跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A15 Screen Assembly Replacement
你所需要的
  1. Samsung Galaxy A15 Screen Assembly Replacement, Prepare the phone for disassembly: 步骤 1 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Prepare the phone for disassembly: 步骤 1 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Prepare the phone for disassembly: 步骤 1 中的图像 3,3
    • Let the phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Unplug all cables and completely power off the phone.
    • Press and hold the power and volume down buttons at the same time to bring up the shutdown menu.
    添加评论
  2. Samsung Galaxy A15 Screen Assembly Replacement, Heat the right edge: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back are susceptible to heat damage. The phone should be just too hot to touch comfortably.
    询问修复机器人
    添加评论
  3. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 3 中的图像 1,1
    • While you're waiting for the adhesive to soften, here is some useful information:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • There is an additional layer of adhesive towards the bottom of the phone. Apart from this area, you should not be deeper than 4 mm from the edge.
    询问修复机器人
    添加评论
  4. Samsung Galaxy A15 Screen Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
    询问修复机器人
    添加评论
  5. Samsung Galaxy A15 Screen Assembly Replacement, Slice the adhesive: 步骤 5 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Slice the adhesive: 步骤 5 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Slice the adhesive: 步骤 5 中的图像 3,3
    • Slide the opening pick along the right edge between the back cover and the frame to slice through the adhesive.
    • Leave the opening pick in the bottom right corner to keep the adhesive from resealing.
    询问修复机器人
    添加评论
  6. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 6 中的图像 1,1
    • Reheat your iOpener and apply it to the bottom of the back cover for two minutes.
    询问修复机器人
    添加评论
  7. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 7 中的图像 3,3
    • Insert another opening pick in the bottom right corner and slide it along the bottom edge to slice through the adhesive.
    • Leave this opening pick in the bottom left edge to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  8. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 8 中的图像 1,1
    • Reheat your iOpener and apply it to the left side of the back cover for two minutes.
    询问修复机器人
    添加评论
  9. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 9 中的图像 3,3
    • Insert another opening pick in the bottom left corner and slide it along the left edge to slice through the adhesive.
    • Leave this opening pick in the top left corner to prevent the adhesive from resealing.
    • Only insert the pick up to 4 mm deep to avoid damaging the rear cameras or flash.
    询问修复机器人
    添加评论
  10. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 10 中的图像 1,1
    • Reheat your iOpener and apply it to the top of the back cover for two minutes.
    询问修复机器人
    添加评论
  11. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 11 中的图像 2,2
    • Insert another opening pick in the top left corner at the same depth and slide it along the top edge to slice through the adhesive.
    • Leave this opening pick in the top right corner to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  12. Samsung Galaxy A15 Screen Assembly Replacement, Unfasten the camera clips: 步骤 12 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Unfasten the camera clips: 步骤 12 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Unfasten the camera clips: 步骤 12 中的图像 3,3
    • Insert an opening pick along the top edge of the phone and twist it gently to unfasten the camera clips.
    • Slide the opening pick around the edge of the camera modules to unfasten the remaining camera clips.
    • Only insert the pick up to 4 mm to avoid damaging the rear cameras or flash.
    询问修复机器人
    添加评论
  13. Samsung Galaxy A15 Screen Assembly Replacement, Slice remaining adhesive: 步骤 13 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Slice remaining adhesive: 步骤 13 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Slice remaining adhesive: 步骤 13 中的图像 3,3
    • Once the adhesive around the edges is loose, insert an opening pick deeper into the bottom edge from the bottom left corner.
    • Slide the pick deeper into the phone across the bottom edge, slicing the remaining adhesive.
    询问修复机器人
    添加评论
  14. Samsung Galaxy A15 Screen Assembly Replacement, Remove the back cover: 步骤 14 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Remove the back cover: 步骤 14 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Remove the back cover: 步骤 14 中的图像 3,3
    • Lift and remove the back cover.
    • During reassembly:
    • This is a good point to power on the phone and test all functions before sealing it up. Be sure to power the phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
    询问修复机器人
    添加评论
  15. Samsung Galaxy A15 Screen Assembly Replacement, Remove the SIM tray: 步骤 15 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Remove the SIM tray: 步骤 15 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Remove the SIM tray: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located towards the top of the phone on the left edge.
