跳转到主内容
Retina MacBook 2015 USB-C Port Replacement
Geoff Wacker
Geoff Wacker7 其他贡献者
最后更新于 August 24, 2022
30分钟 - 1小时
中等
Use this guide to replace the USB-C port on your Retina MacBook 2015.
To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable. These accessories are not included with your MacBook, so make sure you have them ready before you begin.
你所需要的
配件
工具
查看更多...
视频概述
  1. Retina MacBook 2015 USB-C Port Replacement, Unfasten the lower case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    If, like me, you didn’t have a P5 Pentalope screwdriver but did have one that fits an iPhone.
    You can sand down the tip until it’s the right size.
    Stuart - 回复
    Thank you Stuart! I would never have thought of this and it worked perfectly.
    R McP -
    Hello,
    where do I plug the USB-C to USB-A cable on MacBook MacBook Pro (Retina, 15-inch, Mid 2015)
    I can’t any port suitable for USB-c !??
    sissi - 回复
    My MacBook had P4 pentalobe screws, notP5
    Greg Lavardera - 回复
    Big thanks to Jeff for such thorough and detailed instructions. This is definitely a more advanced repair so if you're not comfortable with making such repairs, like having experience working on iPhones, computers, etc., you might think twice before attempting. It's very helpful to read all the instructions thoroughly before starting. Plan on 3 to 4 hours—the battery removal along with its adhesive is a real $@$*-show, but totally doable if you followed Jeff's recommendations.
    I'll post a few tips in the comments on each step that I think is worth noting but I will mention here one of the trickier steps. ZIF connectors on the flat cables can be a little tricky, especially if you have never done these. Before attempting to do the first one (step 8) review the others in steps 16, 20, and 25. You'll get a better sense of how these little retaining flaps flip up and what they actually look like when you study each photo in each step—they are very tiny and fragile.
    Steven Gibson - 回复
    Just finished replacing the battery. I followed the directions that came with the battery instead of this guide. In short, Steps 15 to 35 are not necessary. You don't have to completely disassemble the laptop to replace the battery.
    Andrew Mohan - 回复
    Thanks. I skipped it too and it worked.. It was a painstaking to remove the two side batteries as the cables were connected. But a little patience gets the job done. I did however remove the audio jack connector but from the audio board. Removed the display connector and the usb-c bracket to get the bottom case free.
    Paras Tolani -
    READ EVERY STEP, AND EVERY COMMENT FOR THAT STEP BEFORE ATTEMPTING! Go slow. Think first. Be organized. No probs.
    David Nagle - 回复
  2. Retina MacBook 2015 USB-C Port Replacement: 步骤 2 中的图像 1,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 2 中的图像 2,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 2 中的图像 3,3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
    "During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place."
    Not sure if was just me, but I sweated to push those clips, I was pushing hard for the kind of product, but not enough for this Apple one. I was almost losing hope.
    Giovanni Conti - 回复
    The clips are like knobs that click into a socket of two metal prongs. Don't pull too hard and have it surprise you.
    Joseph Wright - 回复
  3. Retina MacBook 2015 USB-C Port Replacement: 步骤 3 中的图像 1,1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  4. Retina MacBook 2015 USB-C Port Replacement: 步骤 4 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 4 中的图像 2,2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
    This step at the suggested height tears the ribbon cable. do step 7 first. carefully
    Kiernan - 回复
    If you carefully open the display all the way and then lift the upper case, you can let the display rest on your flat working surface. The upper case will be held in place at an appropriate angle by the display hinge.
    Mike C - 回复
    It's a two-spooger-job.
    LMAOOOOOOOO
    Elixir2 - 回复
  5. Retina MacBook 2015 USB-C Port Replacement: 步骤 5 中的图像 1,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 5 中的图像 2,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 5 中的图像 3,3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
    Wow okay could someone explain why this is necessary? What happens if you skip this step and simply undo the screw to disconnect the power?
    EB Computers - 回复
    Removing the screw does not disconnect the power—power comes from the battery terminals contacting the underside of the logic board, and they’re tricky to separate reliably at this stage of disassembly. This step is the safest and easiest way to kill power; don’t skip it.
