2
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    添加评论
  6. iPhone 16 Pro Front Camera Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Insert an opening pick: 步骤 6 中的图像 3,3
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
    询问修复机器人
    添加评论
  7. iPhone 16 Pro Front Camera Assembly Replacement, Back glass information: 步骤 7 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Back glass information: 步骤 7 中的图像 2,2
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
    询问修复机器人
    添加评论
  8. iPhone 16 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: 步骤 8 中的图像 3,3
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contact.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  9. iPhone 16 Pro Front Camera Assembly Replacement, Heat the right edge: 步骤 9 中的图像 1,1
    • Heat the right edge of the back glass until it's hot to the touch.
    询问修复机器人
    添加评论
  10. iPhone 16 Pro Front Camera Assembly Replacement, Separate the bottom right corner adhesive: 步骤 10 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Separate the bottom right corner adhesive: 步骤 10 中的图像 2,2
    • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  11. iPhone 16 Pro Front Camera Assembly Replacement, Heat the left edge: 步骤 11 中的图像 1,1
    • Heat the left edge of the back glass until it's hot to the touch.
    添加评论
  12. iPhone 16 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: 步骤 12 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: 步骤 12 中的图像 2,2
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  13. iPhone 16 Pro Front Camera Assembly Replacement, Heat the top edge: 步骤 13 中的图像 1,1
    • Heat the top edge of the back glass, including the area around the volume buttons, until it's hot to the touch.
    询问修复机器人
    添加评论
  14. iPhone 16 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: 步骤 14 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: 步骤 14 中的图像 2,2
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You'll hear and feel clicks as the top two clips release.
    询问修复机器人
    添加评论
  15. iPhone 16 Pro Front Camera Assembly Replacement, Swing open the back glass: 步骤 15 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Swing open the back glass: 步骤 15 中的图像 2,2
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
    • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
    询问修复机器人
    添加评论
  16. iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the battery: 步骤 16 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the battery: 步骤 16 中的图像 2,2
    • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
    • Two 1.2 mm‑long screws
    • One 1.0 mm‑long screw
    询问修复机器人
    添加评论
  17. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 17 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 17 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 17 中的图像 3,3
    • Use tweezers or your fingers to pick up and remove the lower connector cover.
    询问修复机器人
    添加评论
  18. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 18 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 18 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 18 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    询问修复机器人
    添加评论
  19. iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the back glass: 步骤 19 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the back glass: 步骤 19 中的图像 2,2
    • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
    • Two 1.0 mm‑long screws
    • One 1.2 mm‑long screw
    • One 1.6 mm‑long screw
    询问修复机器人
    添加评论
  20. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 20 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 20 中的图像 2,2
    • Use tweezers or your fingers to pick up and remove the upper connector cover.
    询问修复机器人
    添加评论
  21. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 21 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 21 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
    询问修复机器人
    添加评论
  22. iPhone 16 Pro Front Camera Assembly Replacement, Remove the back glass: 步骤 22 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Remove the back glass: 步骤 22 中的图像 2,2
    • Lift the back glass off the frame and remove it.
    询问修复机器人
    添加评论
  23. iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the earpiece speaker: 步骤 23 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the earpiece speaker: 步骤 23 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the earpiece speaker: 步骤 23 中的图像 3,3
    • The 5G mmWave antenna is only in United States and Puerto Rico iPhone 16 Pros (model A3083). For all other models, skip the next four steps.
    • Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors, located on the top right corner of the logic board.
    询问修复机器人
    添加评论
  24. iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 步骤 24 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 步骤 24 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: 步骤 24 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the two front camera assembly press connectors underneath the previous two.
    询问修复机器人
    添加评论
  25. iPhone 16 Pro Front Camera Assembly Replacement, Remove the front camera assembly: 步骤 25 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Remove the front camera assembly: 步骤 25 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Remove the front camera assembly: 步骤 25 中的图像 3,3
    • Use a spudger or your fingers to pick up the front camera assembly and remove it from the phone.
    询问修复机器人
    添加评论
  26. iPhone 16 Pro Front Camera Assembly Replacement, Disassembly complete: 步骤 26 中的图像 1,1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone. Some of the reassembly photos show the Pro Max model, but the procedure is correct for the Pro.
    询问修复机器人
    添加评论
  27. iPhone 16 Pro Front Camera Assembly Replacement, Install the front camera assembly: 步骤 27 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Install the front camera assembly: 步骤 27 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Install the front camera assembly: 步骤 27 中的图像 3,3
    • Lay the front camera assembly in its recess.
    • Gently tuck the camera flex cables into the gap between the rear camera assembly and the earpiece speaker assembly.
    询问修复机器人
    添加评论
  28. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 28 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 28 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 28 中的图像 3,3
    • Use your fingers or a spudger to push the front camera flex cables up towards the earpiece speaker, then tuck them in the gap between the earpiece speaker and the logic board.
    询问修复机器人
    添加评论
  29. iPhone 16 Pro Front Camera Assembly Replacement, Connect the front camera assembly: 步骤 29 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Connect the front camera assembly: 步骤 29 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Connect the front camera assembly: 步骤 29 中的图像 3,3
    • Use your finger or a spudger to connect the two front camera assembly press connectors, located on the top edge of the logic board.
    询问修复机器人
    添加评论
  30. iPhone 16 Pro Front Camera Assembly Replacement, Connect the earpiece speaker: 步骤 30 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Connect the earpiece speaker: 步骤 30 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Connect the earpiece speaker: 步骤 30 中的图像 3,3
    • Use your finger or a spudger to connect the earpiece speaker and 5G mmWave antenna (US models only) press connectors, located on the top right corner of the logic board.
