跳转到主内容
加入维修社区 - 创建账户
iPad Pro 11" 4th Gen Screen Replacement
你所需要的
  1. iPad Pro 11" 4th Gen Screen Replacement, Prepare your iPad: 步骤 1 中的图像 1,1
    • Ensure the battery is entirely drained before attempting this repair. The battery connection in this device is sensitive and you don't want to accidentally provide the board power for a myriad of reasons.
    • All cords/cables should be removed and the iPad should be fully shut down.
    添加评论
  2. iPad Pro 11" 4th Gen Screen Replacement, Important Information: 步骤 2 中的图像 1,3 iPad Pro 11" 4th Gen Screen Replacement, Important Information: 步骤 2 中的图像 2,3 iPad Pro 11" 4th Gen Screen Replacement, Important Information: 步骤 2 中的图像 3,3
    • There are important and sensitive connections that you should make note of before attempting this repair. The colored boxes each represent an important component just below the screen.
    • Exposed LCD Edges
    • Screen Magnets
    • Camera Module, Ambient Light & Proximity Sensors, and Microphone
    • Display Cables
    询问修复机器人
    添加评论
  3. iPad Pro 11" 4th Gen Screen Replacement, Heat the Right Edge: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • You may use a hair dryer or heat gun but extreme caution should be used because you don't want to over heat any one part of the display.
    • There is an additional method for opening using iFixit's new Anti-Clamp.
    询问修复机器人
    添加评论
  4. iPad Pro 11" 4th Gen Screen Replacement, Insert Opening Pick: 步骤 4 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Insert Opening Pick: 步骤 4 中的图像 2,2
    • If the display is badly cracked, consider cover it with a layer of clear packing tape. This may allow a suction cup to adhere. iFixit even advises using superglue if you are totally replacing the display.
    • Apply a suction cup to the right edge of the screen about 5 cm from the bottom edge.
    • Pull up on the suction cup with firm, constant pressure to create a gap large enough to insert an opening pick no more that 5mm into the iPad.
    • If you find it helpful, mark the 5mm line on the opening pick with a sharpie before inserting.
    • Try to remember you only need to create a gap large enough for the opening pick to get in.
    询问修复机器人
    添加评论
  5. iPad Pro 11" 4th Gen Screen Replacement, Separate the right edge adhesive: 步骤 5 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Separate the right edge adhesive: 步骤 5 中的图像 2,2
    • Insert another opening pick right next to the original.
    • Slide the new pick along the right edge to separate the adhesive.
    • When you get close to the volume buttons make sure the pick isn't inserted more than 2mm
    • Leave the pick in the top right corner.
    询问修复机器人
    添加评论
  6. iPad Pro 11" 4th Gen Screen Replacement, Heat the Top Edge: 步骤 6 中的图像 1,1
    • Apply the heated iOpener to the top edge of the iPad for two minutes.
    询问修复机器人
    添加评论
  7. iPad Pro 11" 4th Gen Screen Replacement, Important Information: Top Edge: 步骤 7 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Important Information: Top Edge: 步骤 7 中的图像 2,2
    • The top edge contains the camera module, two ambient light sensors, the proximity sensor, and the front microphone. All of these components are fragile and easily damaged if an opening pick is inserted too far.
    • This color indicates the location of the ambient light sensors. Avoid inserting the opening pick more than 2mm to avoid damaging the sensors.
    • This color indicates the location of the camera module, proximity sensor and microphone. Avoid inserting the opening pick more that 1mm to avoid damage.
    询问修复机器人
    添加评论
  8. iPad Pro 11" 4th Gen Screen Replacement, Separate the Top Adhesive: 步骤 8 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Separate the Top Adhesive: 步骤 8 中的图像 2,2
    • Insert opening pick #3 around the corner from where you left #2.
    • Take pick #3 and slide the pick along the top edge. Taking precaution of the components listed in the previous step.
    • Leave pick #3 on the right side of the ambient light sensor, near the upper left corner.
    询问修复机器人
    添加评论
  9. iPad Pro 11" 4th Gen Screen Replacement, Heat the Bottom Edge: 步骤 9 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the screen for two minutes.
    询问修复机器人
    添加评论
  10. iPad Pro 11" 4th Gen Screen Replacement, Separate the Bottom Edge Adhesive: 步骤 10 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Separate the Bottom Edge Adhesive: 步骤 10 中的图像 2,2
    • Insert pick #4 in the bottom right corner below the original pick.
    • Slide the pick around the bottom right corner taking caution not to insert more than 2mm.