    Jeff Suovanen -
    What if I can’t get my LED to power on when reassembling the machine?
    greg2b - 回复
    Update: Realized my USB-C connector (Step 14) wasn’t properly seated.
    greg2b -
    Hi what will happen if i skip this step, coz i did tried to power down the battery by pressing small gold button, but no avail. the LED light still there even after more than 5 times press (5-10secs or more) each press.
    Dimitri Zaborski - 回复
    Did you learn the answer to your question? I'm having the same issue -- I keep pressing the gold button but the battery light stays on.
    R McP -
    Mi laptop doesn’t turn it on doing that ):
    alexisaguinagam26 - 回复
    This step is critical. If not done, there is a good chance trackpad and keyboard backlight will be dead on reassembly. If this, here is how to recover
    Keyboard and trackpad not working after battery replacement
    The LED light is quite dim so do it on a dark place to see it clearly.
    After rMB is reassembled. CAN'T JUST PLUG IN THE USB-C CHARGER. Must follow an exact sequence with charnge with 1A brick first. See above link comment "Update 3"
    Howard - 回复
    ¿El indicador led debe volver a encender una vez se conecte la batería y se pulse el botón de power o se queda apagado hasta que se conecte el cargador??
    Samuel Suárez - 回复
    I did not do this after reconnection. But read my post(10/8/24) on how to power up rMB after assembly. Need to use different smaller charger first before larger rMB charger. Also if didn't do this discharge step properly prior to disconnecting kbd/trackpad, they can fail likely due to corrupted firmware. I also show how to recover this situation in the post on 10/8/24.
    Howard -
  6. Retina MacBook 2015 USB-C Port Replacement: 步骤 6 中的图像 1,1
    • Close the MacBook and carefully flip it upside-down.
  7. Retina MacBook 2015 USB-C Port Replacement: 步骤 7 中的图像 1,1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
    Before the IPD flex cable can be removed the battery disconnect button has be held down for up to 10 seconds. If the LED near the battery connector is switched on it shows that there is power going through the logic board from the battery, once the button is pressed and this light goes off the machine is safe to be worked on.
    Aaron Dalziel - 回复
  8. Retina MacBook 2015 USB-C Port Replacement: 步骤 8 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    Only peel back the first half of the tape covering the trackpad cable ZIF connector—do not completely remove.
    Steven Gibson - 回复
    Gently - lift tape while wiggling cable side to side. Be sure tape is released, but do not remove completely
    David Nagle - 回复
  9. Retina MacBook 2015 USB-C Port Replacement: 步骤 9 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 9 中的图像 2,2
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    This is very tricky indeed - at least on my computer. I failed at this point - having skipped to it as sugested above so as not to stress the ribbons on the other side. The ZIF was not as I expected. They had opened when I pulled up the stick cover and I found I was working on the socket itself. The top edge came adrift after almost no pressure being put on it. The ribon did not come free with gentle pulling though. At that point I put the back on again… waited until the battery recharged a bit and found I had not nroken it after all. I doubt I shall try again. It is much harder to replace than the 15 inch - much…
    Simon Anthony - 回复
    I’ve just found that I have broken it after all. No keyboard. Bluetooth still works so I can use the machine.
    All in all, an expensive mistake. BTW - I did NOT get the kit from IFIXIT - not sold here.
    Simon Anthony - 回复
    I found “Recognizing & Disconnecting Cable Connectors”
    认识和断开线缆连接头
    useful, esp. for someone who has not used ZIF connectors and retaining flaps before. There are several retaining flaps that need to be opened. The first time is tricky as you need a sense of how much force to apply. I used the flat end of the provided spudger. Apply progressively firmer upward pressure until the retaining flap pops open. The first time is tricky, but straightforward thereafter.
    Ki Park - 回复
    Mouse back and forth between the two right-side thumbnail photos and you will get a little animation feel showing how these ZIF connectors operate—it's very helpful. Apply light but consistent pressure to pop them up. Helps to go side to side if they're a little stubborn.
