跳转到主内容
iPad Pro 12.9" 2nd Gen Screen Replacement
你所需要的
    • Before starting repairs, take your iPad off the charger and power it down.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear eye protection. The glass may break, sending pieces flying.
  1. iPad Pro 12.9" 2nd Gen Screen Replacement, Adhesive tip: 步骤 2 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Adhesive tip: 步骤 2 中的图像 2,2
    • Removing the screen involves using an opening pick and/or halberd spudger to separate the adhesive securing the screen to the frame.
    • As you slice through the adhesive, note the following:
    • The adhesive on the long edges of the iPad is about 4 mm wide. Avoid slicing deeper than that, or you risk damaging the display panel.
    • The adhesive on the short edges of the iPad is about 2 mm wide. Avoid slicing deeper than that.
    • Take especially care when slicing near the home button and charging port to avoid damaging the flex cables.
    • Take extra care when you slice near the front facing camera, to avoid damaging or smearing it.
  2. iPad Pro 12.9" 2nd Gen Screen Replacement, Heat the left edge: 步骤 3 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Heat the left edge: 步骤 3 中的图像 2,2
    • Apply a heated iOpener to the left edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 5 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    • The display adhesive of the iPad is strong and the glass breaks easily. You need to reheat and reapply the iOpener in each section several times during the display removal.
  3. iPad Pro 12.9" 2nd Gen Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 3,3
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad Pro 12.9" 2nd Gen Screen Replacement: 步骤 5 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement: 步骤 5 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement: 步骤 5 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad Pro 12.9" 2nd Gen Screen Replacement: 步骤 6 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement: 步骤 6 中的图像 2,2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. iPad Pro 12.9" 2nd Gen Screen Replacement, Apply a suction handle: 步骤 7 中的图像 1,1
    • Once the screen is warm to touch, apply a suction handle to the left edge of the iPad's screen, above the Smart Connector port and as close to the edge as possible.
  7. iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 8 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 8 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 8 中的图像 3,3
    • While holding down the corners of the iPad, repeatedly pull up on the screen, then ease it back down to weaken the adhesive. This will eventually create a small gap in the seam.
    • If the edge cools down during the pulling process, reheat the edge with an iOpener before proceeding.
    • Once you've created a small gap, insert the tip of an opening pick into the gap.
    • Don't insert your opening pick deeper than 3–4 mm, or you risk permanently damaging the display panel.
  8. iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 9 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 9 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 9 中的图像 3,3
    • Reapply the iOpener to the bottom left corner of the iPad for at least 2 minutes, spanning from the opening pick to the home button.
    • After letting the adhesive soften, insert an opening pick or halberd spudger into the gap next to the opening pick.
    • Don't insert your slicing tool deeper than 3–4 mm, or you risk permanently damaging the display panel.
    • Use an opening pick or halberd spudger to slice the adhesive along the bottom left side of the iPad. If the slicing becomes difficult, reheat the edge and try again.
  9. iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 10 中的图像 1,1
    • Insert an opening pick underneath the bottom left corner of the screen to prevent the adhesive from resealing.
  10. iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 11 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 11 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 11 中的图像 3,3
    • Reapply the iOpener to the upper left corner of the iPad for at least 2 minutes, spanning from the opening pick to the front facing camera.
    • Use an opening pick or halberd spudger and slide along the upper left edge of the iPad to slice the adhesive.
    • If the slicing becomes difficult, reheat the edge and try again.
  11. iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 12 中的图像 1,1
    • Insert an opening pick underneath the top left corner of the screen to prevent the adhesive from resealing.
  12. iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 13 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 13 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 13 中的图像 3,3
    • Reheat your iOpener and apply it the top edge of the device for at least 2 minutes.
    • Use an opening pick or halberd spudger and slide along the top edge of the iPad to slice the adhesive. Stop before you reach the front-facing camera.
    • Don't insert your slicing tool deeper than 2 mm, or you risk permanently damaging the display panel.
  13. iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 14 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 14 中的图像 2,2
    • Insert an opening pick underneath the screen just before the front-facing camera to prevent the adhesive from resealing.
  14. iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 15 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 15 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 15 中的图像 3,3
    • Reheat your iOpener and apply it to the top edge of the device for at least 2 minutes.
    • Insert an opening pick or a halberd spudger just past the front-facing camera.
    • Use your cutting tool to slice the remaining adhesive underneath the top edge of your device.
    • If the slicing becomes hard, reheat the edge and try again.
  15. iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 16 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 16 中的图像 2,2
    • Insert an opening pick underneath the upper right corner of the screen to prevent the adhesive from resealing.
  16. iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 17 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 17 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 17 中的图像 3,3
    • Apply a heated iOpener to the right edge of the screen for 5 minutes to loosen the adhesive underneath.
    • Use an opening pick or halberd spudger and slide along the right edge of the iPad to slice the adhesive.
    • Insert an opening pick underneath the center of the right edge to prevent the adhesive from resealing.
