跳转到主内容
iPhone 11 Pro 屏幕更换
你所需要的
  1. iPhone 11 Pro 屏幕更换, 移除五角螺丝: 步骤 1 中的图像 1,2 iPhone 11 Pro 屏幕更换, 移除五角螺丝: 步骤 1 中的图像 2,2
    • 开始之前,请为 iPhone 电池放电25%以下。如果意外刺穿,已充电的锂离子电池可能着火和/或爆炸。
    • 开始拆卸前,请关闭iPhone的电源。
    • 移除 iPhone 底部边缘的两颗6.7毫米长的五角螺丝。
    • 打开 iPhone 的显示屏将损害其防水密封性。在执行此步骤之前,请准备好备用密封条,或者如果在不更换密封条的情况下重新组装iPhone,请小心避免液体暴露。
    I am having difficulty accessing the disassembly steps to remove all of the components from the rear case. This web site stops at step 1. I am not sure how to access the rest of the steps. Can you help. Domingo Rochin
    Mingo59 - 回复
  2. iPhone 11 Pro 屏幕更换, 标记你的三角撬片: 步骤 2 中的图像 1,3 iPhone 11 Pro 屏幕更换, 标记你的三角撬片: 步骤 2 中的图像 2,3 iPhone 11 Pro 屏幕更换, 标记你的三角撬片: 步骤 2 中的图像 3,3
    • 如果插入太深,三角撬片可能会损坏你的设备。 按照此步骤标记撬片并防止损坏。
    • 从尖端测量 3 毫米,并用永久性记号笔标记三角撬片。
    • 你还可以用不同的尺寸标记三撬片的其他角。
    • 或者,将 将一枚硬币 粘在距撬片尖端 3 毫米处。
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - 回复
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - 回复
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - 回复
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - 回复
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - 回复
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - 回复
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - 回复
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - 回复
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - 回复
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - 回复
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - 回复
  3. iPhone 11 Pro 屏幕更换, 用胶带覆盖破损: 步骤 3 中的图像 1,3 iPhone 11 Pro 屏幕更换, 用胶带覆盖破损: 步骤 3 中的图像 2,3 iPhone 11 Pro 屏幕更换, 用胶带覆盖破损: 步骤 3 中的图像 3,3
    • 如果 iPhone 的后玻璃破裂,请在维修过程中通过在玻璃上贴胶带来防止进一步破损并防止人身伤害。
    • 将重叠的透明包装胶带条黏在 iPhone 的后玻璃上,直到覆盖整个手机后部。
    • 戴上安全眼镜以保护你的眼睛免受修理过程松散玻璃的伤害。
    • 如果在接下来的几个步骤中无法让吸盘粘在手机上,请将强力胶带(折叠到把手中,然后用它提起后玻璃。
    • 如果所有措施都不可行,你可以用502胶把吸盘粘到后玻璃上。
  4. iPhone 11 Pro 屏幕更换, 反向钳使用指南: 步骤 4 中的图像 1,3 iPhone 11 Pro 屏幕更换, 反向钳使用指南: 步骤 4 中的图像 2,3 iPhone 11 Pro 屏幕更换, 反向钳使用指南: 步骤 4 中的图像 3,3
    • 接下来的两个步骤演示了如何使用反向钳,一个旨在简化打开过程的工具。 如果你不使用 反向钳,请跳过这两个步骤以使用替代方法。
    • 有关如何使用 反向钳的完整说明,请查看本指南
    • 将蓝色手柄拉向铰链以解除开启模式。
    • 将反向钳手臂滑过 iPhone 的左边缘或右边缘。
    • 将吸盘放在屏幕上主页按钮的正上方——一个在前面,一个在后面。