    询问修复机器人
    添加评论
  11. iPad Pro 11" 4th Gen Screen Replacement: 步骤 11 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement: 步骤 11 中的图像 2,2
    • Slide the opening pick along the bottom edge, taking care just above the USB-C port.
    • Once the pick has made it to the opposite corner, leave pick #4 right above the USB-C port.
    • Insert opening pick #5 above opening pick #4 and take #5 the rest of the length of the bottom edge and around the left corner. Leave #5 at just above the corner.
    询问修复机器人
    添加评论
  12. iPad Pro 11" 4th Gen Screen Replacement, Heat the Left Edge: 步骤 12 中的图像 1,1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
    询问修复机器人
    添加评论
  13. iPad Pro 11" 4th Gen Screen Replacement, Important Information: The Left Edge: 步骤 13 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Important Information: The Left Edge: 步骤 13 中的图像 2,2
    • The left edge contains several display cables. These are extremely fragile and easily damaged by an opening pick if it's inserted too far.
    • This color indicates where the display cables are located within small indents of the frame. Best practice is to insert the pick at a 45 degree angle.
    • This color indications where the flat sections of the frame are. These sections require the pick to be horizontal.
    询问修复机器人
    添加评论
  14. iPad Pro 11" 4th Gen Screen Replacement, Separate the Left Edge Adhesive: 步骤 14 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Separate the Left Edge Adhesive: 步骤 14 中的图像 2,2
    • Insert a pick at a 45 degree angle just above the bottom left corner.
    • Carefully slide the pick along the left edge, stopping when you reach the flats section of the frame.
    询问修复机器人
    添加评论
  15. iPad Pro 11" 4th Gen Screen Replacement, Separate the Remaining Adhesive: 步骤 15 中的图像 1,1
    • Separate the remaining adhesive.
    • Slide the pick at a 45 degree downward angle and don't insert the pick more than 5mm.
    • Slide the pick horizontally and don't insert more than 5mm
    询问修复机器人
    添加评论
  16. iPad Pro 11" 4th Gen Screen Replacement, Separate the Screen from the Frame: 步骤 16 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Separate the Screen from the Frame: 步骤 16 中的图像 2,2
    • Use yet another opening pick to see if there is any remaining adhesive.
    • Grave the top right and bottom left corners of the screen and slowly move the screen towards the bottom right side.
    • The screen is still attached to the iPad by several ribbon cables. While you move the display you can lift it straight up slightly to see their position.
    • Keep moving the screen until you see the ambient light sensor ribbon cable near the top edge is uncovered.
    询问修复机器人
    添加评论
  17. iPad Pro 11" 4th Gen Screen Replacement: 步骤 17 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement: 步骤 17 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor bracket to the logic board.
    • One 1.3 mm screw
    • One 2.0 mm screw
    • Use a pair of tweezers or your fingers to remove the bracket.
    • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
    询问修复机器人
    添加评论
  18. iPad Pro 11" 4th Gen Screen Replacement, Disconnect the Ambient Light Sensor Cable: 步骤 18 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Disconnect the Ambient Light Sensor Cable: 步骤 18 中的图像 2,2
    • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connectors.
    询问修复机器人
    添加评论
  19. iPad Pro 11" 4th Gen Screen Replacement, Reposition the Screen: 步骤 19 中的图像 1,3 iPad Pro 11" 4th Gen Screen Replacement, Reposition the Screen: 步骤 19 中的图像 2,3 iPad Pro 11" 4th Gen Screen Replacement, Reposition the Screen: 步骤 19 中的图像 3,3
    • The screen is still attached by one more ribbon cable - do not try to remove it yet.
    • Holding the right edge of the screen, open the iPad like a book.
    • In order to not strain the ribbon cable let the screen rest over the left side of the iPad.
    询问修复机器人
    添加评论
  20. iPad Pro 11" 4th Gen Screen Replacement, Remove the Logic Board Cable Shield: 步骤 20 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Remove the Logic Board Cable Shield: 步骤 20 中的图像 2,2
    • Using a Phillips head screwdriver, remove the five screws securing the cable shield to the logic board:
    • Two 2.0 mm screws
    • Three 1.3 mm screws
    • Use tweezers or your fingers to grab and remove the lower cable shield.
