Philips Satinelle Gear Replacement
没有估计
中等
更好的介绍
简介
转到步骤 1Use this guide if you need to replace the gear that turns the tweezers of your Philips Satinelle.
Unplug the device and remove the purple guard.
Remove the head by pressing the right side of the head (with the device facing away from you).
You will hear a 'click' and the head will become dislodged from the body of the device.
Replace the gear and re-insert the pin.
Ensure that pin is protruding slightly, it should not be flush.
即将完成!
结论
3指南评论
What size pinion is used in it? Kindly help.
Can you send link to buy this piece?
Or 3d Printer file?
Thanks