    • 向下推吸盘以将吸力施加到所需区域。
    • 如果发现设备表面太光滑而反向钳无法吸住,请使用包装胶带来创造一个更容易抓握的表面。
  5. iPhone 11 Pro 屏幕更换: 步骤 5 中的图像 1,3 iPhone 11 Pro 屏幕更换: 步骤 5 中的图像 2,3 iPhone 11 Pro 屏幕更换: 步骤 5 中的图像 3,3
    • 向前拉蓝色手柄以锁定手臂。
    • 顺时针转动手柄 360 度或直到吸盘开始拉伸。
    • 确保吸盘彼此对齐。 如果在拉伸过程中吸盘慢慢不对齐,请松开吸盘并重新对齐手臂。
  6. iPhone 11 Pro 屏幕更换: 步骤 6 中的图像 1,3 iPhone 11 Pro 屏幕更换: 步骤 6 中的图像 2,3 iPhone 11 Pro 屏幕更换: 步骤 6 中的图像 3,3
    • 加热 iOpener 并将其穿过反向钳臂。
    • 你也可以使用 吹风机热风枪 或热板,但过热可能会损坏显示屏和/或内部电池,因此请小心操作。
    • 折叠 iOpener,使其位于 iPhone 底部边缘。
    • 等待一分钟,让胶水软化并出现一个缝隙。
    • 将三角撬片插入屏幕和塑料边框下方的间隙,而不是屏幕本身。
    • 如果反向钳无法创造出足够的间隙,请对该区域施加更多热量并将手柄旋转四分之一圈。
    • 一次不要旋转超过四分之一圈,并在每次旋转之间等待一分钟。 让反向钳和时间为您完成工作。
    • 跳过接下来的三个步骤。
    If the display is separating from the plastic, and the plastic is not rising in the middle, then you have forgotten step 1! The screws that hold the plastic to the bottom are still there! Stop fighting it, and go back to step 1! I made this mistake on my livestreamed repair on my youtube channel, somehow I managed to get it out with the screws attached, hopefully my display works! I gave up on the anti-clamp, used a hand suction on the bottom right corner with heat gun, used pry tool on the bottom right corner, and used another spudger along the middle which I guess bent the holes the screws go in so that it released the front. I also skipped over the slide action that is necessary. Also the adhesive on my phone was so intense it was a continual battle. Hopefully my display works!
    Benjamin Lupton - 回复
  7. iPhone 11 Pro 屏幕更换, 加热手机的下边缘: 步骤 7 中的图像 1,1
    • 加热iPhone的下缘将有助于软化固定显示屏的胶水,使其更容易打开。
    • 使用吹风机或准备一个iOpener,并将其放到手机的下缘约90秒,以软化下面的粘合剂。
    I used a regulated heating gun, 180 degree celsius, 60 percent airstream, moving constantly around the edges for two minutes - works great for me.
    einhanseat - 回复
  8. iPhone 11 Pro 屏幕更换: 步骤 8 中的图像 1,2 iPhone 11 Pro 屏幕更换: 步骤 8 中的图像 2,2
    • 如果你使用的是单个的吸柄,请将其贴在手机的底部边缘,同时避开玻璃的弯曲部分。
  9. iPhone 11 Pro 屏幕更换, 轻轻提起屏幕: 步骤 9 中的图像 1,3 iPhone 11 Pro 屏幕更换, 轻轻提起屏幕: 步骤 9 中的图像 2,3 iPhone 11 Pro 屏幕更换, 轻轻提起屏幕: 步骤 9 中的图像 3,3
    • 用稳定、持续的力量拉起吸盘,使前面板和后壳之间产生一个微小的缝隙。
    • 请将撬片插入屏幕和塑料边框下方的间隙,不是屏幕本身 .
