简介
根据本指南的操作来更换损坏或工作不正常的Switch的风扇。
Switch 使用JIS标准的螺丝,如果没有对应的螺丝刀,使用普通十字螺丝刀也可以,但一定注意不要把螺丝弄花。iFixit的十字螺丝刀与JIS的螺丝相兼容。
注意:当你拆除屏蔽板时,你需要更换屏蔽板和散热器之间的导热膏。由于普通的导热膏不是为弥合大的缝隙而设计的,最接近的替代品是K5 Pro粘性导热膏。
注意:本指南以及我们出售的零件与2017年发布的原始任天堂Switch型号(HAC-001)以及2019年发布的较新型号(HAC-001(-01))兼容。
你所需要的
258等其他人完成本指南。
由衷感谢以下译者:
77%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
57指南评论
If your joycons are not charging, it could be the fans fault as they seem to share a 1.8v and or 5v rail, I had both joycons refusing to charge, and the fan was not working, so by replacing the fan, it had them charging properly again.
oh? i was wondering why my joycons died and never turned on. i though the hot switch short circuited them. the same thing happened to mine. The fan died as well as my joycons. very useful mate. thanks for the info!
Robby Ninte - 回复 分享
I’ve recently found a video that shows what can be wrong with Switch with the same issue, but working fan https://www.youtube.com/watch?v=WuQC3ipu... . In the comments people confirmed several times that it helps.
If I'm just replacing the fan, do I need to clean off/reapply any thermal paste?