    询问修复机器人
    添加评论
  21. iPad Pro 11" 4th Gen Screen Replacement, Unscrew Battery Connector: 步骤 21 中的图像 1,1
    • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
    询问修复机器人
    添加评论
  22. iPad Pro 11" 4th Gen Screen Replacement, Important Information: Battery Reference: 步骤 22 中的图像 1,3 iPad Pro 11" 4th Gen Screen Replacement, Important Information: Battery Reference: 步骤 22 中的图像 2,3 iPad Pro 11" 4th Gen Screen Replacement, Important Information: Battery Reference: 步骤 22 中的图像 3,3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    询问修复机器人
    添加评论
  23. iPad Pro 11" 4th Gen Screen Replacement, Create a battery blocker: 步骤 23 中的图像 1,3 iPad Pro 11" 4th Gen Screen Replacement, Create a battery blocker: 步骤 23 中的图像 2,3 iPad Pro 11" 4th Gen Screen Replacement, Create a battery blocker: 步骤 23 中的图像 3,3
    • You need to place a barrier between the battery connector and logic board to disconnect the battery. Follow this step to create a battery blocker out of a playing card.
    • Cut two 6 mm-wide strips from a playing card to block the connections to the battery.
    询问修复机器人
    添加评论
  24. iPad Pro 11" 4th Gen Screen Replacement, Insert the card strips: 步骤 24 中的图像 1,3 iPad Pro 11" 4th Gen Screen Replacement, Insert the card strips: 步骤 24 中的图像 2,3 iPad Pro 11" 4th Gen Screen Replacement, Insert the card strips: 步骤 24 中的图像 3,3
    • Insert the card strips under each side of the battery connector.
    • If you can't slide the cards under the battery connector, use an opening pick to gently lift the connector to help insert the card strips.
    • Don't pry or lift the connector too much—it's soldered onto the logic board and may break if stressed.
    询问修复机器人
    添加评论
  25. iPad Pro 11" 4th Gen Screen Replacement, Disconnect Display Cables: 步骤 25 中的图像 1,3 iPad Pro 11" 4th Gen Screen Replacement, Disconnect Display Cables: 步骤 25 中的图像 2,3 iPad Pro 11" 4th Gen Screen Replacement, Disconnect Display Cables: 步骤 25 中的图像 3,3
    • Using the pointed end of a spudger, disconnect the bottom two display cables.
    • Using the pointed end of a spudger disconnect the top two display cables.
    询问修复机器人
    添加评论
  26. iPad Pro 11" 4th Gen Screen Replacement, Remove the Screen: 步骤 26 中的图像 1,1
    • The screen is now entirely disconnected. You may lift it away from the housing.
    • Use isopropyl alcohol (>90%) and a lint free cloth or q-tip to remove any remaining adhesive on the housing before replacing the display. Remember, without replacing the adhesive strips, your iPad is at serious risk of water damage.
    • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
    询问修复机器人
    添加评论
  27. iPad Pro 11" 4th Gen Screen Replacement, LiDAR Removal: 步骤 27 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, LiDAR Removal: 步骤 27 中的图像 2,2
    • The LiDAR sensor assembly is paired to the Face ID hardware. You'll need to transfer it to your replacement screen to keep Face ID functionality. The following steps show how to remove the sensor assembly and install it on your replacement screen.
    • Ambient Light Sensors (2)
    • Microphone
    • Proximity Sensor
    • The ribbon cable that connects these sensors is very thin and delicate, take your time and be careful with removal.
    • Prepare an iOpener. Leave it in place at the top of the display for two minutes.
    询问修复机器人
    添加评论
  28. iPad Pro 11" 4th Gen Screen Replacement, Ambient Light Sensors: 步骤 28 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Ambient Light Sensors: 步骤 28 中的图像 2,2
    • Using a pair of tweezers, insert one arm between the ambient light sensor and the screen.
    • Gently pry the sensor up from the screen. This may take considerable force.
    • Repeat these steps with the other ambient light sensor.
    询问修复机器人
    添加评论
  29. iPad Pro 11" 4th Gen Screen Replacement, Proximity Sensor: 步骤 29 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Proximity Sensor: 步骤 29 中的图像 2,2
    • Reheat & reapply your iOpener
    • Using the same method that we used with the ambient light sensor, use one arm of the tweezers to slip under the ribbon cable and gently pry up.
    询问修复机器人
    添加评论
  30. iPad Pro 11" 4th Gen Screen Replacement, Microphone: 步骤 30 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Microphone: 步骤 30 中的图像 2,2
    • There may be tape covering the microphone.
    • Slide the opening tool under the microphone to separate the adhesive.
    • Pry up to separate the microphone from the screen.
    询问修复机器人
    添加评论
  31. iPad Pro 11" 4th Gen Screen Replacement, LiDar Cable Removal Procedure: 步骤 31 中的图像 1,1
    • Slide an opening pick under the LiDAR sensor assembly cable to separate it from the screen.