    • 用于固定显示屏的防水胶水非常牢固; 完成这个步骤可能需要很大的力量。 如果你在打开缝隙时遇到困难,应该对其实施进一步的加热,并上下轻轻摇动屏幕,以削弱胶水的粘性,直到能够打开一个足够大的缝隙来插入工具。
  10. iPhone 11 Pro 屏幕更换, 分离屏幕胶水: 步骤 10 中的图像 1,3 iPhone 11 Pro 屏幕更换, 分离屏幕胶水: 步骤 10 中的图像 2,3 iPhone 11 Pro 屏幕更换, 分离屏幕胶水: 步骤 10 中的图像 3,3
    • 用三角撬片划动开口,从手机的下边缘开始一直到手机的左边缘,然后向音量控制按钮和静音开关划动,划开固定显示屏的粘合剂。
    • 不要将三角撬片插入超过3毫米,否则可能会损坏内部组件。
  11. iPhone 11 Pro 屏幕更换, 注意事项: 步骤 11 中的图像 1,1
    • iPhone 的右边缘有一根易损的排线。请勿在此插入三角撬片 ,你很可能会损坏排线。
  12. iPhone 11 Pro 屏幕更换: 步骤 12 中的图像 1,3 iPhone 11 Pro 屏幕更换: 步骤 12 中的图像 2,3 iPhone 11 Pro 屏幕更换: 步骤 12 中的图像 3,3
    • 将工具重新插入到iPhone的右下角,并将其划到手机右上角,以划开粘合剂。
    • 请勿将撬片插入超过 3 毫米,否则可能会损坏显示屏排线。
  13. iPhone 11 Pro 屏幕更换: 步骤 13 中的图像 1,3 iPhone 11 Pro 屏幕更换: 步骤 13 中的图像 2,3 iPhone 11 Pro 屏幕更换: 步骤 13 中的图像 3,3
    • 显示屏的顶部边缘是用胶水和卡扣固定的。
    • 轻轻向下拉显示器的右边缘(朝充电口的方向)。
    • 将三角撬片插入手机的右上角。
  14. iPhone 11 Pro 屏幕更换: 步骤 14 中的图像 1,2 iPhone 11 Pro 屏幕更换: 步骤 14 中的图像 2,2
    • 根据需要继续向下拉显示器(朝向充电口),以便留出足够大的间隙以插入撬片。
    • 将撬片滑动到左上角并切开剩余的固定显示屏的粘合剂。
    • 请勿将撬片插入超过 3 毫米,否则可能会损坏前面板传感器阵列。
  15. iPhone 11 Pro 屏幕更换, 取下吸盘: 步骤 15 中的图像 1,1
    • 拉动吸盘上的小凸块,将其从前面板卸下。
  16. iPhone 11 Pro 屏幕更换, 打开手机: 步骤 16 中的图像 1,3 iPhone 11 Pro 屏幕更换, 打开手机: 步骤 16 中的图像 2,3 iPhone 11 Pro 屏幕更换, 打开手机: 步骤 16 中的图像 3,3
    • 像翻书一样将显示屏轻轻的从手机的左侧翻开。
    • 先不要试图将显示屏与手机完全分离,因为显示屏脆弱的排线仍连接在手机的主板上。
    • 用其他物品支撑显示屏以保持其倾斜,以便进行下一步的维修。
    • 在重新组装期间,将显示器放置到位,沿顶部边缘对齐卡扣,然后小心地将顶部边缘按入到位,再将显示器的其余部分按下。 如果它不能轻易卡入到位,请检查显示器周边的卡扣的状况并确保它们没有弯曲。
  17. iPhone 11 Pro 屏幕更换, 拧下电池连接器盖: 步骤 17 中的图像 1,2 iPhone 11 Pro 屏幕更换, 拧下电池连接器盖: 步骤 17 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • 卸下固定电池盖的两颗 1.3 毫米长的 Y000 螺钉。
    • 在整个维修过程中,请不要弄丢任何一个螺丝并确保它们准确地回到原来的位置,以避免损坏你的 iPhone。
    • 在重新组装期间,此时是将 iPhone开机并测试所有功能的最好的机会。以免你在粘好屏幕后才发现哪里有问题。在测试后继续装机之前,请务必将iPhone关机。
    I have the Mako Driver kit. The Y000 in that doesn’t work. it doesn’t seem to work for these screws. Almost feel like the tip needs to be ground down to fit the Y screw.