    • Press in firmly to eject the tray and remove it.
    询问修复机器人
    添加评论
  16. Samsung Galaxy A15 Screen Assembly Replacement, Remove the frame screws: 步骤 16 中的图像 1,1
    • Remove the fifteen 4 mm-long screws connecting the frame to the chassis.
    询问修复机器人
    添加评论
  17. Samsung Galaxy A15 Screen Assembly Replacement, Disconnect the fingerprint button: 步骤 17 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Disconnect the fingerprint button: 步骤 17 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the fingerprint button press connector from the motherboard.
    询问修复机器人
    添加评论
  18. Samsung Galaxy A15 Screen Assembly Replacement, Unfasten the frame clips: 步骤 18 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Unfasten the frame clips: 步骤 18 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Unfasten the frame clips: 步骤 18 中的图像 3,3
    • Flip the phone over so the screen is facing up.
    • Insert an opening pick between the screen and the SIM card tray cutout to form a gap between the frame and the phone.
    • Slide the opening pick down the left edge of the device to unfasten the frame clips.
    询问修复机器人
    添加评论
  19. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 19 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 19 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 19 中的图像 3,3
    • Continue sliding the opening pick around the perimeter of the phone until all of the clips are unfastened.
    • If the opening pick comes out of the phone, re-insert it at the last unfastened corner.
    询问修复机器人
    添加评论
  20. Samsung Galaxy A15 Screen Assembly Replacement, Remove the frame: 步骤 20 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Remove the frame: 步骤 20 中的图像 2,2
    • Pull the frame straight off of the phone.
    询问修复机器人
    添加评论
  21. Samsung Galaxy A15 Screen Assembly Replacement, Disconnect the battery: 步骤 21 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Disconnect the battery: 步骤 21 中的图像 2,2
    • Use the flat end of a spudger to lift up and disconnect the battery press connector from the motherboard.
    询问修复机器人
    添加评论
  22. Samsung Galaxy A15 Screen Assembly Replacement, Disconnect the interconnect cable: 步骤 22 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Disconnect the interconnect cable: 步骤 22 中的图像 2,2
    • The connector labeled "OCTA" is not connected to the board but rather the display cable connector. Make sure you disconnect the connectors from each other.
    • Insert the flat end of a spudger under the overhang of the top "OCTA" cable connector.
    • Pry up the top connector away from the bottom one until they're disconnected.
    询问修复机器人
    添加评论
  23. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 23 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 23 中的图像 2,2
    • Use the flat end of a spudger to pry up the "SUB" connector from the daughterboard and disconnect it.
    询问修复机器人
    添加评论
  24. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 24 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 24 中的图像 2,2
    • Use the flat end of a spudger to pry up the "MAIN" connector from the motherboard and disconnect it.
    询问修复机器人
    添加评论
  25. Samsung Galaxy A15 Screen Assembly Replacement, Remove the interconnect cable: 步骤 25 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Remove the interconnect cable: 步骤 25 中的图像 2,2
    • Pick up the interconnect cable and remove it from the phone.
    询问修复机器人
    添加评论
  26. Samsung Galaxy A15 Screen Assembly Replacement, Peel up the pull tabs: 步骤 26 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Peel up the pull tabs: 步骤 26 中的图像 2,2
    • Peel up the blue battery pull tab until you can grab it with your fingers.
    询问修复机器人
    添加评论
  27. Samsung Galaxy A15 Screen Assembly Replacement: 步骤 27 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 27 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement: 步骤 27 中的图像 3,3
    • Use your fingers to peel the two small tabs from the top and bottom corners of the battery's left edge.
    • If these tabs aren't fully separated, you won't be able to lift the battery in the next step.
    询问修复机器人
    添加评论
  28. Samsung Galaxy A15 Screen Assembly Replacement, Separate the battery adhesive: 步骤 28 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Separate the battery adhesive: 步骤 28 中的图像 2,2
    • Take care not to crease or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • With one hand, fold the two upper and lower tabs out of the way of the battery and firmly hold down the frame.
