跳转到主内容
加入维修社区 - 创建账户
iPad Mini 6 Speaker Assembly Replacement
你所需要的
  1. iPad Mini 6 Speaker Assembly Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Apply tape to a cracked screen: 步骤 1 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad Mini 6 Speaker Assembly Replacement, Heat the bottom edge: 步骤 2 中的图像 1,1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. iPad Mini 6 Speaker Assembly Replacement, Screen removal information: 步骤 3 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Screen removal information: 步骤 3 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Screen removal information: 步骤 3 中的图像 3,3
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. iPad Mini 6 Speaker Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. iPad Mini 6 Speaker Assembly Replacement, Separate the bottom adhesive: 步骤 5 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom adhesive: 步骤 5 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom adhesive: 步骤 5 中的图像 3,3
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. iPad Mini 6 Speaker Assembly Replacement, Heat the right edge: 步骤 6 中的图像 1,1
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. iPad Mini 6 Speaker Assembly Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom-right corner adhesive: 步骤 7 中的图像 3,3
    • Rotate the opening pick around the bottom-right corner of the device.
  8. iPad Mini 6 Speaker Assembly Replacement, Separate the remaining adhesive: 步骤 8 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Separate the remaining adhesive: 步骤 8 中的图像 2,2
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. iPad Mini 6 Speaker Assembly Replacement, Reposition the screen: 步骤 9 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Reposition the screen: 步骤 9 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Reposition the screen: 步骤 9 中的图像 3,3
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. iPad Mini 6 Speaker Assembly Replacement, Unfasten the display cable bracket: 步骤 10 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Unfasten the display cable bracket: 步骤 10 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. iPad Mini 6 Speaker Assembly Replacement, Remove the display cable bracket: 步骤 11 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Remove the display cable bracket: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. iPad Mini 6 Speaker Assembly Replacement, Disconnect the display: 步骤 12 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Disconnect the display: 步骤 12 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Disconnect the display: 步骤 12 中的图像 3,3
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. iPad Mini 6 Speaker Assembly Replacement, Remove the screen: 步骤 13 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Remove the screen: 步骤 13 中的图像 2,2
    • Remove the screen from the frame.
  14. iPad Mini 6 Speaker Assembly Replacement, Disconnect the battery: 步骤 14 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Disconnect the battery: 步骤 14 中的图像 2,2
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. 注意:步骤 15 源自标记为进行中的 指南
    iPad Mini 6 Speaker Assembly Replacement, Speaker information: 步骤 15 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Speaker information: 步骤 15 中的图像 2,2
  16. 注意:步骤 16-26 源自标记为进行中的 指南
    iPad Mini 6 Speaker Assembly Replacement, Unfasten the front camera shield: 步骤 16 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Unfasten the front camera shield: 步骤 16 中的图像 2,2
    • The next 11 steps will show how to remove the top speaker.
    • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
  17. iPad Mini 6 Speaker Assembly Replacement, Remove the front camera shield: 步骤 17 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Remove the front camera shield: 步骤 17 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers, or your fingers, to remove the front camera shield.
  18. iPad Mini 6 Speaker Assembly Replacement, Disconnect the volume button board: 步骤 18 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Disconnect the volume button board: 步骤 18 中的图像 2,2
    • Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
  19. iPad Mini 6 Speaker Assembly Replacement, Reposition the volume button board's cable: 步骤 19 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Reposition the volume button board's cable: 步骤 19 中的图像 2,2
    • Use tweezers, or your fingers, to peel back the volume button board's cable from the top speaker.
  20. iPad Mini 6 Speaker Assembly Replacement, Disconnect the top speaker: 步骤 20 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Disconnect the top speaker: 步骤 20 中的图像 2,2
    • Use the point of spudger to pry up and disconnect the top speaker's cable.
    • Be very careful when performing this step; apply equal force to both cords to prevent any damage to the connector.
  21. iPad Mini 6 Speaker Assembly Replacement, Reposition the top speaker's cable: 步骤 21 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Reposition the top speaker's cable: 步骤 21 中的图像 2,2
    • The top speaker's cable is lightly adhered to the frame.
