跳转到主内容
加入维修社区 - 创建账户
Remove Stuck Disc from Samsung P241
你所需要的
  1. Remove Stuck Disc from Samsung P241, Top Case: 步骤 1 中的图像 1,2 Remove Stuck Disc from Samsung P241, Top Case: 步骤 1 中的图像 2,2
    • You will need to be near a power source for this guide.
    • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  2. Remove Stuck Disc from Samsung P241: 步骤 2 中的图像 1,2 Remove Stuck Disc from Samsung P241: 步骤 2 中的图像 2,2
    • Pull the top cover towards you until you can lift it up and off.
    询问修复机器人
    添加评论
  3. Remove Stuck Disc from Samsung P241, Remove Stuck Disc from Samsung P241: 步骤 3 中的图像 1,1
    • After the top cover has been removed, locate the disc drive on the right hand side of the DVD player.
    询问修复机器人
    添加评论
  4. Remove Stuck Disc from Samsung P241: 步骤 4 中的图像 1,1
    • Locate the four rectangular holes in the top of the black plastic disc drive.
    询问修复机器人
    添加评论
  5. Remove Stuck Disc from Samsung P241: 步骤 5 中的图像 1,2 Remove Stuck Disc from Samsung P241: 步骤 5 中的图像 2,2
    • You will now pry off the black plastic cover from the disc tray. Insert a flathead screwdriver into the slot indicated and press down while at the same time pulling the screwdriver towards the middle of the device. This will pop the plastic catch out to the side.
    询问修复机器人
    添加评论
  6. Remove Stuck Disc from Samsung P241: 步骤 6 中的图像 1,1
    • Without removing the first screwdriver, insert a second one into the hole indicated and do the same motion.
    • You can now lift up the right side of the cover. Don't pull up too far or you could break the clasps on the left side.
    询问修复机器人
    添加评论
  7. Remove Stuck Disc from Samsung P241: 步骤 7 中的图像 1,1
    • Now repeat this process, unclipping the catches on the other side.
    询问修复机器人
    添加评论
  8. Remove Stuck Disc from Samsung P241: 步骤 8 中的图像 1,3 Remove Stuck Disc from Samsung P241: 步骤 8 中的图像 2,3 Remove Stuck Disc from Samsung P241: 步骤 8 中的图像 3,3
    • You can now pop of the black plastic cover and see the exposed disc drive. If there is anything stuck inside that is jamming the drive, you can remove it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Lawrence Smith
于01/11/11注册
126 声望
撰写一个指南
团队
Cal Poly, Team 14-7, Forte Winter 2011 Cal Poly, Team 14-7, Forte Winter 2011 的会员
CPSU-FORTE-W11S14G7
5 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 37
总计 4,536