    Lawrence - 回复
    German translation says "3 screws” but there are only 2.
    Markus Mohr - 回复
    p2 works better here
    Aleksandr - 回复
  18. iPhone 11 Pro 屏幕更换, 移除电池接口盖: 步骤 18 中的图像 1,1
    • 移除接口盖
  19. iPhone 11 Pro 屏幕更换, 断开电池连接: 步骤 19 中的图像 1,2 iPhone 11 Pro 屏幕更换, 断开电池连接: 步骤 19 中的图像 2,2
    • 使用撬棒或干净的指甲将电池接口从主板上的插座中撬起。
    • 尽量不要损坏电池接口和其他电路板接口周围的黑色硅胶密封圈。 这些密封件为接口提供额外的保护,防止水和灰尘侵入。
    • 将连接器稍微弯曲远离主板,以防止它在维修过程中意外接触插座并为手机供电。
  20. iPhone 11 Pro 屏幕更换, 拧下主板盖螺丝: 步骤 20 中的图像 1,2 iPhone 11 Pro 屏幕更换, 拧下主板盖螺丝: 步骤 20 中的图像 2,2
    • 使用 Y000 螺丝刀卸下固定主板盖的六颗 1.3 毫米螺丝。
  21. iPhone 11 Pro 屏幕更换, 卸下主板盖: 步骤 21 中的图像 1,1
    • 卸下主板盖
  22. iPhone 11 Pro 屏幕更换, 断开 OLED 显示屏排线: 步骤 22 中的图像 1,2 iPhone 11 Pro 屏幕更换, 断开 OLED 显示屏排线: 步骤 22 中的图像 2,2
    • 使用撬棒或指甲断开 OLED 面板排线接口。
    • 要重新连接像这样的按压式接口 ,请小心对齐并向下按压一侧,直到其卡入到位,然后在另一侧重复。 不要压在中间。 如果接口未对准,针脚可能会弯曲,造成永久性损坏。
    My screen never activates upon reassembly, despite the phone vibrating to various inputs etc. I guess I damaged the cable? By pins, do you mean the pins of the cable damage, or the pins on the logic board damage? Need to know what to do.
  23. iPhone 11 Pro 屏幕更换, 断开前传感器 + 数字化仪: 步骤 23 中的图像 1,3 iPhone 11 Pro 屏幕更换, 断开前传感器 + 数字化仪: 步骤 23 中的图像 2,3 iPhone 11 Pro 屏幕更换, 断开前传感器 + 数字化仪: 步骤 23 中的图像 3,3
    • 使用撬棒或指甲断开前传感器组件排线接口。
    • 使用撬棒或指甲断开数字化仪排线接口。
    • 如果维修后屏幕对触摸没有反应,请断开电池连接,然后重新安装此接口,确保其完全卡入到位并且插座中没有灰尘或其他异物。
  24. iPhone 11 Pro 屏幕更换, 移除屏幕: 步骤 24 中的图像 1,1
    • 移除屏幕
    • 在重新组装过程中,如果你想更换屏幕胶水,请在此处暂停。
    Between steps 20 & 21, use a Y000 driver to remove two 1.3 mm screws securing the sensor cable cover bracket, then carefully remove the long and narrow bracket.
    randy - 回复
  25. iPhone 11 Pro 屏幕更换, 拧下前面组件螺丝: 步骤 25 中的图像 1,2 iPhone 11 Pro 屏幕更换, 拧下前面组件螺丝: 步骤 25 中的图像 2,2
    • 使用Y000 螺丝刀移除将扬声器/传感器组件固定到显示器背面的三颗螺丝:
    • 两颗1.3 mm 螺丝
    • 一颗1.9 mm 螺丝
    Note that the top left screw has a smaller head than the other 3! You’ll learn like I did if they get mixed up & its really hard to get the other 1.3 mm screw to fit.