    • Pull up on the blue battery pull tab with strong, steady force until the battery is separated from its adhesive in the phone.
    • If the battery doesn't budge, apply a few drops of isopropyl alcohol (90% or greater) beneath the battery, wait a few minutes, and try again.
    询问修复机器人
    添加评论
  29. Samsung Galaxy A15 Screen Assembly Replacement, Remove the battery adhesive: 步骤 29 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Remove the battery adhesive: 步骤 29 中的图像 2,2
    • Completely peel off the remaining battery adhesive attached to the frame of the phone.
    询问修复机器人
    添加评论
  30. Samsung Galaxy A15 Screen Assembly Replacement, Remove the battery: 步骤 30 中的图像 1,1
    • Remove the battery and its film.
    询问修复机器人
    添加评论
  31. Samsung Galaxy A15 Screen Assembly Replacement, Detach the display cable connector: 步骤 31 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Detach the display cable connector: 步骤 31 中的图像 2,2
    • Insert the flat end of a spudger underneath the display ribbon connector and pry it off of the board.
    添加评论
  32. Samsung Galaxy A15 Screen Assembly Replacement, Remove the daughterboard screw: 步骤 32 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Remove the daughterboard screw: 步骤 32 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3 mm-long screw securing the daughterboard to the phone.
    询问修复机器人
    添加评论
  33. Samsung Galaxy A15 Screen Assembly Replacement, Remove the motherboard screw: 步骤 33 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Remove the motherboard screw: 步骤 33 中的图像 2,2
    • Use a Phillips screwdriver to remove the 3 mm-long screw securing the motherboard to the phone.
    询问修复机器人
    添加评论
  34. Samsung Galaxy A15 Screen Assembly Replacement, Remove the boards: 步骤 34 中的图像 1,2 Samsung Galaxy A15 Screen Assembly Replacement, Remove the boards: 步骤 34 中的图像 2,2
    • Grab the motherboard and daughterboard by their edges and pull them together straight up and out of the phone.
    • Be careful not to strain on the antenna cables connecting the two boards. If it feels stuck, gently pull up on it until it is free.
    询问修复机器人
    添加评论
  35. Samsung Galaxy A15 Screen Assembly Replacement, Remove the vibration motor: 步骤 35 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Remove the vibration motor: 步骤 35 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Remove the vibration motor: 步骤 35 中的图像 3,3
    • Insert one tip of angled tweezers into the gap beneath the vibration motor closest to the bottom of the phone.
    • Grab the vibration motor with the tweezers and lift it up and out of the phone.
    询问修复机器人
    添加评论
  36. Samsung Galaxy A15 Screen Assembly Replacement, Remove the earpiece speaker: 步骤 36 中的图像 1,3 Samsung Galaxy A15 Screen Assembly Replacement, Remove the earpiece speaker: 步骤 36 中的图像 2,3 Samsung Galaxy A15 Screen Assembly Replacement, Remove the earpiece speaker: 步骤 36 中的图像 3,3
    • Insert the tip of angled tweezers into the gap next to the earpiece speaker. Get underneath the earpiece speaker and gently pry it up.
    • Lift the earpiece speaker out of the phone.
    询问修复机器人
    添加评论
  37. Samsung Galaxy A15 Screen Assembly Replacement, Only the screen assembly remains: 步骤 37 中的图像 1,1
    • You're now left with the screen assembly.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
    添加评论
结论
取消:我没有完成这个指南。
50等其他人完成本指南。
Nick Schultz
于03/24/24注册
58,525 声望
创作了317篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了29,508篇指南
5指南评论
Can someone help me figure out where to purchase the OEM screen for Galaxy a15 5g please?
Daniel Aguilar - 回复 分享
I seen one on Amazon for $85.
Sold by Pishzeo
Martina Mueller - 回复 分享
I bought it on Temu
Federico Bellizia - 回复 分享
Cool 🍎 🇨🇮💪
Arthur yokoré - 回复 分享
If you are in the US, just get a prepaid locked Samsung A15 from Walmart for like $40 and repack the motherboard.
Tomislav - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 67
过去 7 天: 403
过去 30 天: 1,840
总计 36,020