    • Exercise caution while separating this cable to avoid tearing it.
    询问修复机器人
    添加评论
  32. iPad Pro 11" 4th Gen Screen Replacement, Remove the LiDAR Cable: 步骤 32 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Remove the LiDAR Cable: 步骤 32 中的图像 2,2
    • Continue to use the opening pick to separate the LiDAR cable from the screen.
    询问修复机器人
    添加评论
  33. iPad Pro 11" 4th Gen Screen Replacement, Lower Display Cable Transfer: 步骤 33 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Lower Display Cable Transfer: 步骤 33 中的图像 2,2
    • Some display replacements come without display cables attached. If this is the case, you will need to remove the display cables from your original display.
    • The bracket in the bottom right corner of the display is covering the display cable connectors.
    询问修复机器人
    添加评论
  34. iPad Pro 11" 4th Gen Screen Replacement, Separate Display Cable: 步骤 34 中的图像 1,2 iPad Pro 11" 4th Gen Screen Replacement, Separate Display Cable: 步骤 34 中的图像 2,2
    • Use an opening pick to remove the small section of the upper display cable that is attached to the bracket.
    询问修复机器人
    添加评论
  35. iPad Pro 11" 4th Gen Screen Replacement, Remove the Bracket: 步骤 35 中的图像 1,3 iPad Pro 11" 4th Gen Screen Replacement, Remove the Bracket: 步骤 35 中的图像 2,3 iPad Pro 11" 4th Gen Screen Replacement, Remove the Bracket: 步骤 35 中的图像 3,3
    • Use a Phillips screwdriver to remove the two 1.2mm screws securing the display cable bracket.
    • Using a pair of tweezers remove the lower display cable bracket.
    询问修复机器人
    添加评论
  36. iPad Pro 11" 4th Gen Screen Replacement, Disconnect & Remove Display Cables: 步骤 36 中的图像 1,3 iPad Pro 11" 4th Gen Screen Replacement, Disconnect & Remove Display Cables: 步骤 36 中的图像 2,3 iPad Pro 11" 4th Gen Screen Replacement, Disconnect & Remove Display Cables: 步骤 36 中的图像 3,3
    • Using flat end of a spudger, pry up and disconnect the narrow display cable.
    • Set the cable aside to connect to your new display.
    • Repeat this process with the wider display cable.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
21等其他人完成本指南。
Luke
于07/23/19注册
1,575 声望
撰写一个指南
10指南评论
One quick note - you can replace the screen on the 4th gen with one from a 3rd gen, but there's a slight difference in the ledge in the top right corner that stops it from sitting flush. It needs to be dremeled out about 1/8" for the screen to fit properly.
Scott van Gulik - 回复 分享
Excellent call out! Please add it to the guide as a note or call out at the beginning. I think that process would be worth its own guide if you ask me. Would definitely link it to this one if you do.
Luke - 回复 分享
My iPad had been off for weeks if not months before doing this repair. I jumped right in, followed the guide precisely, and everything went well with no hiccups. iPad won't turn on now. Does anyone have any ideas why that might be. What could I have damaged in this process? What can I do to diagnose the issue? It has been plugged in for over 24 hours and still won't power on. I don't get the battery icon showing that it needs to be plugged in. I don't get a sound when I plug it in. Nothing. Any guidance would be appreciated. Thanks.
Ben Caler - 回复 分享
Did you try a force restart? Double check connectors are clicked in the socket, sometimes they seem like they are but can be off a bit. Check for burned components on the board by the connectors.
iPod Fix It - 回复 分享
1. Force Restart - Press and release the upper volume button, then the lower volume button, then press and hold the top button for about a minute to see if the device will restart. If that doesn't work, plug the device in and attempt to do the same thing again.
2. Connect the iPad to a computer. On a Mac, if the device is receiving power, it will appear in the Finder. If you're using a Windows computer, open iTunes, and it should be visible there. If it doesn't appear on the computer, it's likely that there's an issue with the logic board. If a functioning iPad has a defective/blank display will still show up when plugged into a computer.
3. If it doesn't show up, it's likely that the logic board was short circuited or the backlighting filter was fried. The battery must remain disconnected for the entire repair and be reconnected last (i.e. after all other cables have been reconnected). Can you confirm that you started by disconnecting the battery and only reconnected once everything else was done?
Luke - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 57
过去 7 天: 337
过去 30 天: 1,492
总计 37,035