    Andrew Campbell - 回复
    Thank you Andrew. That saved me!
    Matt Hunt -
    I have to admit that I stared for a long time at the phone trying to make it look like this picture. It's the back of the old screen (front assembly= screen)...you're removing the parts to move to the new screen
    Fixtropy - 回复
  26. iPhone 11 Pro 屏幕更换, 翻转扬声器组件: 步骤 26 中的图像 1,3 iPhone 11 Pro 屏幕更换, 翻转扬声器组件: 步骤 26 中的图像 2,3 iPhone 11 Pro 屏幕更换, 翻转扬声器组件: 步骤 26 中的图像 3,3
    • 耳机扬声器已轻轻固定到位。
    • 用撬棒的尖端轻轻撬起扬声器的顶部边缘。
    • 上下翻转扬声器组合件,并使其远离显示屏的顶部边缘。
    • 扬声器通过非常细的带状电缆保持连接。注意不要拉紧或损坏电缆。
  27. iPhone 11 Pro 屏幕更换, 加热手机上边缘传感器条: 步骤 27 中的图像 1,1
    • 使用吹风机或热风枪或准备 iOpener 并将其放置在显示器的顶部正面约 1-2 分钟,以软化固定传感器的粘合剂。
  28. iPhone 11 Pro 屏幕更换, 撬起麦克风: 步骤 28 中的图像 1,3 iPhone 11 Pro 屏幕更换, 撬起麦克风: 步骤 28 中的图像 2,3 iPhone 11 Pro 屏幕更换, 撬起麦克风: 步骤 28 中的图像 3,3
    • 使用撬棒的尖端提起麦克风并将其与前面板的缺口分开。
  29. iPhone 11 Pro 屏幕更换, 移除环境光感应器: 步骤 29 中的图像 1,2 iPhone 11 Pro 屏幕更换, 移除环境光感应器: 步骤 29 中的图像 2,2
    • 使用镊子摆动环境光传感器,并将其从显示屏上的槽口中提起。
    • 如果传感器在几秒钟后仍未自由摆动,请施加更多热量,然后重试。
    • 传感器通过一根非常细的柔性电缆保持与传感器组件其余部分的连接。注意不要拉紧或损坏电缆。
  30. iPhone 11 Pro 屏幕更换: 步骤 30 中的图像 1,3 iPhone 11 Pro 屏幕更换: 步骤 30 中的图像 2,3 iPhone 11 Pro 屏幕更换: 步骤 30 中的图像 3,3
    • 如果你成功移除了整个环境光传感器,如第一张照片所示,请继续执行下面的下一步。
    • 如果白色扩散板条脱落并仍然嵌入显示屏中,如第二张照片所示,你将需要使用薄刀片或撬动工具小心地将其沿着顶部边缘撬开。
    • 首先重新施加热量可能会使此任务容易一些。在重新组装过程中,请先将扩散器安装到显示器上,并确保其朝向正确的方向(第一幅图像显示为正面,而第三幅图像显示为背面)。
    • 然后,将环境光传感器放在漫射器顶部。在安装固定听筒/传感器组件的螺钉时,你需要将传感器固定在适当的位置。拧紧螺丝后,传感器将保持在原位并正常工作。
  31. iPhone 11 Pro 屏幕更换: 步骤 31 中的图像 1,3 iPhone 11 Pro 屏幕更换: 步骤 31 中的图像 2,3 iPhone 11 Pro 屏幕更换: 步骤 31 中的图像 3,3
    • 从左到右操作,将三角撬片滑动到柔性电缆下方和接近传感器+泛光照明器模块下方。
    • 轻轻扭动并提起以将模块从其前面板的槽口中分离出来。
    • 将扬声器抬起并保持不妨碍进入是很有帮助的。请注意不要在工作时拉细的柔性电缆。
  32. iPhone 11 Pro 屏幕更换, 移除扬声器+前传感器: 步骤 32 中的图像 1,3 iPhone 11 Pro 屏幕更换, 移除扬声器+前传感器: 步骤 32 中的图像 2,3 iPhone 11 Pro 屏幕更换, 移除扬声器+前传感器: 步骤 32 中的图像 3,3
    • 移除耳机扬声器和前传感器组件。
    • 重新组装期间,检查包含以下组件的黑色塑料模块的位置:
    • 接近传感器
    • 泛光灯
    • 模块的位置必须确保这些组件不会被任何粘合剂阻塞。
结论
将新的替换零件与原始零件进行比较——在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
要重新组装你的设备,请按相反顺序执行上述步骤。
请将你的电子废料带到 R2 or e-Stewards 认证的回收商
修理过程如遇问题,可以查看我们的社区iPhone 11 Pro Max 论坛以获取更多排除故障的帮助信息。
97等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Jeff Suovanen
于08/06/13注册
439,253 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,410篇指南
9条评论
Scusate ma perche dovrei spendere 1-2 ore di tempo piu il costo del display a “soli” euro 500,00 (ma ti fanno il resto di € 0,05!, ndr) quando la APPLE “UFFICIALE” te lo ripara con 300euro pezzi , attrezzi e tempo di lavoro : TUTTO INCLUSO !!!!!
