Samsung DVD-HD850 Player Disk Drive Motor Replacement
简介
转到步骤 1This guide shall assist you in fixing a jammed disk tray if you followed thoroughly the troubleshooting steps with no positive results.
Find and locate the disk tray it is located top right hand side of the component when the back of the device ( dvd player ) is facing you.
Locate and gently remove the data strips on the tray. There are three in total, two on the left hand side and one on the right.
After removing the clips slowly incline the disk drive towards you and unclip it from the two (2) brackets located on the top
Slowly remove the circuit board/cables/strips from under the black bar. ( under and over)
