简介
Use this guide to replace the top speaker in your iPad mini 6.
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
You'll need replacement adhesive in order to complete this repair.
Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the front camera shield to the frame.
Use a spudger to pry up and disconnect the volume button board's press connector secured to the frame.
Use tweezers, or your fingers, to peel back the volume button board's cable from the top speaker.
Use the point of spudger to pry up and disconnect the top speaker's cable.
Gently peel back the cable to separate it from the frame.
Apply a heated iOpener to the top-left edge of the device for 90 seconds to loosen the top speaker's adhesive.
While you're waiting for the adhesive to loosen, note the following:
Adhesive is located around the perimeter of the speaker.
Adhesive is also located in the center of the speaker.
Insert an opening pick between the top speaker and the frame.
Pry up with the opening pick to completely separate the top speaker from the frame.
Remove the top speaker.