    Steven Gibson - 回复
    this is a great tip Steve!
    Eric - 回复
  10. Retina MacBook 2015 USB-C Port Replacement: 步骤 10 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 10 中的图像 2,2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
    it would be nice to have a specific picture of the cable and contacts and how it is oriented in the ZIF connector. This isn't clear in any of these photos or text.
    My trackpad cable snapped so had to replace it and none of the replacement cables have the tape which is on the smaller end to the trackpad. The other end is fairly easy to figure out but the trackpad end isn't as the cable makes a 180 degree turn inside the case (poor design).
    Marc - 回复
  11. Retina MacBook 2015 USB-C Port Replacement: 步骤 11 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 11 中的图像 2,2
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
    You can open the laptop screen all the way open with it flat in the table (screen facing up) and the keyboard should stay up.
    xavierviveros - 回复
  12. Retina MacBook 2015 USB-C Port Replacement: 步骤 12 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 12 中的图像 2,2
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
    the moment you opening macbook case and before any tinkering with connections, you MUST press little yellow button on logicboard, located on the right from battery connector - this will disable all power to the board. You can check by looking at the small led on left side of the battery connector - if there is very faint light, it means that power is still there. After pressing button light should go off. Removing screw is not necessary at all, and like I said - you MUST disable power before any touching to connections etc.
    DigiHead - 回复
    Where it says
    “2015 models have a silver grounding clip with two foam pads directly under this screw“
    I have a 2015 MacBook & the grounding clip is not there!
    I’m using this guide to investigate why there are lines on screen or darker screen at certain angles of opening it. Also a background ghosting effect on screen too.
    No obvious damage or loose connectors so wondered if the lack of grounding clip can cause these symptoms?
    Anybody out there know?
    nijafe - 回复
    Either buy the clip and check, or replace the screen (or LB), but the macbook would more likely not start if there is a missing grounded connection, depending on what is being grounded.
    Sean -
  13. Retina MacBook 2015 USB-C Port Replacement: 步骤 13 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    Battery Blocker
    $3.99
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
    I HAD TO DO THIS TWICE. After replacing the battery while following this guide to a 'T', the battery was not being recognized by the logic board. Strangely, with the power unplugged it would still light up the screen and tell me the battery was at a critical level, but it would not boot. Resetting the SMC had no effect. I thought I killed my computer or got a bad battery, so as a last ditch effort I re-opened the case, pressed the battery disconnect button, removed the screw and inserted the battery separation tool again to Physically Disconnect the battery from the mainboard. After about 5 minutes I then removed the tool and reassembled everything, plugged in via 5v iphone charger and USBA-C cable again and LO, the battery is now reporting correctly, charging correctly and allowing me to boot on its power .
    Neil Schultz - 回复
  14. Retina MacBook 2015 USB-C Port Replacement: 步骤 14 中的图像 1,1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips #00 screw.
    • 3.5 mm T5 Torx screw
    This was oddly the hardest part. That Tri-Point screw just wouldn’t budge! I had to sand the end of the only Tri-point screwdriver I had in the end to get it to fit.
    Stuart - 回复
    Be sure to get the metal plate under the chip near where the PT5 screw is before tightening
    abscate - 回复
    I should have read the comments before using the provided 1.1 mm Tri-point Y00 bit. I almost stripped the screw but was able to use a small flat head bit to open the screw.
    Ifixit: you may want to update this part in the instructions. Not everyone reads the comment section, esp. when it comes to specification of bits which is basic and must be accurate. This is one of the more critical ones in the procedure that can easily go south. The rest of the instructions are excellent.
    Ki Park - 回复
    early 2015 model here. I’ve used a Y1.5 with cautiously applied down force.
    beaudry.ian - 回复
    My 2015 had a 2.5mm Y screw not a Y000.