  17. iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 18 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 18 中的图像 2,2
    • Insert an opening pick underneath the bottom right corner of the iPad to prevent the adhesive from resealing.
  18. iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 19 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 19 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 19 中的图像 3,3
    • Reheat your iOpener and apply it to the bottom edge of the device for at least 2 minutes.
    • Insert an opening pick or a halberd spudger underneath the bottom right corner of the iPad.
    • Slide the opening pick along the bottom edge of the iPad, stopping short about 12 mm before reaching the home button.
  19. iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 20 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Insert an opening pick: 步骤 20 中的图像 2,2
    • Insert an opening pick underneath the screen just before the home button to prevent the adhesive from resealing.
    • Use the tip of an opening pick or an halberd spudger to slice the adhesive beneath the home button.
    • Don't insert your slicing tool deeper than 2 mm, or you risk permanently damaging the home button.
  20. iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 21 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Slice the adhesive: 步骤 21 中的图像 2,2
    • Insert an opening pick or a halberd spudger just past the home button.
    • Use your cutting tool to slice the remaining adhesive underneath the bottom edge of your device.
  21. iPad Pro 12.9" 2nd Gen Screen Replacement, Loosen and slice any remaining adhesive: 步骤 22 中的图像 1,1
    • At this point, you've sliced through most of the screen adhesive. Use an opening pick to carefully slice any remaining adhesive along the edges until the screen is freed.
    • If some parts are stubborn, heat the area with an iOpener to loosen the adhesive.
  22. iPad Pro 12.9" 2nd Gen Screen Replacement, Lift the display: 步骤 23 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Lift the display: 步骤 23 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Lift the display: 步骤 23 中的图像 3,3
    • The iPad shown in the following two steps is the iPad Pro 12.9" 1st Generation. The internals look slightly different but the taping procedure is the same.
    • The display cables in this iPad are very short. Read the next two steps before you proceed.
    • Do not pivot the screen about the lower edge. The display cables don't have enough slack to allow for this and will tear if you do not slide the screen towards the front-facing camera as you lift.
    • The display cables will tear if you raise the screen more than 90º.
    • Lift up the upper edge of the screen and slide the entire screen towards the front-facing camera to access the iPad's internal components.
    • Use masking tape to tape the lower edge of the screen to the frame to prevent the screen from slipping.
  23. iPad Pro 12.9" 2nd Gen Screen Replacement, Prop up the screen: 步骤 24 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Prop up the screen: 步骤 24 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Prop up the screen: 步骤 24 中的图像 3,3
    • This step shows one way to support the screen using masking tape. You can also turn the iPad sideways. Make sure not to strain the display cables with whatever method you choose.
    • Attach a long strip of masking tape to the top edge of the screen. Fold the tape over the edge and make sure that the tape is attached securely.
    • Attach the other end of the strip to the bottom edge of the iPad frame to hold the screen at an angle. Make sure the tape attaches securely to the frame.
  24. iPad Pro 12.9" 2nd Gen Screen Replacement, Unfasten the logic board EMI shield screws: 步骤 25 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Unfasten the logic board EMI shield screws: 步骤 25 中的图像 2,2
    • It's important to disconnect the battery before you proceed further. Detaching or connecting the display cables with the battery plugged in can cause a short that will destroy touchscreen functionality.
    • Use a Phillips screwdriver to remove the six screws securing the logic board EMI shield:
    • Two 2.4 mm-long screws
    • Four 1.2 mm-long screws
  25. iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the logic board EMI shield: 步骤 26 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the logic board EMI shield: 步骤 26 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the logic board EMI shield: 步骤 26 中的图像 3,3
    • Lift the logic board EMI shield from the edge nearest the top of the iPad.
    • Peel up the EMI shield from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when you reinstall it and screw it down.
    • Remove the logic board EMI shield.
  26. iPad Pro 12.9" 2nd Gen Screen Replacement, Unfasten the battery connector screw: 步骤 27 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Unfasten the battery connector screw: 步骤 27 中的图像 2,2
    • Use a Phillips screwdriver to remove the 1.6 mm-long screw securing the battery connector.
  27. iPad Pro 12.9" 2nd Gen Screen Replacement, Battery connector information: 步骤 28 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Battery connector information: 步骤 28 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Battery connector information: 步骤 28 中的图像 3,3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has springs on the logic board that press down against the battery contact pads. You'll need to slide something thin and flexible between the contact points to disconnect the battery.
  28. iPad Pro 12.9" 2nd Gen Screen Replacement, Create a battery blocker: 步骤 29 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Create a battery blocker: 步骤 29 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Create a battery blocker: 步骤 29 中的图像 3,3
    • Use a piar of scissors to cut two 6 mm x 20 mm strips of a playing card to use as a battery blocker.
  29. iPad Pro 12.9" 2nd Gen Screen Replacement, Insert the card strips: 步骤 30 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Insert the card strips: 步骤 30 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Insert the card strips: 步骤 30 中的图像 3,3
    • Gently insert the card strips on each side of the battery connector as far as they will go.
