当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
加热iOpener三十秒
在整个维修过程中,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
如果iOpener过热膨胀,千万不要触碰iOpener。
如果iOpener中间部分依然烫的没法碰,请等待冷却后再使用,加热好的iOpener 应该可以保持热度十分钟
如果你没有微波炉,请按照此步骤在沸水中加热iOpener。
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
iOpener会很燙,所以拿取時請小心的從iOpener的邊邊拿
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
如果您的显示屏玻璃已经碎裂,防止显示屏玻璃在您维修时进一步伤害您,请使用胶带来固定已经碎裂的屏幕。
给iPad 的正面整面贴上胶带。
这一步将保证在您翘起和移除显示屏时能够保持完整。
尽量根据下面的指南进行操作。但,一旦玻璃破碎,请停下拆解并使用金属撬刀撬出玻璃,避免更多的碎裂。
戴上安全眼镜来保护你的眼睛。 小心操作不要损坏了LCD内屏。
The next three steps demonstrate the Anti-Clamp , a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
For complete instructions on how to use the Anti-Clamp, check out this guide .
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Place an object under your iPad so it rests level between the suction cups.
Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
Pull the blue handle forward to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
Wait one minute to give the adhesive a chance to release and present an opening gap.
If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
For complete instructions on how to use a hair dryer, check out this guide .
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
Skip the next two steps.
重新加热iOpener 并将其放置在iPad顶部边缘位置且高于前置摄像头。
小心,请勿在维修过程中过度加热iOpener。 在重新加热iOpener之前请至少等待10分钟。
如果您有可以弯折的iOpener,您可以弯折其使其同时加热左上角边缘位置。
将原撬片放置在原位,以防粘合剂重新粘合。
拿一片新的撬片,轻轻的从左天线处滑动到home键前。
只能从iPad外边缘向内滑动 请勿按照相反方向滑动 这样可能会损坏天线。
如果您需要再次滑动来清理粘合剂,请取出撬片然后从外边缘重新插入再向内滑动。
将撬片放置不动。
请小心操作本步骤 。 花点时间来确保粘合剂是热并柔软的,并且您已经使用撬片打开了所有开口。 以及不要害怕停止和重新加热。
在音量控制侧面相反的那一面,你应该确保那一面的每个角都已插入撬片。 旋转撬片然后轻轻提起玻璃面板,沿着显示屏排线边缘清理掉最后的粘合剂。
如果在此步骤遇到很大的阻力难以撬起屏幕请重新加热iOpener 然后将其放置在难以撬起的区域。
在支起玻璃面板的同时,用撬片分离掉最后的粘合剂。
一定要小心操作,不要切割或损坏任何显示排线。
一旦粘合剂全部分离掉,就像打开书一样将玻璃面板放在工作台上。
在重新组装过程中,用异丙醇清洁外壳(以及前玻璃面板,如果你打算重新使用它的话)上的粘合剂残留物,并使用我们的 显示器粘合剂应用指南 和预切粘合剂条 更换粘合剂。
在重新组装过程中,很容易夹住前玻璃和 iPad 框架之间的柔性电缆。 请注意柔性电缆,并确保它们轻轻折叠并塞入框架下方。 如果柔性电缆中的折叠被完全压平,则它可能会损坏而无法修复。
拆下固定LCD屏幕的Phillips螺丝。
3个4.0 mm螺丝
1个4.8 mm螺丝
因为LCD屏幕任然在Home键附近有许多排线与iPad Air主体相连,切勿尝试完全的将LCD屏移开。 仅可从前置摄像头尾端处抬起屏幕。
使用撬棒扁平的一段来从前置摄像头一边撬起一道可以让你手指抓住LCD 屏幕的缝隙。
从前置摄像头处提起iPad Air 的LCD屏幕,就像翻书一样将它翻转到Home键一侧。
小心驶得万年船,切勿操之过急。在您进行翻转的时候请同时盯着LCD排线。
放下LCD屏幕,以便来处理LCD的排线。
请将LCD屏幕放置在柔软、干净、无绒的表面。
卸下将电池连接器固定到主板的 2.3 毫米十字螺丝。
为降低短路风险,你可以 插入电池隔离片 或修改后的撬片来断开电池。
使用电池隔离片隔离电池时要非常小心。 电池触点容易损坏,造成不可逆转的损坏。
将电池阻挡器滑到主板的电池接口区域下方,并在工作时将其留在原位。
如果你在主板下方安装电池隔离片时遇到问题,你可以尝试使用扑克牌断开电池连接。
在这个步骤中使用的工具:
Polyimide Tape
$9.99
购买
移除前面板组件
在组装过程中,擦拭前面板组件上任何的灰尘和指纹,确保显示屏干净。
如果您的新屏幕遇到“幽灵”或“幻影”触摸输入问题,可以通过在面板背面的标注区域粘贴一层非常薄的绝缘胶带,例如Kapton (聚酰亚胺)胶带 ,来解决这个问题。 iFixit面板具有良好的绝缘性,不需要粘贴任何胶带。
若无适当的绝缘措施,数字转换器的这些区域可能会与其他组件接地,导致触摸输入故障。
这些绝缘材料是肉眼不可见的,这与许多iPad上的泡沫防尘条不同。
Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
Only pry up on the connector—not on the socket itself.
Fold the front-facing camera cable out of the way.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