    Michael Bonney - 回复
    Adding to the helpful comments above, on replacing the 1.1mm tripoint screw, I found the the magnetism of the nearby speaker coil overcame that of the driver and would draw the screw away or the combo of forces would fling it out of the work area! After fiddling with it for too long, I used some of the battery adhesive removed earlier to attached the screw to the driver. Wax would probably work better if I’d had some.
    jefflyons - 回复
    I used the PH00 head to unscrew what they call the “1.1 mm Tri-point Y00 screw”, NOT the Y00 head, and it unscrewed perfectly fine.
    Grace Escamilla - 回复
    Agreed, my screw was a PH00.
    stephen delaney - 回复
    I have an early 2015 MacBook and it was a PH00 head I needed to use.
    Sean Stein - 回复
    Accidentally broke this cable
    Any idea with compatible parts??
    Part number is 821-00402-A.
    My mac is 12 inch A1534
    What screw should i use??
    zack - 回复
  15. Retina MacBook 2015 USB-C Port Replacement: 步骤 15 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 15 中的图像 2,2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    Emphasis on aligning the bracket correctly. What the pictures do not show is that underneath the flat part of the metal bracket (the area between the two screw holes) is a connector that needs to be accurately aligned. Aligning the two screw holes does not imply that the connector is seated correctly.
    After I re-assembled my 2015 MacBook power would not come on. I thought I had damaged the logic board despite being careful and following instructions. Diagnosing the problem took a while. Retracing the steps and focusing on power supply I was able to determine that the metal flap which hides the connector underneath had not made proper contact.
    What I did was to use a finger to get a tactile feel for the connector underneath the metal bracket aligning properly and then press down vertically when it seemed to be aligned. It’s a subtle tactile feel. After re-doing this step, I got power back. Be careful not to damage the connector as noted in the instructions.
    Ki Park - 回复
    Good tip. It’s so easy to damage these fragile connectors by forcing the plug in and reattaching the mounting plate screws
    Peter Newman -
  16. Retina MacBook 2015 USB-C Port Replacement: 步骤 16 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 16 中的图像 2,2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  17. Retina MacBook 2015 USB-C Port Replacement: 步骤 17 中的图像 1,1
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
    hey my macbook do not have sound after replacing the topcase, i did connect everything like here you did, also I did the reset of PR and NVRAM. What Can I check more? simply when I open the OS, there is no audio device at all
    dkflu - 回复
    The audio jack cable is a bit of a pain to reinsert. I found if I turned the screen and the bottom on its side, like an open book, I had much better orientation and it was much easier to insert.
    Steven Gibson - 回复
    Excellent guide and all works like a sharm, but was one issue. After full assemble there wasn't sound. Then I open Macbook again and disconnect and connect audio cable. You must insert cable so, that white stripe will not visible. And sound reveal!
    Pzs Serv - 回复
    This helped me, thanks!
    Egbert Kappert -
  18. Retina MacBook 2015 USB-C Port Replacement, Retina MacBook 2015 Lower Case Assembly Removal: 步骤 18 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement, Retina MacBook 2015 Lower Case Assembly Removal: 步骤 18 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to peel back the tape covering the display cable connector.
  19. Retina MacBook 2015 USB-C Port Replacement: 步骤 19 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 19 中的图像 2,2
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
    I'm in trouble, pulling the tape I took off the flap, what can I do?
    Alberto Raso - 回复
  20. Retina MacBook 2015 USB-C Port Replacement: 步骤 20 中的图像 1,1
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
  21. Retina MacBook 2015 USB-C Port Replacement: 步骤 21 中的图像 1,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 21 中的图像 2,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 21 中的图像 3,3
    在这个步骤中使用的工具:
    iOpener
    $12.99
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If it doesn't separate easily, heat the cable and/or the case directly beneath it with a hair dryer or iOpener to soften the adhesive, and try again.
    I should have used a hair dryer to warm up the glue because the black paint stuck to the board and It exposed a patch of the cable. It might be ok.
    Joseph Wright - 回复
  22. Retina MacBook 2015 USB-C Port Replacement: 步骤 22 中的图像 1,1
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Carefully line up the cable with the gold contacts facing down, and gently slide it into the connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
    A step was skipped. You have to flip up the metal locking tab on the socket before the cable can be removed. See the photo.