Comunque guida ben fatta!!!
unknow unknow - 回复
UMM, Maybe you can tell customers that they will forever have a notification pop up saying “Unknown Part, not an original part installed” so that they can make an informed decision if they want to install or not.
Harry van Heerden - 回复
Fixed it. Thank you.
jmcgaughey - 回复
Works perfect!
For me the "Unknown Part Message" it's just a apple's psychological trick.
I was concern about the Face Recognition, but works fine.
Rio Hana - 回复
Did i need to copy the screen data before installing?
I use the i fix it iPhone 11 Pro LCD Display
Heinrich - 回复
Display Daten für True Tone müssen mit einem Programmer aufs neue Display übertragen werden. Das sollte allgemein bekannt sein. Und dann entferne ich die Ohrhörer/Lautsprecher/Sensor Einheit komplett mit der Kunststoffhalterung vorsichtig vom Display und baue die so auf dem neuen Display wieder ein. Mir ist noch nie was kaputt gegangen. Die Fummelei mit dem Raushebeln tue ich mir nicht an. Viel zu riskant.
Tina - 回复
On the back of the iFixit iPhone 11 Pro replacement screen, there's a little sticker with a QR code attached to... whatever that connector piece is in the middle. I forgot to remove that before buttoning everything up, but everything seems to work fine. Does anyone know if that could be issue? Only thing I could see is if it's supposed to contact metal-to-metal for heat dissipation.
Charles Whittington - 回复
completed this repair and a month later the screen is black, but working. The glass is damaged so it’s possible that has something to do with it but I’ve also heard it’s an ios16 issue with charging. same thing happened when I replaced an iPhone 13 screen. Any ideas on what’s going on?
Carlos Figueroa - 回复
Thanks for this - it was helpful. My screen was shattered so even do the tape trick the suction cup only pulled up the cracked glass and no the bezel edge. If you have the same issue as me, its still doable, but an extra step as the screen comes off in one piece and its much harder to work the pick around the edge as you are seperating the glass from the bezel, and then have to remove the bezel seperately after. I had to pry it up carefully with a spudger to get a gap between the bezel and lower case to slide my pick in and seperate the bezel from the adhesive. Hopefully this helps someone who was in the same situation as me.
Owen Scott - 回复
添加评论
浏览统计数据:
过去 24 小时: 82
过去 7 天: 589
过去 30 天: 2,274
总计 196,438