    • You can also use an iFixit battery blocker. Be very careful and don't push the battery blocker underneath the connector with excessive force.
  30. iPad Pro 12.9" 2nd Gen Screen Replacement, Unfasten the display connector bracket screws: 步骤 31 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Unfasten the display connector bracket screws: 步骤 31 中的图像 2,2
    • Use a Phillips screwdriver to remove the four screws securing the display connector bracket:
    • Two 1.2 mm-long screws
  31. iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the display connector bracket: 步骤 32 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the display connector bracket: 步骤 32 中的图像 2,2
    • Remove the display connector bracket.
  32. iPad Pro 12.9" 2nd Gen Screen Replacement, Disconnect the display cables: 步骤 33 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Disconnect the display cables: 步骤 33 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Disconnect the display cables: 步骤 33 中的图像 3,3
    • Use the pointed end of a spudger to pry up and disconnect the display and digitizer cables from their logic board sockets.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • These cables are very delicate, and the connectors can damage easily if they're misaligned. When you reattach the cables to the logic board, try to have as much slack on the cables and gently press the connectors onto their sockets.
  33. iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the screen assembly: 步骤 34 中的图像 1,1
    • Remove the screen assembly.
  34. iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the tape: 步骤 35 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the tape: 步骤 35 中的图像 2,2
    • Use tweezers to peel off the tape covering the ZIF connector above the home button.
  35. iPad Pro 12.9" 2nd Gen Screen Replacement, Release the ZIF connector: 步骤 36 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Release the ZIF connector: 步骤 36 中的图像 2,2
    • Use the point of a spudger to open the ZIF connector that secures the cable by bringing its flap in an upright position.
  36. iPad Pro 12.9" 2nd Gen Screen Replacement, Disconnect the home button: 步骤 37 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Disconnect the home button: 步骤 37 中的图像 2,2
    • Use tweezers to slide the cable out of the ZIF connector.
  37. iPad Pro 12.9" 2nd Gen Screen Replacement, Loosen the home button cable adhesive: 步骤 38 中的图像 1,1
    • The home button's ribbon cable is very fragile. If it gets damaged, Touch ID will no longer function.
    • Apply a heated iOpener to the home button for 2 minutes to loosen the adhesive underneath its cable.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the screen.
  38. iPad Pro 12.9" 2nd Gen Screen Replacement, Free the home button cable: 步骤 39 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Free the home button cable: 步骤 39 中的图像 2,2
    • Carefully slide an opening pick underneath the home button cable to separate it from the screen.
  39. iPad Pro 12.9" 2nd Gen Screen Replacement, Loosen the home button bracket adhesive.: 步骤 40 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Loosen the home button bracket adhesive.: 步骤 40 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Loosen the home button bracket adhesive.: 步骤 40 中的图像 3,3
    • The home button bracket is held in place with strong adhesive.
    • Apply a few drops of high concentration (90% or higher) isopropyl alcohol to the base of the home button bracket to loosen its adhesive.
    • A heated iOpener, a hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the screen.
  40. iPad Pro 12.9" 2nd Gen Screen Replacement, Pry up the home button bracket: 步骤 41 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Pry up the home button bracket: 步骤 41 中的图像 2,2
    • Insert the edge of an opening tool under the home button bracket lip.
    • Carefully pry up with steady force to loosen the bracket.
    • If you want to transfer your home button to a new screen be especially careful not to damage the home button cable during this procedure.
    • The adhesive holding this bracket can be stubborn. Apply more isopropyl alcohol or heat if it doesn't budge.
  41. iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the home button bracket: 步骤 42 中的图像 1,2 iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the home button bracket: 步骤 42 中的图像 2,2
    • Use tweezers to carefully pull the home button bracket from underneath the home button cable.
    • Remove the home button bracket.
  42. iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the home button: 步骤 43 中的图像 1,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the home button: 步骤 43 中的图像 2,3 iPad Pro 12.9" 2nd Gen Screen Replacement, Remove the home button: 步骤 43 中的图像 3,3
    • Gently push the home button from the front of the display inward using the tip of a finger.
    • Remove the home button.
    • The home button attaches to the screen with an adhesive gasket. When you transfer the home button to a new display, use some liquid adhesive to glue the button perimeter to the screen.
  43. iPad Pro 12.9" 2nd Gen Screen Replacement, Only the screen remains: 步骤 44 中的图像 1,1
    • Only the screen remains.
    • During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • If your screen didn't come with pre-applied adhesives, use our screen adhesive application guide to install fresh pre-cut adhesive strips when reassembling your iPad.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Dominik Schnabelrauch
于11/23/16注册
184,492 声望
创作了680篇指南
团队
iFixit iFixit 的会员
Community
136 名成员
创作了15,122篇指南
一条评论
The iPad shown in the first two photos in step 1 is not an iPad Pro. It's an older model iPad.
Jake Whitney - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 166
过去 30 天: 655
总计 5,003