    Vin Coniglione - 回复
    And be careful when re-inserting the connector. One end of the two indentations got a little bent (I did not notice) which resulted in a black screen when powering up. I used a heat gun (low setting) to separate the cable from the labtop housing. When re-assembling, first insert the connector (after closing the metal flap as instructed), verify that it’s properly seated, then re-attach the rest of the cable to the laptop housing. In the first try, I first re-attached the cable to the housing, then tried to insert the cable connected into the metal socket. Because of a lack of slack, the cable connector at one end got bent slightly. After identifying the problem, I had to straighten it/unbend out using my fingers. Hence it is easier to insert the connector first, then attach the rest of the cable to the laptop housing.
    Ki Park - 回复
    Black screen upon reboot:
    Inserting the display ribbon cable into it’s contact without closing the metal flap before reassembly will result in a black screen.
    Charlene Lizut - 回复
    I live in a colder climate (and it's winter now) - a hair dryer was absolutely necessary to get this cable loose.
    David Nagle - 回复
    OK, when I read those directions, I did it wrong. I followed the instructions and kept the flap closed when the cable was reinserted during reassembly. Of course I got a blank screen. It should read the flap must be closed AFTER the cable is reinserted during reassembly.
    Eric - 回复
  23. Retina MacBook 2015 USB-C Port Replacement: 步骤 23 中的图像 1,1
    • Separate the upper case assembly from the lower case assembly.
  24. Retina MacBook 2015 USB-C Port Replacement, Audio Jack Board: 步骤 24 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement, Audio Jack Board: 步骤 24 中的图像 2,2
    • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
    Does unplugging the "dual microphone assembly ribbon cable" affect anything other than the microphones? The headphone jack is separate, for example, right?
    wizfish mcfrabblegabben - 回复
    Right. We haven't tested it, but unplugging that cable shouldn't affect anything other than the microphones. You can see the microphone assembly in this guide.
    Jeff Suovanen -
  25. Retina MacBook 2015 USB-C Port Replacement: 步骤 25 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 25 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to pull the microphone assembly ribbon cable free of its connector.
    I broke the microphone assembly ribbon cable, from step twenty five. Is there anyway to fix this, soldering kit, or can I order a new cable online?
    Read Fuller - 回复
  26. Retina MacBook 2015 USB-C Port Replacement: 步骤 26 中的图像 1,1
    • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
  27. Retina MacBook 2015 USB-C Port Replacement: 步骤 27 中的图像 1,1
    • Remove the audio jack board.
    On your way back during reassembly, as long as you are VERY careful with the ribbon once you do it, it is easier to reattach the ribbon in the connector before reseating the audio jack board.
    lauren - 回复
  28. Retina MacBook 2015 USB-C Port Replacement, Display Assembly: 步骤 28 中的图像 1,1
    • Remove the two 3.3 mm T5 Torx screws securing the display cable assembly.
  29. Retina MacBook 2015 USB-C Port Replacement: 步骤 29 中的图像 1,1
    • Remove the single 4.3 mm Phillips #00 screw securing the USB-C port ribbon cable.
  30. Retina MacBook 2015 USB-C Port Replacement: 步骤 30 中的图像 1,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 30 中的图像 2,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 30 中的图像 3,3
    • Unfold the USB-C port ribbon cable until it lays flat, allowing access to the bracket beneath.
    my a1534 had slightly different connector 821-00828-A an it had two torx screws attaching it
    Maria Belova - 回复
  31. Retina MacBook 2015 USB-C Port Replacement: 步骤 31 中的图像 1,1
    • Lift and remove the metal bracket securing the USB-C port ribbon cable connector.
    • During reassembly, be sure the metal tab on the USB-C connector board slides through the slit on the metal bracket.
  32. Retina MacBook 2015 USB-C Port Replacement: 步骤 32 中的图像 1,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 32 中的图像 2,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 32 中的图像 3,3
    • Use a spudger to disconnect the USB-C port ribbon cable by prying the connector straight up.