    询问修复机器人
    添加评论
  31. iPhone 16 Pro Front Camera Assembly Replacement, Remove the leftover adhesive: 步骤 31 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Remove the leftover adhesive: 步骤 31 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Remove the leftover adhesive: 步骤 31 中的图像 3,3
    在这个步骤中使用的工具:
    • Work around the fragile grounding clips as you're cleaning the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
    • Use a spudger to scrape the adhesive residue off of the frame.
    • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
    询问修复机器人
    添加评论
  32. iPhone 16 Pro Front Camera Assembly Replacement, Clean the back glass: 步骤 32 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Clean the back glass: 步骤 32 中的图像 2,2
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
    询问修复机器人
    添加评论
  33. iPhone 16 Pro Front Camera Assembly Replacement, Clean the frame: 步骤 33 中的图像 1,1
    • Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
    询问修复机器人
    添加评论
  34. iPhone 16 Pro Front Camera Assembly Replacement, Apply the replacement adhesive: 步骤 34 中的图像 1,1
    • Lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
    添加评论
  35. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 35 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 35 中的图像 2,2
    • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
    添加评论
  36. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 36 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 36 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 36 中的图像 3,3
    • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
    询问修复机器人
    添加评论
  37. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 37 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 37 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 37 中的图像 3,3
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
    询问修复机器人
    添加评论
  38. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 38 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 38 中的图像 2,2
    • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
    • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Don't press too hard, or you'll stretch and deform the adhesive.
    询问修复机器人
    添加评论
  39. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 39 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 39 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 39 中的图像 3,3
    • Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
    • Use the pull tab to peel off the large front liner from the adhesive.
    • At this point, you may still have a liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
    询问修复机器人
    添加评论
  40. iPhone 16 Pro Front Camera Assembly Replacement, Connect the back glass: 步骤 40 中的图像 1,1
    • Prop up the back glass along the right edge of your iPhone.
    询问修复机器人
    添加评论
  41. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 41 中的图像 1,1
    • Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
    询问修复机器人
    添加评论
  42. iPhone 16 Pro Front Camera Assembly Replacement, Connect the battery: 步骤 42 中的图像 1,1
    • Use your finger or a spudger to press and connect the battery press connector onto the logic board.
    • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
    • If your iPhone doesn't turn on, connect it to a power source and try again.
    • If you've replaced the logic board and the screen fails to turn on, you'll need to follow the screen guide to manually connect the display connector.
    询问修复机器人
    添加评论
  43. iPhone 16 Pro Front Camera Assembly Replacement, Install the connector covers: 步骤 43 中的图像 1,1
    • Align the back glass connector cover by its screw holes and lay it in place.
    询问修复机器人
    添加评论
  44. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 44 中的图像 1,1
    • Use a tri-point Y000 driver to install the four screws securing the back glass connector cover:
    • Two 1.3 mm‑long screws
    询问修复机器人
    添加评论
  45. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 45 中的图像 1,1
    • Align the battery connector cover by its screw holes and lay it in place.
    询问修复机器人
    添加评论
  46. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 46 中的图像 1,1
    • Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
    询问修复机器人
    添加评论
  47. iPhone 16 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: 步骤 47 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Remove the final adhesive liners: 步骤 47 中的图像 2,2
    • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
    • As you remove the liners, make sure nothing touches the exposed adhesive.
    • Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
    询问修复机器人
    添加评论
  48. iPhone 16 Pro Front Camera Assembly Replacement, Install the back glass: 步骤 48 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Replacement, Install the back glass: 步骤 48 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Replacement, Install the back glass: 步骤 48 中的图像 3,3
    • Lower the back glass onto the frame, beginning with the top edge.
    • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
    • Press along the edges of the iPhone until the back glass sits flush against the frame.
    询问修复机器人
    添加评论
  49. iPhone 16 Pro Front Camera Assembly Replacement, Apply heat to the perimeter: 步骤 49 中的图像 1,1
    • Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
    • The heat softens the adhesive and helps create a better bond.
    询问修复机器人
    添加评论
  50. iPhone 16 Pro Front Camera Assembly Replacement, Apply pressure to the perimeter: 步骤 50 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Apply pressure to the perimeter: 步骤 50 中的图像 2,2
    • Use your fingers to firmly squeeze around the perimeter of the iPhone.
    询问修复机器人
    添加评论
  51. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 51 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 51 中的图像 2,2
    • Place your iPhone screen-side down on a clean, flat work surface.
    • Lay a strip of tape around the perimeter of the back glass to protect the finish.
    • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
    • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
    询问修复机器人
    添加评论
  52. iPhone 16 Pro Front Camera Assembly Replacement: 步骤 52 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement: 步骤 52 中的图像 2,2
    • Place 3-4 heavy books squarely on top of your iPhone.
    • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
    • Leave the books in place for about 30 minutes.
    • The pressure will help activate the adhesive.
    询问修复机器人
    添加评论
  53. iPhone 16 Pro Front Camera Assembly Replacement, Install the pentalobe screws: 步骤 53 中的图像 1,2 iPhone 16 Pro Front Camera Assembly Replacement, Install the pentalobe screws: 步骤 53 中的图像 2,2
    • Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
    询问修复机器人
    添加评论
结论
After your repair, calibrate a genuine replacement front camera assembly using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers Community for help.
取消:我没有完成这个指南。
Nick Schultz
于03/24/24注册
57,747 声望
创作了316篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了26,617篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 60
过去 30 天: 251
总计 3,219