    • Gently peel back the cable to separate it from the frame.
  22. iPad Mini 6 Speaker Assembly Replacement, Heat the top speaker: 步骤 22 中的图像 1,1
    • Apply a heated iOpener to the top-left edge of the device for 90 seconds to loosen the top speaker's adhesive.
  23. iPad Mini 6 Speaker Assembly Replacement, Top speaker information: 步骤 23 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Top speaker information: 步骤 23 中的图像 2,2
    • Adhesive is located around the perimeter of the speaker.
    • Insert a pick 2 mm to separate this adhesive.
    • Adhesive is also located in the center of the speaker.
    • Insert a pick 7 mm to separate this adhesive.
  24. iPad Mini 6 Speaker Assembly Replacement, Separate the top speaker's adhesive: 步骤 24 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Separate the top speaker's adhesive: 步骤 24 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Separate the top speaker's adhesive: 步骤 24 中的图像 3,3
    • Insert an opening pick between the top speaker and the frame.
    • Insert the pick at least 7 mm to separate the center adhesive.
  25. iPad Mini 6 Speaker Assembly Replacement: 步骤 25 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement: 步骤 25 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement: 步骤 25 中的图像 3,3
    • Slice along the perimeter of the top speaker to separate the adhesive.
  26. iPad Mini 6 Speaker Assembly Replacement, Remove the top speaker: 步骤 26 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Remove the top speaker: 步骤 26 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Remove the top speaker: 步骤 26 中的图像 3,3
    • At this point, the perimeter of the speaker should be separated from the frame. If there's still resistance around the edges of the speaker, use an opening pick to cut the adhesive again.
    • Pry up with the opening pick to completely separate the top speaker from the frame.
    • Remove the top speaker.
  27. 注意:步骤 27-32 源自标记为进行中的 指南
    iPad Mini 6 Speaker Assembly Replacement, Disconnect the bottom speaker: 步骤 27 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Disconnect the bottom speaker: 步骤 27 中的图像 2,2
    • The next six steps will show how to remove the bottom speaker.
    • Use the point of spudger to pry up and disconnect the bottom speaker's cable.
  28. iPad Mini 6 Speaker Assembly Replacement, Heat the bottom speaker: 步骤 28 中的图像 1,1
    • Apply a heated iOpener to the bottom-left edge of the device to loosen the bottom speaker's adhesive.
  29. iPad Mini 6 Speaker Assembly Replacement, Bottom speaker information: 步骤 29 中的图像 1,2 iPad Mini 6 Speaker Assembly Replacement, Bottom speaker information: 步骤 29 中的图像 2,2
    • Insert a pick 9 mm to separate this adhesive.
  30. iPad Mini 6 Speaker Assembly Replacement, Separate the bottom speaker's adhesive: 步骤 30 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom speaker's adhesive: 步骤 30 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Separate the bottom speaker's adhesive: 步骤 30 中的图像 3,3
    • Insert an opening pick between the bottom speaker and the frame.
    • Insert the pick at least 9 mm to separate the center adhesive.
  31. iPad Mini 6 Speaker Assembly Replacement: 步骤 31 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement: 步骤 31 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement: 步骤 31 中的图像 3,3
    • Slice along the perimeter of the bottom speaker to separate the adhesive.
  32. iPad Mini 6 Speaker Assembly Replacement, Remove the bottom speaker: 步骤 32 中的图像 1,3 iPad Mini 6 Speaker Assembly Replacement, Remove the bottom speaker: 步骤 32 中的图像 2,3 iPad Mini 6 Speaker Assembly Replacement, Remove the bottom speaker: 步骤 32 中的图像 3,3
    • Pry up with the opening pick to completely separate the bottom speaker from the frame.
    • Remove the bottom speaker.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
另外一个人完成了本指南。
Alex Diaz-Kokaisl
于01/16/22注册
237,473 声望
创作了1,171篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了25,685篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 78
总计 2,856