    • Pry from the side nearest the back edge of the MacBook.
    • Remove the ribbon cable.
  33. Retina MacBook 2015 USB-C Port Replacement: 步骤 33 中的图像 1,1
    • Fully open the display.
    • Set the MacBook down on its right edge with the display facing away from you, as shown.
  34. Retina MacBook 2015 USB-C Port Replacement: 步骤 34 中的图像 1,2 Retina MacBook 2015 USB-C Port Replacement: 步骤 34 中的图像 2,2
    • Remove the four 4.8 mm T8 Torx screws securing the display hinges.
    On an early 2015 model, I found the T9 Torx bit to be too tight a fit in the hinge screw heads. Almost to the point where one screw head got slightly damaged as the bit slipped when turning as it hadn’t gone in far enough. This is the T9 bit that came with the iFixIt 64 bit driver kit.
    So I used the T8 bit instead and managed to loosen the other screws much more easily. It’s a slightly looser fit but it goes in further and didn’t slip even though the screws on this particular machine were very very tightly screwed in.
    Cool_Breeze - 回复
    @cool_breeze I think you’re right and this is probably a mistake in the guide. Apple commonly uses T8 screws, T9 not so much. But it can be hard to tell for sure depending on which toolkit you happen to be using. I’ll update the text to say T8! Thanks for the heads-up.
    Jeff Suovanen -
  35. Retina MacBook 2015 USB-C Port Replacement: 步骤 35 中的图像 1,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 35 中的图像 2,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 35 中的图像 3,3
    • Holding the display assembly with one hand and the upper case with the other, push them together slightly to move the hinges out of their recesses in the the upper case.
    • There are only a few millimeters of play between the hinges and the case, so you won't need to push far.
    • Push the upper case forward while pulling back gently on the display.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
    Furthermore once the repair is complete it's also standard procedure to use a 5Watt power adapter to charge the MacBook until a small chime is heard, at which point the standard adapter can be used
    Jamie H - 回复
    How long does it take usually before you should hear the chime? Any way to test that the USB-C has been properly plugged backed in before reassembling everything?
    Pierre Renaux - 回复
    When reassembling, remember that the keyboard goes UP against the display (erm erm.)
    bredelet - 回复
  36. Retina MacBook 2015 USB-C Port Replacement, USB-C Port: 步骤 36 中的图像 1,1
    • Remove the single 2.9 mm T3 Torx screw securing the USB-C port to the upper case.
  37. Retina MacBook 2015 USB-C Port Replacement: 步骤 37 中的图像 1,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 37 中的图像 2,3 Retina MacBook 2015 USB-C Port Replacement: 步骤 37 中的图像 3,3
    • Slide the USB-C port out of its recess in the upper case, and remove the USB-C port.
结论
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
17等其他人完成本指南。
Geoff Wacker
于09/30/13注册
91,222 声望
创作了89篇指南
7指南评论
Can I just pay you to do it lol.
Anthony Quiroz - 回复
Only if you were here, I would pay you 400 to fix it. #NEVER BUYING
Anthony Quiroz - 回复
Is there a guide for the early 2015 MacBook pro?
Eli Stettner - 回复
Thanks so much for this guide! I have one question though. Why exactly do you need to connect the computer to a 5v charger after repair? I replaced the USB-C port on my MacBook and it recognizes the 5v charger but not the 29w charger or any other USB-C device.
taostech - 回复
Did it and worked perfectly! Only issue was that at about step 25 - 30 I noticed a small extra bracket on the tray. I can’t figure out what it is..
Check out here:
Leftover part from USB-C fixing - bracket?
Harri Vainio - 回复
Looks like you can only replace the inner part of the USB-C socket, while the outer part is the formed by the opening in the case. Will replacing the inner part make USB plugs sit tight again, or is it the case opening which is worn out?
Mike - 回复
Unless the case metal is visibly worn down, the internal section of the plug itself is probably the culprit. Happy fixing!
Carsten Frauenheim -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 39
过去 30 天: 215
总计 35,762
